Thank you... didn't know the whiteline will rust. I have the rear anti roll bar and there is no rust.
where can I buy a rsr panhard rod? can't find one.
@stu: will get problems with the mot.
Edited by motion
Nothing wrong with the whiteline ones, I've had ones before and put denso tape on them, just like new when taking them off a few years later...They are all the same.
Denso tape is amazing for preserving things in harsh environments, I used to use this on every hydraulic hose connection where I used to work as it was in a harbour, years old and as new…
Rear ARB and other whiteline parts also rusts that fast? Maybe its the climate in the uk? :-)
I have a rear anti roll bar since 4 years and there is not a bit of rust. ....but i must say i dont drive it thru the winter.
i remember the whiteline ARB nuts and bolts were bad quality these were wobbleing on each other so i changed them all to German quality bolts XD lol!!!
How is it about the nut of the panhard rod? Also shaking on the thread?
Edited by motion
I've had both Ultra Racing and Whiteline. The your joint is in the middle of the bar which creates more flex, it is also thinner material. The Whiteline bar is noticeably stiffer. It's no secret that the paint is crap on Whiteline though. If it gets bad enough I will just repaint.
  • 2 years later...
i just ordered a cusco panhard rod brand new from RHD-Japan £100 inc delivery via DHL.
It will be coated with many layers of laquer when it arrives to stop any rust.
