Rob H@RCH Engineering Posted November 7, 2012 Author Posted November 7, 2012 (edited) Got a bit done on the TRD strut brace today started off with a blasting in the sand blasting cabinet.Before and after with the mountsThen the bar this was fun as it was just too long to fit in the cabinet properly so every thing got covered lolThe ends are staying bare alu as thats what they should be by the look of it and the bar is dark gray. Finished!! looks much better now!Fitted Edited November 8, 2012 by Rob H Quote
Rob H@RCH Engineering Posted November 19, 2012 Author Posted November 19, 2012 well were off back on the Dyno this week for the Hi boost tuning, boost by gear, anti lag, launch control and the hi res knock sensor calibrating to the engine noise, and anything els setting up we can think of lol Quote
_shaun_ Posted November 19, 2012 Posted November 19, 2012 sweet cant wait to see what this thing makes any set powergoals your looking for? Quote
Rob H@RCH Engineering Posted November 19, 2012 Author Posted November 19, 2012 No I dont really have any set goals I am happy with the way it goes now to be honest lol so with an extra bar of boost it should be quite fun!! but its more the other bits that are going to be set up that will make the biggest improvements for me. The boost by gear and traction control are the bits it needs most lol because even with the diff it spins the wheels for fun as it is! Quote
jayc-glanza17 Posted November 19, 2012 Posted November 19, 2012 glad you tarted up that trd brace i gave ya rob...glad it went to a good home.do you run water lines on your td05? Quote
Stevo_n Posted November 19, 2012 Posted November 19, 2012 Good build, loads of effort gone into it. Hope the mapping go's well. Quote
Nanglebadger Posted November 19, 2012 Posted November 19, 2012 sounds good dude! keep us posted on how u get on!Phil. Quote
Rob H@RCH Engineering Posted November 19, 2012 Author Posted November 19, 2012 glad you tarted up that trd brace i gave ya rob...glad it went to a good home.do you run water lines on your td05?Cheers mate it cleaned up nice the strut brace! The Greddy TD05 16G does not have water pipes there oil cooled only.Cheers for the comments lads I will update with some vids and stuff once its done!! Quote
Rob H@RCH Engineering Posted January 15, 2013 Author Posted January 15, 2013 Few more bits to update! Got this nice bit of knobage from a fellow member! Then I finally got round to repainting my rocker cover! While the rocker cover was off I thought it would be a good idea to check the valve clearances now it has some miles on its back and well I will let the photo do the talking lol it took some time to get them spot on again! My stock of ladyboys (shims) All boxed up again with new plugs and it runs so much better it unreal!! Quote
PaulStarletSR Posted January 16, 2013 Posted January 16, 2013 looks smart mate! whats next for her then? Quote
Rob H@RCH Engineering Posted January 16, 2013 Author Posted January 16, 2013 Hi boost (1.6-1.8 bar), boost by gear, traction control, anti lag launch control setting up are just a few of the bits that need setting up in the ECU lol then I have TRD front ARB and white line rear ARBs to fit, and a few other bits to come!! So theres plenty to keep me going for now lol Quote
Rob H@RCH Engineering Posted January 16, 2013 Author Posted January 16, 2013 ex a bit tight?The set up was made to run with the stock N/A rad witch is what I'm running there ain't a lot of space but its no were near making contact! Quote
Rob H@RCH Engineering Posted January 16, 2013 Author Posted January 16, 2013 Bit of a better pick! Quote
Rob H@RCH Engineering Posted January 16, 2013 Author Posted January 16, 2013 O yes they were lol the bloke at the machine shop said to check them once they had done some miles but I think I got them a bit out when I built it too going on them! Quote
Beastmode panda Posted January 16, 2013 Posted January 16, 2013 Fucking hell, just read through it all. Insane build, amazing. Quote
Rob H@RCH Engineering Posted January 16, 2013 Author Posted January 16, 2013 Lol cheers mate there's been a lot of graft, time and money gone into it over the last 12 years! Quote
Rob H@RCH Engineering Posted January 17, 2013 Author Posted January 17, 2013 Another small up date!! spent all morning out in the snow today fitting the rear lights and wiring up the revers lights!! even put the rear fog light in the bottom right light!! Im well happy with the out come! Quote
Xpect Posted January 18, 2013 Posted January 18, 2013 (edited) May I ask, what are the gains of your spark-setup and was it expensive and hard or cheap and easy (or a mixture of that)? Edited January 18, 2013 by Xpect Quote
Rob H@RCH Engineering Posted January 18, 2013 Author Posted January 18, 2013 There ain't really noticeable gains but it allows you to run more boost with out blowing out the spark. You really need to go stand alown some of the piggy backs can run coil plugs I think but I'm not sure. As for because well how far do you go lol.Cheers for the comments! Quote
