1000cc+ bike oil coolers possibilities
well as we all know starbos are 1.3
but suzuki, honda cbr etc bikes are 800/ 1000cc plus,
well my thinking is could we use a stock bike oil cooler for everyday use on a gt/glanza as mocal etc oil coolers are designed for more track day use rather than daily
just a thought ????
something simular to this it was taken from a suzuki GSXR 750
KGrHqFqMFGBW3-LMBRjP0gg60_12_zps8d691b86
Edited by russ78
you shouldn't run a oil cooler on the road without a temperature valve on it. [sorry dont know the technical name] reason being if you constantly cool the oil it'll run too cold and your oil wont get to its correct running temp. can actually cause more damage than good.
just a quick question, why do you actually want to run one if its not for track use?
I will be running a fully forged TD05 16G at about 1.5bar 300BHP+ in the next couple of weeks so just platying it safe really buddy 8)
Should work fine. Here is something to think about. guys over on TGTT, are running 4a-fe oil coolers.
I would personally run a temp sensor first and see what it gets too. If the oil temp doesn't get to 115 degree's it would be a waste really, and I doubt you'll ever get to that kinda figure unless you were tracking the car where the throttle is constantly on and off. Feathering the throttle round town and a quick blip here and there will not cause you any trouble.
You can buy oil cooler or transmission coolers in lots of sizes so just get a small one ie 10row and definitely get a thermostat, inline stats seem to be better though, with a thermostatic sandwich plate my oil still takes ages to heat up and needs provoking to run at a proper temperature. I've not even got the cooler connected now.
