  • Replies 133
  • Created
  • Last Reply
Top Posters In This Topic
they make custom ones do they? also is the t-piece from there too or elsewhere?
yeah thats were got the lines and fittings form, the T pieces you might find at a motor factors tho
is that a front mounted mushroom mate?
i want to do the same, whats the space like?
did you just use a right angle, then a straight pipe?
thanks
hi yeah its a hks mushroom filter if thats what you mean lol, i think i just used a a 90deg bend but it is tight tho
Wow man some amazing stuff here! Can you write up a how to on flocking your own dashboard? I'd love to do some flocking but never knew I could do it myself, always thought it was for the pro's.
hmm ok. what size inlet is the hks filter? if you can remember
sorry fella i have been out working on the car but i forgot to get it for you !
you can flock parts but my dash doesnt look 100%! the smaller panels are easyer to do.
the kit cost somethink like £30 to start with and you can buy extra flock as you need it,
  • 2 weeks later...
Where abouts can you get it from? :)
back on to working on the car today with mounting a boost controller, turbo timer and ciggy lighter,
first was the ciggy light to be cut in to the centre panel
then time to fit the the turbo timer
then the same with the boost controller
just got to plumb in the rest of the boost controller and get a new harness for the turbo timer,
Awesome work, keep the updates coming!
cheers Idrees i was hoping to start ordering some light weight panels for it, but its started to smoke badly on boost today :p
Gutted :D any idea what the issue is? I hope you can get it fixed asap!
Gutted :wub: any idea what the issue is? I hope you can get it fixed asap!
lookin good so far mate, sorry to hear bout the issue, hope it's not major
i am not 100% sure what it is sadly,
at the moe its blown oil in to the air filter, keeps breathing very heavy and also its smoking badly on boost :o
right got on to sorting the car out today and sadly it meant that the engine had to be taking apart once again to find out the problem, and this is what i found
so i not too sure what to do next now!
i have done a bit more tonight in the way of running wires for my boost controller which might be for sale, and i have started to remove the head lining because its added weight,
as the engine is in bits i thought i would get on with cleaning the head ready for the valves to be removed cleaned and refitted with new valve stem seals, also i have started to clean out the ports in the head to help air flow,
