Sign in to follow this
Asad
Light Bulb Guide
Been looking for some uprated headlight bulbs just thought i`d make a little guide on what bulbs our cars use
Headlight bulb (main + dipped beam are combined) = H4
Sidelight/number plate/repeater bulbs = 501
Front indicator = 180deg pins 382 Gt only? 120deg pins 581 glanza?
Interior roof light = 269 (festoon type) 31mm
Cluster bulb = 509T
Glanza Foglight (same for remix bumper) = H3C
Not sure on the EP82 fog light bulbs and the rear light bulb arrangment, If any are wrong/different feel free to add them in everyone
A
Share this post
ep82 quadlight dipped beam is hb3 the closest without going direct to toyota
Share this post
very helpful topic here!
in terms of the h4 main headlight. are we allowed the white / blue bulbs ?
Share this post
asad have you considered HIDs?
and if you want to get white interior festoon bulbs its 31mm
very helpful topic
Share this post
I dont have enough monies to install the HID`s the right way (putting projector lenses in etc )
so bulbs will have to do....also on the look out for some fog lights now
Share this post
The number plate surround bulbs for the Glanza's are
Capless 921 bulb's if anybody needs to know
Share this post
Does anyone know what bulb types in the rear lenses are? ie the brake lights, indicator lights and reverse/fog lights?
Share this post
Closest you can get for the gt(quadlight) is hb3 dipped beam hb4 main beam
Was looking at upgrading my gt's lights recently but couldnt find a perfect match to the original bulbs
Share this post
Does anyone know the rear brake light bulb name? They're the big wedge ones
Share this post
I've just used this guide to replace some bulbs, only to find they didn't fit.
Indicators - 382 bulbs have 180 degree fitment pins, whereas my Glanza has 120 degree pins, which is bulb type 581.
Also, the interior light bulb that goes in the roof is 31mm long, as yes, they come in different sizes which isn't mentioned either.
Cheers
Al
Edited by Arnold
Share this post
Actually if you read the replies it is mentioned :p
very helpful topic
Handy topic to have though ill ammend the 1st post with the correct bulb
Share this post
Nice editing ;)
Interior festoon 31mm bulb is type 269. Bulb 264 (mentioned above) is 42mm.
Edited by Arnold
Share this post
I got a stop tail light bulb for my GT the other day and it was referred to as a 21/5w if that's any help
John
Share this post
Ah I knew it was 5w but didn't realise it was 21w for the brake. That would make complete sense though
John
Share this post
Not an answer to your question but I bought Ring Ultima Headlights for the quadlight, the light from those head lights are nuts. So bright. Well worth investing.
Share this post
