ste91 Posted October 12, 2012 Posted October 12, 2012 Hi guysHaven't posted on UKSO for a while, been lurking as usual but rarely post.Just wondering if there's anything new being done since I've been out of the scene for a bit. I saw a few posts a while back about 4EFTE intake manifolds - what's the deal with those? How do they compare to the trusty Corolla manifolds and what about the throttle body as well?Anything new to do with exhaust manifolds, cams, ECU, etc...? Quote
ryan lang Posted October 13, 2012 Posted October 13, 2012 check my old build thread dude theres a nice big list of things i had/and was going to do Quote
ste91 Posted October 14, 2012 Author Posted October 14, 2012 Who's running a 4EFTE manifold then? How does it compare to the Corolla one? (Better top end?) Has anyone tried the throttle body with it as well as if I remember they are supposed to be a little bit bigger? Quote
ste91 Posted October 14, 2012 Author Posted October 14, 2012 I did, but fuck am I going through 35 pages Quote
Amjad Posted October 14, 2012 Posted October 14, 2012 I think that's the only thing that really developed with the 4efe people switching to the turbo mani and tb Quote
ste91 Posted October 15, 2012 Author Posted October 15, 2012 Did a quick search and from what I can see, the 4EFTE manifold and TB are best for peak power, and the Corolla manifold best for all round, and the 4EFTE stuff isn't easy to fit compared to the good old Corolla manifold. Quote
Josh@TunerLifestyle Posted October 15, 2012 Posted October 15, 2012 cj performance bought out some better ignition leads out witch i think helps also my stickers add 10 bhp Quote
Mike@TD.co.uk Posted October 15, 2012 Posted October 15, 2012 We turbo'd a stock 4efe with a K24, that went well CheersMike JonesTuning Developments Ltd Quote
morgey Posted October 15, 2012 Posted October 15, 2012 We turbo'd a stock 4efe with a K24, that went well CheersMike JonesTuning Developments LtdOoo interesting. Got any printouts? How much boost can a stock 4efe handle? Quote
Mike@TD.co.uk Posted October 15, 2012 Posted October 15, 2012 No printouts i'm afraid as it was before we had a dyno so was road-mapped.Was running 0.5bar boost on a Blitz K24, with EManage and supporting mods.Pulled really well, quicker than a stock Glanza V CheersMike JonesTuning Developments Ltd Quote
ste91 Posted October 15, 2012 Author Posted October 15, 2012 (edited) What other mods did you have? Injectors? Fuel pump? Clutch?I'm guessing it was the usual setup of manifold/decat/exhaust/intake/FMIC, all bolted on, (which inlet manifold did you use?) then 4EFTE injectors, with standard gearbox etc...?And although 0.5 bar doesn't sound like much I imagine it's "enough" because the 4EFE has a higher compression ratio.What was the rev limit? Did you do any head work? (4EFTE valve springs?)Standard 4EFE rad or was the cooling upgraded? Edited October 15, 2012 by ste91 Quote
loguey Posted October 19, 2012 Posted October 19, 2012 So after reading a few turbo 4EFE threads it sounds like a little strenghtening head work, uprated valves and springs etc with a thickher HG to lower the compression and you can safely run boost? Quote
ste91 Posted October 19, 2012 Author Posted October 19, 2012 So after reading a few turbo 4EFE threads it sounds like a little strenghtening head work, uprated valves and springs etc with a thickher HG to lower the compression and you can safely run boost?You don't "need" to lower compression, you just run less boost.5psi on a 4EFE is worth a lot more than 5psi on a 4EFTE. Many turbo Hondas only run a few psi because it's all they need. Quote
loguey Posted October 19, 2012 Posted October 19, 2012 I seeeee. Im curious towards boosting the 4efe as im gonna have one sat in my garage in a few weeks needing new rings, but plan to overhaul it and put it back in my sr.Boost would make my day lol.So what about internals uprate, maybe strengthened rods? Quote
