Yeah at the bottom of the oem cam cover there is a L shape if you put both the clear cover and the oem one together you will see what im on about...anyways here's a pic of the L shape at the bottom of the oem cover
If you cut that L shape in the clear cam cover it will help it fit flush and put less strain on the plastic when tightening the nuts. NOTE use a dremel and a cuting disc to cut the plastic or it will just shatter!!!!
Hope you dont mind me putting a pic up on your build thread mate if so i will take it off lol
  • Replies 541
Yeah i could of most probably of got it to fit without cutting it..but it was abit tight and working in the cold with plastic is a big no no lol so thought i cut it to be the same as the oem to make life easyer..All i have used for the gap at the top is black silicone and its done the job.
