Hi guys/gals seen a couple of cars on here with adhesive plates. Any one caught any bad attention with them? They arent legal but how can it be a crime :(
<p>as above some people get the wrong plates which are illegal they are called the "gloss" finish.
you have to get the reflective one and you will be fine.
Edited by 5T4R7ET N/A
Yeah seen a few cars with the gloss plate, although they look smart, its not worth the hastle i am lookin for the reflective type, heard a few friends say some people do knock em out
Mate had one on the windscreen of his rx7 got pulled n was told its illegal he asked the requirements, and it was to size, was reflective and it was visable from infront of the car, so he told the copper to do one haha
I got pulled and fined for having one on my windscreen, told it had too be on my bumper :(
You had a stick-on numberplate on your windscreen? :huh:
apparently the number plate has to be in front of your front wheels, so you cant stick it on your windscreen
Interpretation of Part II
4. In this Part the following expressions shall have the following meanings -
"diagonal length", in relation to a relevant area, means the length of a line drawn diagonally across the square enclosing the area (so that the extent of the relevant area is thereby delimited);
"relevant area", in relation to a registration plate, means the area contained in a square described on the ground -
(a) in front of the vehicle in the case of a plate fixed on the front of the vehicle, and
( B) behind the vehicle in the case of a plate fixed on the rear of the vehicle,
Fixing of front registration plates: vehicles registered on or after the relevant date
6. - (1) This regulation applies to vehicles, other than works trucks, road rollers and agricultural machines, first registered on or after the relevant date.
(2) Except as provided in paragraph (5), a registration plate must be fixed on the front of the vehicle in the manner required by paragraph (3).
(3) This paragraph requires the plate to be fixed -
(a) vertically or, where that is not reasonably practicable, in a position as close to the vertical as is reasonably practicable,
( B) in such a position that in normal daylight the characters of the registration mark are easily distinguishable from every part of a relevant area having the diagonal length specified in paragraph (4).
(4) The diagonal length of the relevant area is -
(a) in the case of a mark having characters the width of which is at least 57 millimetres, 22 metres,
( B) in the case of a mark having characters the width of which is 50 millimetres, 21.5 metres,
© in the case of a mark having characters the width of which is 44 millimetres, 18 metres.
So as long as its vertical as possible and its near 'the front' where that is interpreted as, its fine
Edited by TrisK