morgey Posted October 19, 2012 Posted October 19, 2012 Just stick 4efte rods in, pistons if u want, 4efte cams, springs n maybe headbolts. Headgasket aswel. Then you would be good for most of what a 4efte can take Quote
ste91 Posted October 19, 2012 Author Posted October 19, 2012 I have no idea how much a standard 4EFE could take but you should be able to run a few psi without problems as there are people in other countries who have the Toyota Tercel which has a 5EFE, some of them bolt turbos onto those (some do the 4EFTE swap) but there are plenty of FE+CT9 setups around so they must be good enough for low boost.The only thing I'm unsure about with boosting an FE is that I don't think they have a knock sensor amongst other things but I might be wrong. Quote
Mike@TD.co.uk Posted October 20, 2012 Posted October 20, 2012 What other mods did you have? Injectors? Fuel pump? Clutch?I'm guessing it was the usual setup of manifold/decat/exhaust/intake/FMIC, all bolted on, (which inlet manifold did you use?) then 4EFTE injectors, with standard gearbox etc...?And although 0.5 bar doesn't sound like much I imagine it's "enough" because the 4EFE has a higher compression ratio.What was the rev limit? Did you do any head work? (4EFTE valve springs?)Standard 4EFE rad or was the cooling upgraded?Sorry, only just seen this Injectors were 4EFTE, fuel pump was stock, as was the clutch. Gearbox was stock, and the inlet was the 4EFE one too. Radiator was stock.Rev limit was stock, as the head was still all 4EFE.Ran very well and surprised us all CheersMike JonesTuning Developments Ltd Quote
Xpect Posted November 8, 2012 Posted November 8, 2012 (edited) Ever seen Motions 115PS red EP91?Or I think he has a few bits of PS more, like 117 or so. And he hasn't even got other or modded cams and is still rocking the 4E-FE Gen3 Intake Manifold.@Mike: So you just bolted on the K24 with an Intercooler, fitted FTE Injectors and mapped the stock ECU with the help of a Emanage? Or was there some work on the had done too, like uprated valve springs? Edited November 8, 2012 by Xpect Quote
TrisK Posted November 8, 2012 Posted November 8, 2012 Or was there some work on the had done too, like uprated valve springs?Rev limit was stock, as the head was still all 4EFE.Ran very well and surprised us all CheersMike JonesTuning Developments LtdHead was stock. Quote
Xpect Posted November 9, 2012 Posted November 9, 2012 Maybe I'll try that, as a FTE is in Germany really expensive. Just the engine, putting it in and getting it road legal would cost much more than 5000€... Thats nearly 4 times the cost of my EP91 Moonlight all Stock. And I already put more than 400€ in it for the Spoiler, the intake and some small parts. And the money I gave tomsgtadvance, that doesn't answer to my PNs on UKSC and doesn't seem to be online here And as the K24 is from a German Audi it should be easier to get road legal. Quote
rmsnoel Posted December 15, 2012 Posted December 15, 2012 Im back in a 4efe after a 5year absence and what Ive noticed is ecu mods. Either jdm 100ps or early generation corolla 7200rpm ecu and wiring. Also just seen today someone using the latest bug-eyed corolla ecu and coilpack with a new 6800rpm limit though I'm not sure about power or torque curve.I'm waiting until I find a few more dyno graphs with air/fuel printouts so I can start playing with injectors and apexi safc maybe. Quote
ro55ifumi Posted December 15, 2012 Posted December 15, 2012 Check Rob's thread as to what can be done />http://www.ukstarletowners.com/index.php?showtopic=53321John Quote
rmsnoel Posted December 15, 2012 Posted December 15, 2012 Early corolla 4-2-1 exhaust manifold or a 4afe 4-2-1 manifold seem to be options aswell. Id love to see our wee v-tec slaying Ep's 0-60 in 8seconds, 130mph topspeed with a janspeed style 4-2-1 bwaap bwaap bwaap. Quote
