Taggy Posted January 27, 2012 Posted January 27, 2012 Not sure if my car is drinking fuel like no ones business, but i put in £20 the other day and i only got 70 miles out of it, i worked it out and im only getting 21mpg!! and whats worse driving slow seems to make no difference to fuel economy.I noticed the fuel pressure at 1900rpm is about 15psi then levels off to 11psi when the turbo spools up at 4000rpm, Is this high fuel pressure from the RRFPR the cause as its mechanical?I am wondering if putting in engine management wil help? Quote
LukeSR Posted January 27, 2012 Posted January 27, 2012 It's because you love to piss people off in your sleeper Quote
Driver Posted January 27, 2012 Posted January 27, 2012 Defo something not right, i was getting 40+ as a daily driver and no less then 25 even giving it alot of stick. Quote
Taggy Posted January 27, 2012 Author Posted January 27, 2012 yeah its a 1.3 after all so off boost it should be quite economical, i noticed the fuel economy went right down when he cranked up the fuel rail pressure because it was leaning out at high RPM.Its fixed the air/fuel ratio mixture when the TD04 is going balls out, but a side effect is that my car when off boost is now running really high rail fuel pressure anything from 13-15psi.What mpg are people getting running td04? Quote
Jamie1st Posted January 27, 2012 Posted January 27, 2012 Ive heard of people getting better MPG on a TD04 off boost? Maybe because you can rev it more before it's in boost?I think you should get a piggy back ECU and get it mapped, will sort the fuelling out on full boost, without turning the fuel pressure right up. Quote
Driver Posted January 27, 2012 Posted January 27, 2012 Just to say aswell my figures above were a td04 at 1.5barish (stock fuel pump and FPR) Tuned by Racetech on an emanage blueId blame the RRFPR route as its more of a get you by option, id invest in some semi decent management and a good map. Quote
Driver Posted January 27, 2012 Posted January 27, 2012 Ive heard of people getting better MPG on a TD04 off boost? Maybe because you can rev it more before it's in boost?I think you should get a piggy back ECU and get it mapped, will sort the fuelling out on full boost, without turning the fuel pressure right up.The reason most get better mpgs on TD04s is because most are mapped semi decently. Stock the Gt/Glanza is quite rich so trimming the fueling with a piggyback etc helps shitloads. Quote
Amjad Posted January 27, 2012 Posted January 27, 2012 Ive heard of people getting better MPG on a TD04 off boost? Maybe because you can rev it more before it's in boost?I think you should get a piggy back ECU and get it mapped, will sort the fuelling out on full boost, without turning the fuel pressure right up.& More powerrrr! The reason most get better mpgs on TD04s is because most are mapped semi decently. Stock the Gt/Glanza is quite rich so trimming the fueling with a piggyback etc helps shitloads.I really hope that's the case, mine drinks like mad on just CT9! :L Quote
starletburkie Posted January 27, 2012 Posted January 27, 2012 15 psi fuel pressure?? stock is 2.4bar or so, 15 psi is 1.0 bar? Quote
F3rAL Posted January 27, 2012 Posted January 27, 2012 I only get 27mpg from my N/A so you should not worry about it Quote
rob_bower Posted January 27, 2012 Posted January 27, 2012 ^^^^27 out of an n/a my n/a still did 35-40 mpg I suggest you try changing the lambda sensor! Quote
raffa_mk Posted January 27, 2012 Posted January 27, 2012 i get about 90 miles for £20 local driving and thats giving it a boot here n there, but did a trip to notts and back and got about 90miles for £12 today thats because it cruise's in 6th gear on motorway average 80mph Quote
ryan lang Posted January 27, 2012 Posted January 27, 2012 get it mapped you got the derv smart car for plodding about Quote
F3rAL Posted January 27, 2012 Posted January 27, 2012 (edited) The thing is I hav no Cat (Friend took it out because it was cloged up) I have cone air filter with cold air feed, and fpr, and I am always first from the lights and yeah I drive in london so a lot of traffic, stop and go all the time. I don't think there is any problem with it, it's just the way i drive and I get less economy on shell 99 fuel than normal, but more performance. Edited January 27, 2012 by F3rAL Quote
LukeSR Posted January 27, 2012 Posted January 27, 2012 I get around 330 miles out of £40 worth of fuel (average price £1.31 a litre), which works out around 33mpg.. I think thats in my n/a Quote
morgey Posted January 27, 2012 Posted January 27, 2012 i get 30-34mpg outa mine albit a 1.6 and n/a Quote
akyakapotter Posted January 27, 2012 Posted January 27, 2012 because it turboed lol :-) heavy right foot like me ;-) Quote
Nanglebadger Posted January 27, 2012 Posted January 27, 2012 mine is bollox too.even off boost, its bollox.been to see Jay about it and we dont know why.hence why i now own a derv....altho it only gets 34 mpg on my shit run to work.Phil. Quote
_shaun_ Posted January 27, 2012 Posted January 27, 2012 mines still pretty heavy on fuel but thats more due to me using the screamer pipe to cheer me up coming back from work. getting it maped on the emu made the world of diffrence more power and better mpgs? its a win win Quote
Nanglebadger Posted January 27, 2012 Posted January 27, 2012 i thought the blitz ECU would have helped mine.nope.Phil. Quote
micky boy Posted January 27, 2012 Posted January 27, 2012 Im getting about 350miles to a full tank on a long run off boost (well as much as i can) im running prety much standared i.e Tmic, Decat hks silent hi power,JAM ECUOhh and thats with an idleing problem!! Quote
nazzurro19 Posted January 27, 2012 Posted January 27, 2012 i get around the 200 mark and it costs me around £40 to fill and thats off boost and on boost i still get around 200 miles to a tank where as before i used to get 230-250so after being mapped its gone way down lol Quote
Amjad Posted January 27, 2012 Posted January 27, 2012 i thought the blitz ECU would have helped mine.nope.Phil.Yeah it's really odd, off boost mine still drinks! Weirdly though, when I'm caning it the gauge doesn't go anywhere for ages! I think Mine's programmed the ECU for fun! May just be my tracking/sticking brakes though hmm Quote
