Matt1878 Posted August 28, 2013 Posted August 28, 2013 (edited) Well as you guys know I drove my second Glanza home 70 miles yesterday and it drove perfect.. Went to go back out in it yesterday and it started up but was very very lumpy, As though it was only running on 3 cylinders.Turned it off, fired it up again and had the same problem... Then all of a sudden it cut out and wont start at all now. Its turning over but not firing at all. Its not the immobilizer as I thought I could have just been a bit of a retard with new alarm but I'm not. I've taken the dizzy cap off, cleaned it out. Changed the HT leads for a spare set and also swapped the king lead for a different one. All with no change. Any help on this is appreciated guys... Edited August 29, 2013 by Matt1878 Quote
mikey4410 Posted August 28, 2013 Posted August 28, 2013 Do u have fuel present (going into cylinders) do u have a clean spark ? Quote
Matt1878 Posted August 28, 2013 Author Posted August 28, 2013 Do u have fuel present (going into cylinders) do u have a clean spark ? I can certainly smell fuel in the cylinders mate yes. Will be checking for a clean spark when I've got some one with me to turn it over in a short while Quote
iamlegend Posted August 28, 2013 Posted August 28, 2013 great start to new owner ship thats starlets for you haha Quote
Matt1878 Posted August 28, 2013 Author Posted August 28, 2013 great start to new owner ship thats starlets for you haha Yes! I wouldn't mind but the engine is totally stock! Quote
Socks Posted August 28, 2013 Posted August 28, 2013 great start to new owner ship thats starlets for you haha Not Really..... A Cars History, how its been treated effect that massively... There certainly one of the most reliable motors out there on the roads even today... imo... Quote
yaristurbo Posted August 28, 2013 Posted August 28, 2013 temp sensor wire snapped right hand side of block? one facing bulk head? Quote
Idrees Posted August 28, 2013 Posted August 28, 2013 This has completely baffled me. It ran absolutely perfect so I doubt it's a major fault. I did about 150 miles in it over this weekend alone and it was perfect so I'm scratching my head over this. Plugs have done about 1500 miles so unlikely to be those, it may be worth changing them just in case though. If you want to check for fuel just remove the rubber hose on the fuel return pipe and see if fuel comes out of it when you turn it over. Quote
Matt1878 Posted August 28, 2013 Author Posted August 28, 2013 Me and you both iddy! Really confusing one!... Will go over everything tomorrow on my day off.. Quote
daniel_g Posted August 28, 2013 Posted August 28, 2013 Just clean the plugs then if they are new, oil or dirt or water might have made its way in. Got good earth straps in the bay ? Quote
Snow Posted August 29, 2013 Posted August 29, 2013 checked the fuses? could be something as silly as that? Quote
Matt1878 Posted August 29, 2013 Author Posted August 29, 2013 checked the fuses? could be something as silly as that?Checked man.. All fuses are fine, ignition etc Quote
Matt1878 Posted August 29, 2013 Author Posted August 29, 2013 Right, I have fuel and I have spark. Please someone put me out my misery! Quote
JayJ Posted August 29, 2013 Posted August 29, 2013 (edited) Ecu error codes? Compression test? Edited August 29, 2013 by JayJ Quote
Matt1878 Posted August 29, 2013 Author Posted August 29, 2013 did you check the temp sensor?Ah shit no.. Where is this!?earth issue, maybe bad fuel??How do you mean bad fuel?I'm thinking its an immobiliser issue.. Loose wire or something Quote
yaristurbo Posted August 29, 2013 Posted August 29, 2013 right hand side of head facing firewall on thermostat housing Quote
yaristurbo Posted August 29, 2013 Posted August 29, 2013 Ah shit no.. Where is this!?How do you mean bad fuel?I'm thinking its an immobiliser issue.. Loose wire or somethingtheres only fuel and spark and cranking that immobilisers stop they cant control anything else, if theyre present its something else Quote
daniel_g Posted August 29, 2013 Posted August 29, 2013 I had a similar issue a few months back in work, turned out the timing belt had skipped a few teeth and obviously preventing it from starting. Worth a check atleast. Quote
Matt1878 Posted August 30, 2013 Author Posted August 30, 2013 I had a similar issue a few months back in work, turned out the timing belt had skipped a few teeth and obviously preventing it from starting. Worth a check atleast.All temp plugs seem to be fine. Will have up check the timing/belt issue Quote
FrancyGlanza Posted October 1, 2013 Posted October 1, 2013 Ino the this is an old post but have you found the problem since? haven the very same problem with mine and tried everything but no luck Quote
