Glanza-Ben Posted February 6, 2014 Author Share Posted February 6, 2014 Inbetween moving house and sending parcels I picked a cheap td04 up and trial fitted it on the new manifold, goin to rotate it tomorrow at some point Quote Link to post Share on other sites
Spoon_tuned Posted February 6, 2014 Share Posted February 6, 2014 Good work mate getting there slowly Quote Link to post Share on other sites
Glanza-Ben Posted February 7, 2014 Author Share Posted February 7, 2014 Had a delivery from opie oils today ready to put in and cleaned my turbo a little bit while rotating it Quote Link to post Share on other sites
Zeldoz Posted February 7, 2014 Share Posted February 7, 2014 How did you get it that spanking? I want to clean the one i bought from you. Quote Link to post Share on other sites
Glanza-Ben Posted February 7, 2014 Author Share Posted February 7, 2014 On 2/7/2014 at 2:19 PM, Zeldoz said: How did you get it that spanking? I want to clean the one i bought from you. Just put a wire wheel on a drill for 5 mins Quote Link to post Share on other sites
Glanza-Ben Posted February 7, 2014 Author Share Posted February 7, 2014 So bolted the turbo onto to manifold also rotated it and bolted manifold on and bolted exhaust up Quote Link to post Share on other sites
daniel_g Posted February 7, 2014 Share Posted February 7, 2014 Nice screamer placement. Quote Link to post Share on other sites
Glanza-Ben Posted February 7, 2014 Author Share Posted February 7, 2014 On 2/7/2014 at 6:10 PM, daniel_g said: Nice screamer placement.Goin out one of my spare bonnets for laughs and giggles Quote Link to post Share on other sites
maddox710 Posted February 7, 2014 Share Posted February 7, 2014 Nice Ben, was going to do that with mine but don't fancy cutting my reverse carbon scoop up Quote Link to post Share on other sites
Glanza-Ben Posted February 7, 2014 Author Share Posted February 7, 2014 On 2/7/2014 at 7:48 PM, maddox710 said: Nice Ben, was going to do that with mine but don't fancy cutting my reverse carbon scoop upCheers mate for most the time it will be facing down but since I have one spare bonnet I'm just gonna drill a hole straight on the front for it to pop out of for summer use and to make some noise Quote Link to post Share on other sites
daniel_g Posted February 7, 2014 Share Posted February 7, 2014 Its so tempting to flip mine 180 and do the same but i can imagine huge flames covering the windscreen haha. Quote Link to post Share on other sites
Glanza-Ben Posted February 7, 2014 Author Share Posted February 7, 2014 On 2/7/2014 at 8:04 PM, daniel_g said: Its so tempting to flip mine 180 and do the same but i can imagine huge flames covering the windscreen haha.My friend has a bonnet entry screamer on his drifters and when out the flames are just goin over the passenger window constantly Quote Link to post Share on other sites
Glanza-Ben Posted February 8, 2014 Author Share Posted February 8, 2014 Got the bc's on tonight and swapped thermostat housing and fitted new coil pack, also fitted driveshafts and headlights and indicators, also ordered oil return pipe, new banjo bolt for turbo, turbo coolant lines and new braided fuel line so once there here it will be put rad and intercooler on and fire it up, touch wood Quote Link to post Share on other sites
Zeldoz Posted February 9, 2014 Share Posted February 9, 2014 When does the screamer flame? On the limiter, or just when on boost and you change gear? Quote Link to post Share on other sites
akyakapotter Posted February 9, 2014 Share Posted February 9, 2014 When it opens on boost it's closed the rest of the time Quote Link to post Share on other sites
maddox710 Posted February 9, 2014 Share Posted February 9, 2014 On 2/9/2014 at 10:45 AM, Zeldoz said: When does the screamer flame? On the limiter, or just when on boost and you change gear?Might not even show fire at all, depends on maps and fuel types Quote Link to post Share on other sites
Glanza-Ben Posted February 9, 2014 Author Share Posted February 9, 2014 On 2/9/2014 at 11:05 AM, maddox710 said: Might not even show fire at all, depends on maps and fuel typesThis is true if it don't flame it will just make stupid noise I'm Tryna think of something I can do to the bonnet I'm gonna drill a hole in but not sure on what some one local wants to wrap it but don't know what style Quote Link to post Share on other sites
Glanza-Ben Posted February 9, 2014 Author Share Posted February 9, 2014 (edited) Swapped thermostat housings and sealed it, fitted new power steering pump pipe, refitted rad and top intercooler pipe turned ignition and checked I had power and was all good, so just waiting on banjo bolt for oil feed then it's crank it over And also getting new fuel line to move that around as only temp atm Edited February 9, 2014 by Glanza-Ben Quote Link to post Share on other sites
jimmymac101 Posted February 9, 2014 Share Posted February 9, 2014 Looking good Ben, must be buzzing to be boosting again James Quote Link to post Share on other sites
Glanza-Ben Posted February 9, 2014 Author Share Posted February 9, 2014 On 2/9/2014 at 5:09 PM, jimmymac101 said: Looking good Ben, must be buzzing to be boosting again JamesTbh mate I'm more excited about mopping and polishing it again as is hanging lol but boost will be fun Quote Link to post Share on other sites
Glanza-Ben Posted February 9, 2014 Author Share Posted February 9, 2014 (edited) Just ordered a couple adaptors for turbo coolent lines to make them an8 and ordered the hose adaptor Aswell Edited February 9, 2014 by Glanza-Ben Quote Link to post Share on other sites
Glanza-Ben Posted February 15, 2014 Author Share Posted February 15, 2014 Started her up today and runs.perfect Quote Link to post Share on other sites
littlegreenmonster Posted February 15, 2014 Share Posted February 15, 2014 Wey hey, well done bud Quote Link to post Share on other sites
jimmymac101 Posted February 15, 2014 Share Posted February 15, 2014 Good work boss wack some progress pics up James Quote Link to post Share on other sites
Glanza-Ben Posted February 15, 2014 Author Share Posted February 15, 2014 Quote Link to post Share on other sites
