WallaceGlanza Posted September 12, 2008 Author Posted September 12, 2008 Nope the reflets have been there for aaaaaaaaages. Cheers mate. Quote
WallaceGlanza Posted September 12, 2008 Author Posted September 12, 2008 Thought I'd put a spec listup since there isn't one so:Engine/Turbo:Autofixed FMICApexi Filter (Mounted behind the grill)Road Runner ManifoldBlitz DecatCustom straight through ss 2.5 inch cat back exhaust HKS Actuator NGK Iridium Spark PlugsNGK Blue LeadsWalbro Fuel Pump SARD RRFPR SARD R2D2Carbing Cooling PanelSamco Rad Hoses (Blue)Silkroad/Section engine torque damperBlitz Active ClutchTRD Reservoir CoversGReddy Emanage BlueAircon removedChassis: Cusco L Zero Coilovers Cusco Type OS Front and Rear Strut Braces Cusco Lower Arm Bar Whiteline Anti-lift Kit Whiteline Pan-Hard Rod15in Sebring Sprints (By Rays Engineering) Powder Coated White Brakes:3G 10 Groove DiscsMintex 1144 PadsEarl's Braided Brake Lines All RoundBlue Painted CalipersStock Rear Discs and PadsInterior:Rear seats, belts and parcel shelf stripped outEvo 7 RecarosOmp 4 point HarnessesOmp Corsica steering wheelRazo Formula Spec pedalsRazo Type 340R gear knobEmanage mounted in centre console with custom carbon fibre fasciaGreddy Profec E-01Defi Link 52mm Boost Gauge mounted in Nomad racing A-pillar PodDefi Link Control unit IIIndiglo DialsPioneer DEH-P6750MP HeadunitPioneer TS-E1076 front speakersOptional Armrest Retrimmed in Black SuedeDoorcards Retrimed In Black SuedeCustom Leather Gear GaiterHalfords Mats WOOOOOO!!Exterior:'98 Front bumper cut for fmic with crystal fogs'98 Clear Front IndicatorsGlanza S Bonnet (Raised 10mm at rear)JDM Reflet Rear Light Clusters Quote
Guest Enzo Posted September 13, 2008 Posted September 13, 2008 fark! that list is pretty packed now,since you have bought ther car how much do you tink you have spent on it, including all those troubles you had when you got it,10k inluding the car? Quote
WallaceGlanza Posted September 13, 2008 Author Posted September 13, 2008 Cheers sparky. fark! that list is pretty packed now,since you have bought ther car how much do you tink you have spent on it, including all those troubles you had when you got it,10k inluding the car?It was over 10k last year, its probably around 12k with buying the car the repairs and mods. I'm too scared to work it out exactly! If it wasn't for all the repairs it would be a complete weapon anyway! Quote
WallaceGlanza Posted September 27, 2008 Author Posted September 27, 2008 I'm finally happy with the car! Wahay! Well the clutch was slipping under any significant load, ie going uphill or trying to overtake, so I decided to re-bleed the cutch and adjust the pedal again and now its completely sorted!Previously I was having to give the car 3k revs to pull away smoothly, at least 3k revs any time I wanted to change up smoothly and I was having to heel toe on down shifts every time (again to get it upto 3k revs) for smooth downshifts, I couldn't even use engine braking in the slightest or the car would judder so much it felt like it was pulling itself apart. Basically I was having to drive everywhere like I was in a race, which was becoming a little tiresome, especially when the clutch would then just start slipping. Now though it's like someone has put the stock clutch back in, the pedal is actually lighter than before, I only need between 1.5 - 2k revs to pull away smoothly and can change up or down when I want and use engine braking when I want, I just assumed the 3k revs needed everywhere were normal for the clutch, but now the only difference from stock is when pulling away and the rattle! I'm so much happier now! I've got a couple of little bits on the way but I won't be doing any more significant mods for a while as I'm moving into a new flat and need to get out my overdraft for good this time! But atleastI can finally enjoying driving the glanza for a while....I hope! Quote
Sparky Posted September 27, 2008 Posted September 27, 2008 Good news mate Im looking into the same clutch, whats the changes like? Is the power there straight away compared to standard?Now get out of your overdraft you bum Quote
WallaceGlanza Posted September 27, 2008 Author Posted September 27, 2008 It changes gear nice and snappily now, like you can feel it really grab the next gear quickly as you change but its still reasonably smooth. It does feel slightly keener to rev now with the reduced mass of the clutch assembly too.Its definatley useable as an everday clutch though, the way it was before I adjusted it properly was how bad I expected it to be but its now its fine, although I haven't really done much heavy traffic/stop start driving with it yet.Are you looking at getting the orc version? As the blitz one seems the same but just more expensive because of the name!Being stuck in an overdraft is what happens when you travel around the world, so its kinda worth it! Quote
Sparky Posted September 27, 2008 Posted September 27, 2008 Not really clued up on my clutches yet so was just going by the name Is the ORC item exactly the same? Need a clutch cable of 300bhp Quote
WallaceGlanza Posted September 27, 2008 Author Posted September 27, 2008 It certainly looks exactly the same, I'm going to need to change the friction plate on mine soonish and I'm gonna put the orc one in for the 309 so I'll see if its the same then. There's not that much info on the blitz one but I'd say its the same. Quote
Sparky Posted September 27, 2008 Posted September 27, 2008 Just looking at the ORC clutch though nearly £700 was a bit steep but it comes with a lightened flywheel, sweet!!!! Quote
