mattyD Posted October 20, 2012 Share Posted October 20, 2012 Are the outer casings exactly the same? Basically I have an n/a gearbox that im going to strip, chuck away the gears and clean up and if what I think is true build up my dog box inside it but I just wanted a bit of confirmation from you more knowledgeable folk beforehand Thankyou muchly Quote Link to post Share on other sites
PaulStarletSR Posted October 20, 2012 Share Posted October 20, 2012 Well I've just put my SR box on the glanza engine for my conversion for the closer ratio aspect so aye mate, crack on Quote Link to post Share on other sites
Rob H@RCH Engineering Posted October 20, 2012 Share Posted October 20, 2012 As far as I know the only difference is the 5th gear cover the n/a one is a pressed steel one not alu like the turbo one, other than that I'm sure there the same Quote Link to post Share on other sites
mattyD Posted October 20, 2012 Author Share Posted October 20, 2012 Awesome, thanks lads I will have to check with TD as to wether its an N/A box or not for definite............ would the 5th gear cover on a mk1 gt box be pressed steel do you know or aluminium like the later 4efte casings?the only reason I ask is because the box I had was consisted of a 6 bolt diff inside which I found out either came from an N/A or mk1 gt box Quote Link to post Share on other sites
lukEp Posted October 20, 2012 Share Posted October 20, 2012 The turbo boxes are all alloy the NA boxes inc paseo ones have steel end cap Quote Link to post Share on other sites
klyfax Posted October 21, 2012 Share Posted October 21, 2012 A 4efe, 4efte non LSD is the same. The diff housing is not the same on a LSD 4efte box. It is bigger. Thats why you can't put a standard LSD in a non LSD box.The end cap is the same, just in steel and alloy. Quote Link to post Share on other sites
morgey Posted October 21, 2012 Share Posted October 21, 2012 On 10/20/2012 at 10:02 PM, PaulStarletSR said: Well I've just put my SR box on the glanza engine for my conversion for the closer ratio aspect so aye mate, crack onAren't n/a ratios longer? Quote Link to post Share on other sites
Rob H@RCH Engineering Posted October 21, 2012 Share Posted October 21, 2012 yes the ratios are different in the n/a box if anything I would say shorter you would be changing gear a lot faster, thats how they get the performance out of smaller engines there is a chart some where with all the ratios for all the boxes on it.This is what Jay posted some time ago! Gear ratio dataAll figures are taken from official Toyota source material that is sitting on the desk beside me here. I apologise in advance if I have made any errors.1996 UKDM 4EFE (C154?)1st : 3.5452nd : 1.9043rd : 1.3104th : 1.0315th : 0.864Reverse : 3.250Differential ratio : 3.722Oil capacity : 1.9 litresOil viscosity : SAE 75W-90Oil Grade : GL-4 or 51996 JDM 4EFE Glanza S1st : 3.5452nd : 1.9043rd : 1.3104th : 0.9695th : 0.815Reverse : 3.250Differential gear ratio : 3.722Oil Capacity : unconfirmedOil viscosity : unconfirmedOil Grade : unconfirmed1996 JDM 4EFTE Glanza V 1st : 3.1662nd : 1.9043rd : 1.3924th : 1.0315th : 0.815Reverse : 3.250Differential gear ratio : 3.722Oil Capacity : unconfirmedOil viscosity : unconfirmedOil Grade : unconfirmed1992-1995 4EFTE GT1st : 3.1662nd : 1.9043rd : 1.3104th : 0.9695th : 0.815Reverse : 3.250Differential gear ratio : 3.722Oil Capacity : unconfirmedOil viscosity : unconfirmedOil Grade : unconfirmed1989-1991 4EFTE GT1st : 3.1662nd : 1.9043rd : 1.3104th : 0.9695th : 0.815Reverse : 3.250Differential gear ratio : 3.722Oil Capacity : unconfirmedOil viscosity : unconfirmedOil Grade : unconfirmed--------------And of course it wouldn't be complete without the automatic figures would it?1996 UKDM 4EFE Automatic (A132L)1st : 2.8102nd : 1.5493rd : 1.0004th : -5th : -Reverse : 2.296 Counter gear ratio : 0.945Differential gear ratio : 3.526Fluid Capacity (transmission) : 5.5 litresFluid Capacity (Differential) : 1.4 litresFluid Type : ATF Type DII or Dexron II or Dexron III1996 JDM Glanza V Automatic 1st : 3.6432nd : 2.0083rd : 1.2964th : 0.8925th : - Reverse : 2.977Counter gear ratio : unconfirmedDifferential gear ratio : 2.821Fluid Capacity : unconfirmedFluid Type : ATF Type DII or Dexron II or Dexron III1992-1995 JDM GT Automatic 1st : 3.6432nd : 2.0083rd : 1.2964th : 0.8925th : - Reverse : 2.977Counter gear ratio : unconfirmedDifferential gear ratio : 2.821Fluid Capacity : unconfirmedFluid Type : ATF Type DII or Dexron II or Dexron III1989-1991 JDM GT Automatic 1st : 3.6432nd : 2.0083rd : 1.2964th : 0.8925th : - Reverse : 2.977Counter gear ratio : unconfirmedDifferential gear ratio : 2.962Fluid Capacity : unconfirmedFluid Type : ATF Type DII or Dexron II or Dexron III----------------There's a blank template for anyone wishing to add more:1st : 2nd :3rd :4th :5th :Reverse : Differential gear ratio : Oil Capacity : Oil viscosity : Oil Grade : Hope that's of some use to somebody somewhere.Jay QuoteMultiQuote Quote Link to post Share on other sites
tayjuniour2015 Posted November 19, 2015 Share Posted November 19, 2015 So would an n/a automatic box be any good on my Glanza auto ? Quote Link to post Share on other sites
5e colin Posted November 19, 2015 Share Posted November 19, 2015 (edited) to the op NO center casing is narower on the na boxes c1## you can use any casing aslong as it is c5# on a turbo box there is 1/2 inch of difference in length of casings between the 2 and 3 digit boxes Edited November 19, 2015 by 5e colin Quote Link to post Share on other sites
tayjuniour2015 Posted November 19, 2015 Share Posted November 19, 2015 Tuning developments said an n/a uk automatic starlet box would fit glanza but might not hold for very long ? Quote Link to post Share on other sites
Bean Posted November 20, 2015 Share Posted November 20, 2015 Anyone got the paseo ratios or anyone used one before? Quote Link to post Share on other sites
Frankieflowers Posted June 28, 2021 Share Posted June 28, 2021 On 10/21/2012 at 9:55 AM, klyfax said: A 4efe, 4efte non LSD is the same. The diff housing is not the same on a LSD 4efte box. It is bigger. Thats why you can't put a standard LSD in a non LSD box. The end cap is the same, just in steel and alloy. Expand Can I put a manual 4efe flywheel on a 4efte that came with a automatic flywheel? Using the 4efe Corolla E11 gearbox on a ep91 4efte. Quote Link to post Share on other sites
Frankieflowers Posted November 23, 2022 Share Posted November 23, 2022 On 10/21/2012 at 9:55 AM, klyfax said: A 4efe, 4efte non LSD is the same. The diff housing is not the same on a LSD 4efte box. It is bigger. Thats why you can't put a standard LSD in a non LSD box. The end cap is the same, just in steel and alloy. Expand I am trying to figure out if the 4efe manual gearbox C140, C150 from a Corolla E11 (that is matching a 4efte from a Starlet Glanza V ep91) has the same transmission as the C56 that matches a 4efte manual Glanza v. I want to put in a KAAZ 1.5 LSD transmission. Anyone? @Jay @Claymore Quote Link to post Share on other sites
