joel_ep91 Posted June 2, 2010 Author Posted June 2, 2010 well yesterday i stripped my spare engine head off sump off and crank almost outand shit its going to need some work quite a bit of movement in the pistons in the bore a sit load of build up on the piston tops and the valves are also very built up . but i seem to have a 4efte crank in it.it says 4ET of it anyway it looks ok no marks that i can see yetjoel Quote
joel_ep91 Posted June 2, 2010 Author Posted June 2, 2010 once its all stripped the hard part begins getting the block head and sump ready for painting cant waitjoel Quote
Liam_D Posted June 2, 2010 Posted June 2, 2010 Looking forward to seeing some results from this mate when its all built up and running!! Quickest Uk Spec N/A?? Quote
joel_ep91 Posted June 2, 2010 Author Posted June 2, 2010 im looking forward to it to have no idea what to expect from it tho still trying to decide on which intake to use either corolla mani and bigger TB or my current mani and bigger TB .and trying to get some heat sheilds made up aswell and cover them in heat wrap to cover my ewhole exhaust is getting wrapped also. still dont know how much i should get skimed of the head tho if im going to be running trd headgasket.dont know about quickest n/a ep but it will do me fine Quote
Sparky Posted June 3, 2010 Posted June 3, 2010 This is going to be a 106 GTI killer Awsome mate looking forward to the build Quote
joel_ep91 Posted June 4, 2010 Author Posted June 4, 2010 by the end of the night i might be the proud owner of something very special dont think what i might get has ever been put on a N/A starlet should be intresting tho Quote
joel_ep91 Posted June 5, 2010 Author Posted June 5, 2010 i have just send payment for something you guys are going to love to see on a 4efe. 1 step closer to a silly quick 4efe, (whos excited joel is !!) Quote
joel_ep91 Posted June 5, 2010 Author Posted June 5, 2010 the only other thing im going to say amjad is i need forged rods and upgraded head bolts with it Quote
Amjad Posted June 5, 2010 Posted June 5, 2010 Whaaat?! If you need those this MUST be good! Nitrous? Quote
joel_ep91 Posted June 5, 2010 Author Posted June 5, 2010 ohhh nitrous didnt think about that might look into that aswell Quote
Sparky Posted June 5, 2010 Posted June 5, 2010 Hmmm its gotta be Nitrous, supercharger has been done Quote
Idrees Posted June 5, 2010 Posted June 5, 2010 Pistons? Then you need rods and bolts to go with it? As far as I'm aware, the 4EFTE and 4EFE crank are the same. Quote
joel_ep91 Posted June 5, 2010 Author Posted June 5, 2010 ok so amjad and sparky are right it is a wizards of nos kit i have just boughthttp://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:ITthats the exact kit i bought its a full kit with everything needed and its a year old brand new the kit is over 600 quid the forged rods are to stick the extra tourqe that its going to be purducing arp head bolts so the head doesnt shoot off lol so the list of parts so far is set of 5efhe cams1 full wizards of nos kitset of forged rodsset of arp headboltstrd headgasketcustom light weight flywheelpaddle clutch trd low temp thermostatlight weight pullysstill to get and to be donecrank polished and groundcrank lightened and balanced block honed block , head and sump to be painted port and polish head and mani and try something on the throttle body get a full gasket kit magnetic sump bunglots of oil filters for the run in peroidemanage of somesortthats all i can think of now, let me know what you guys think and what sort of power you think i could reachbe told by a tunner 130/ 140 with nos will prob be achivable on standard ecu and standard rev limit with a management he couldnt say was looking to raise the rev limit between 7k and 7.5k to be safe will fit turbo valve spring to make it a bit safer:D Quote
Dean @RW-Developments Posted June 5, 2010 Posted June 5, 2010 this is gonna be awsome why dont you throttle body it aswell?? Quote
joel_ep91 Posted June 5, 2010 Author Posted June 5, 2010 i have been looking into them spoke to a few tunners and they all say the same thing sound awsome but the strugle to make much more than standard power.on a civic were the inlet is facing forward so getting any amount air it needs still there was very little gains so i just couldnt justify doing it for little gains would sound and look amazing tho Quote
mk1kurt Posted June 5, 2010 Posted June 5, 2010 they have more lift and duration than standard cams as far as i know. turbo guys use them with good results and the are out of a 1500 N/a so can only do good things havent heard any N/A 4efe guys use them so its more of a learn from doing situation . to raise the limit you would have to get an ecu which is also part of my plans.joelorite dude ive got 5efhe cams in the garage had them in my other 4efe that i was building they reallly are brilliant but i havent had chance to fit them to the new one yet are you getting your valves reseated as that made mine a lot smoother also put in a new set of valve springs my 4efe ran better than new when i rebuilt minejust with a few little touchescheers kurt Quote
joel_ep91 Posted June 6, 2010 Author Posted June 6, 2010 thanks kurtwell i was meant to be waking up to a 24 mm front arb and droplink thismorning for my birth day which didnt turn up so a bit pissed at that so all i got this morning was socks and cloths still very nice but its no arb.cant wait to see my nos kit and cams i should get both them this week:D Quote
Nanglebadger Posted June 6, 2010 Posted June 6, 2010 NOS!!!! must be a family obsession!!!! i feckin LOVE it!!!!cant wait to see this thing with all the above work done! its gonna be outstanding dude!Phil. Quote