WallaceGlanza Posted September 27, 2008 Author Posted September 27, 2008 Yeah its not bad since it comes with the lightened flywheel,but it needs to as the rest of the clutch is pretty heavy.Oh and I only paid £200 for mine! Quote
BoostJunkie Posted September 28, 2008 Posted September 28, 2008 sounding good wallace mate, seeing as your on the subject of clutches looking into clutches myself i'm looking into the exedy cerametallic paddle clutch but i've heard they can be quite harsh though.have you had any or know of anyone whos had experience with them as i've heard for likes of stuck in traffic can be a nightmare or like the problem you had d'you think it just needs setting it up properly? Quote
WallaceGlanza Posted September 28, 2008 Author Posted September 28, 2008 Cheers mate. From what I read about that clutch its a bit more harsh but could still be used everyday, its a true paddle clutch though and its only got 3 paddle bits which means it will be more grabby than the likes of the orc since it has a complete friction plate it will also wear quicker. It also costs at around £300 and doesn't come with a lightweight flywheel whereas for £500 the orc does so its pretty much the same if you were to buy a lightweight fly later.These types of clutch's and especially the paddle type aren't ever going to be as good at stop start traffic as the stock one's but if their really bad it could be just be needing adjusted. I was realy surprised at the difference in mine by just bleeding it and adjusting the pedal slightly. Quote
TheFantasticG Posted September 28, 2008 Posted September 28, 2008 Wallace, the car is looking hawt yo!The rims are especially appealing. Quote
WallaceGlanza Posted September 28, 2008 Author Posted September 28, 2008 Wallace, the car is looking hawt yo!The rims are especially appealing.Cheers mate, I assume its the rays you like, I hate having the shitty winter wheels on but I need 4 new tires for the rays and its too late in the year to put them on now. The car looks crap without them. Quote
BoostJunkie Posted September 28, 2008 Posted September 28, 2008 Cheers mate. From what I read about that clutch its a bit more harsh but could still be used everyday, its a true paddle clutch though and its only got 3 paddle bits which means it will be more grabby than the likes of the orc since it has a complete friction plate it will also wear quicker. It also costs at around £300 and doesn't come with a lightweight flywheel whereas for £500 the orc does so its pretty much the same if you were to buy a lightweight fly later.These types of clutch's and especially the paddle type aren't ever going to be as good at stop start traffic as the stock one's but if their really bad it could be just be needing adjusted. I was realy surprised at the difference in mine by just bleeding it and adjusting the pedal slightly.my flywheel is at the engineers with my crank getting lightened and balanced anyway as i dont think its as straightforward as just slapping the lightened flywheel on it needs to be balanced with the crank.so you reckon it would wear quicker? replacement friction plates for that exedy clutch can be bought correct? Quote
WallaceGlanza Posted September 29, 2008 Author Posted September 29, 2008 If the fly is already lightened then its ok to go straight on but if you're lightening the crank it needs done with the fly on.I would wearquicker as their designed with racing in mindnot stop and start traffic etc but yeah I would've thought you'd be able to get justthe friction plate seperately. Quote
WallaceGlanza Posted October 21, 2008 Author Posted October 21, 2008 With the recent work I've done on the exterior and more so the interior the engine bay has started to look a little sad for itself and is letting the rest of the car down. So its time to start tidying it up, the obvious thing to start with is the rocker cover, since I had cleaned and polished it up before with it then quickly corroding again, I deceided to paint it this time and its not hard to guess what colour I chose....Firstly I polished the rocker up again (very slow process by hand with steel wool, hence why its not perfect):Then on with the chosen colour:However the blue on its own is a little too much so to break it up I decided to polish up the raised parts (I say I decided but then my girlfriend actually did it for me! ):Finally with it refitted:I'm really pleased with it, a simple mod that makes a huge difference to the look under the bonnet, the engine bay still needs a proper clean and a few little other bits will be added to brighten it up later. Quote
SiCaln Posted October 21, 2008 Posted October 21, 2008 u both did a bloody good job by the looks of it! Quote
WallaceGlanza Posted October 21, 2008 Author Posted October 21, 2008 Cheers mate, I'm pretty chuffed with it myself. Makes a big difference under the bonnet. Quote
Guest Enzo Posted October 21, 2008 Posted October 21, 2008 nice man, i know your therd manifold bolt is mising, is there a reason for that? Quote
WallaceGlanza Posted October 21, 2008 Author Posted October 21, 2008 Lol Yeah I had to cut the stud and nut off the old block and haven't got another nut since, just laziness!I'm gonna take the mani back off again soon anyway to recoat it so I'll find one then. Quote
Sparky Posted October 21, 2008 Posted October 21, 2008 Nice choice of colours and equally good job mate Quote
WallaceGlanza Posted October 22, 2008 Author Posted October 22, 2008 Cheers sparky, the colour is really nice, its pretty dark and deep out of the light but then in the light it really sparkles. Quote
