  • Replies 676
thanks turbo grant :)
As above, I run a gtx3071r with a 3" turbo back exhaust no boxes ect... And it's perfect
  • 1 month later...
So dragged this old thing out last weekends. Was looking rather grubby so sloshed it off. Have done absolutely nothing except take a few bits off this year. I will crack on with the stripping soon. Lots of bits to go on and change. Might even space frame the front end yet.
Quick dirty pic rolling on 14's
A30827B2-9A38-4108-8109-BF09CD3B3B4E_zps
  • 1 month later...
Okok turbo grant, one other thing, have you got any pictures of your injector wires, changed my clips and the plastic holder and I'm not sure which sequence the go back in :s
Okok, the only problem I have now it maintaining idle, when I drove the 5e with stock turbo and manifold it would throttle perfectly but be more light than a corsa haha...not it's running a piggyback system from Thailand, ran that with the stock setup before I did the rebuild and upgrade. Now I just need to iron out the issues to make her run again
  • 4 weeks later...
my car is running now, but it just doesn't feel fast at all....specs are, 5efte...74.5mm forged pistons, with rods also, head is standard. turbo is a gt3076 with 3inch piping; custom manifold (intake and exhaust) 560cc injectors, a evo6 throttlebody, piggy back system, tomei regulator, 255lp dw fuel pump....any help would be awesome!!
I put it at the 5e timing, should I switch it back to 4e? I think that is the problem... My friend thinks that since it's a 5e block the timing should be there, but I think I should put it back to 4e
hello turbo grant, my friend wants to know which point I set the timing at, as there are 3 marks on the head...would it be any trouble from you to send a pic of your timing point up where your cam is?
much appreciated...Michael :)
  • 2 months later...
  • 1 month later...
Hey ...
While looking for something else I come across this !!! What a :fool: I am, as 1 1/4 hrs later at 2.43 am and way past my bed time, I finally reach the anti climax .... is not finished :sad:
Ahh well, no sweet dreams for me tonight loll
Next time .... Top efforts my man :thumbsup::thumbsup:
