zf_165_gt4 Posted December 3, 2014 Share Posted December 3, 2014 Hi guys I wrote TOYOBD1 and designed OBD1READ, JayJ freeze has been corrected in the devices sold after 11 september of this year. Older devices reprogramming can be arranged with me if needed. the After start enrichment mode is supposed to go off after X cycles have been counted. contrarily to Warm up enrichment it is supposed to be present at every engine start even if it is allready hot how to install OBD1READhttp://jfbreton.blogspot.ca/2014/10/toyobd1-android-datalogger-how-to.htmlhow to get the application working with it afterhttp://jfbreton.blogspot.ca/2014/10/toyobd1-android-datalogger-connecting.html nice work by the way JayJ. here's the EP82 I owned for a yearhttps://www.dropbox.com/s/w1tez890b8ij535/2014-08-17%2011.48.14.jpg?dl=0 Quote Link to post Share on other sites
JayJ Posted December 3, 2014 Author Share Posted December 3, 2014 On 12/3/2014 at 7:28 PM, zf_165_gt4 said: Hi guys I wrote TOYOBD1 and designed OBD1READ, JayJ freeze has been corrected in the devices sold after 11 september of this year. Older devices reprogramming can be arranged with me if needed. the After start enrichment mode is supposed to go off after X cycles have been counted. contrarily to Warm up enrichment it is supposed to be present at every engine start even if it is allready hot how to install OBD1READ http://jfbreton.blogspot.ca/2014/10/toyobd1-android-datalogger-how-to.html how to get the application working with it after http://jfbreton.blogspot.ca/2014/10/toyobd1-android-datalogger-connecting.html nice work by the way JayJ. here's the EP82 I owned for a year https://www.dropbox.com/s/w1tez890b8ij535/2014-08-17%2011.48.14.jpg?dl=0 Thanks Jean, you should get another GT! And I can confirm the device is fully working and daily used :-] Quote Link to post Share on other sites
Gainzy Posted December 5, 2014 Share Posted December 5, 2014 Want more pics got my mapping on the 12th can your old blitz pull good power COME ON! lol Quote Link to post Share on other sites
JayJ Posted December 5, 2014 Author Share Posted December 5, 2014 On 12/5/2014 at 12:23 AM, Gainzy said: Want more pics got my mapping on the 12th can your old blitz pull good power COME ON! lol There's not much to shoot as the white car has turned to dull grey thanks to road salt Some of the pics seem to be broken, so maybe I should move all the pics to another place and fix this thread, argh Quote Link to post Share on other sites
Gainzy Posted December 5, 2014 Share Posted December 5, 2014 On 12/5/2014 at 6:33 AM, JayJ said: There's not much to shoot as the white car has turned to dull grey thanks to road salt Some of the pics seem to be broken, so maybe I should move all the pics to another place and fix this thread, argh I went to look through again, needs fixed definitely Quote Link to post Share on other sites
Darraghmh91 Posted December 5, 2014 Share Posted December 5, 2014 nice clean glanza mate i do like them pictures of japan tho makes me wanna go ha Quote Link to post Share on other sites
JayJ Posted February 4, 2015 Author Share Posted February 4, 2015 Pictures fixed, enjoy! Also a few new updates..after a long search, I finally found a genuine set of wind deflectors locally and bought a spare set of mirrors too, so I can get the folding work again.My AGM battery finally let go after fully discharging it four times in a year. I was suprised how well it took the abuse it got. I wanted a bit bigger capacity battery, but didn't want to lose on weight, so I ended up buying Earth X lithium battery. It only weight's 1kg!!!! Incredible product!And then the latest and the most favorite purchaseSpecs are 15x7 ET28, 5cm lip. These are very rare forged OZ starlights, weighing 6kilos each. I'll get them refurbed, as the paint is flaking a bit Quote Link to post Share on other sites
Gainzy Posted February 4, 2015 Share Posted February 4, 2015 Cool man Quote Link to post Share on other sites
JayJ Posted March 24, 2015 Author Share Posted March 24, 2015 Wheels have been painted and are waiting for the new 195/45 T1Rs. I would have gone with the AD08R's, but I already had bought Toyos last spring from another enthusiast, as he was selling them cheap. The car had a service today and it was done under the warranty as the water pump seal started to leak just over a year old. Last purchase came today too..from UK ;-) Nutp0rn Quote Link to post Share on other sites
5e colin Posted April 7, 2015 Share Posted April 7, 2015 DAAAAM that battery is small how long will it last without the engine running and lights on 5 min ??? Quote Link to post Share on other sites
Gainzy Posted April 7, 2015 Share Posted April 7, 2015 She's a beauty Quote Link to post Share on other sites
JayJ Posted April 8, 2015 Author Share Posted April 8, 2015 On 4/7/2015 at 7:44 PM, 5e colin said: DAAAAM that battery is small how long will it last without the engine running and lights on 5 min ??? It equals to 24Ah lead battery, so it actually has a bigger capacity than the AGM battery(16Ah) I had even the weight is 6kg less. Lead acid batteries tend to lose cranking amps in cold, but lithium battery’s cranking power will not drop-off. It also has a microprocessor Battery Management System that monitors the charge level of each cell and balances the charge when needed. Without BMS you can't use lithium batteries in cars, because alternators aren't smart chargers. Lets say the car uses ~150watts with all the lights on(headlights, parking lights, rear lights) and thereon will drain around 12.5amps(150w/12v=12.5), so the battery should last ~2hours in theory. Quote Link to post Share on other sites
JayJ Posted July 30, 2015 Author Share Posted July 30, 2015 Well, my gearbox has decided to stop working properly(syncros), but even with the problems we managed to do a roadtrip(~3000km) up to north, Norway. It was a cool trip and awesome landscapes. Also the rear wheel bearing started to mess around just after we arrived to Norway, so it was going to be a interesting return, but now we are back home safe and sound! Spare gearbox is on its way at the moment thanks to James and next I'm going to order some goodies from Iddy and Nengun or RHDjapan to get the car back to life stronger than ever. ;) Quote Link to post Share on other sites
JayJ Posted August 7, 2015 Author Share Posted August 7, 2015 A lot of parts are on the way, but these came the first! Quote Link to post Share on other sites
Gainzy Posted August 7, 2015 Share Posted August 7, 2015 Hope there's some Jam parts on the way Quote Link to post Share on other sites
JayJ Posted August 17, 2015 Author Share Posted August 17, 2015 Spare gbox arrived finally last week after a lot of hassle with the local postal service. I'll change the input and output shaft bearings just for a peace of mind, so it was time to split it! As the car will be in a daily use around the year I wanted to give some protection to Meisters and ordered coilover socks from Tegiwa. This day was like a Christmas after the courier delivered the last parcels..from Japan.. Ogura flywheel weights 4.1kg, the whole set is just over 8kilos. Quote Link to post Share on other sites
Gainzy Posted August 17, 2015 Share Posted August 17, 2015 I'm jealous of that LSD going to be amazing transformation! Quote Link to post Share on other sites
Rich-k Posted August 18, 2015 Share Posted August 18, 2015 So jealous of all your parts mate! Quote Link to post Share on other sites
