Ollieh17 Posted November 13, 2013 Posted November 13, 2013 Noticed water in the back after stripping it out?!?! Any idea where it could be coming from, already removed grommets and put sealant on them already? Quote
fremyjay Posted November 13, 2013 Posted November 13, 2013 ive had the same sitting behind my rear passenger light, keep drying it up and selaed everywhere still cant seem to find it Quote
daniel_g Posted November 13, 2013 Posted November 13, 2013 I had it in my old GT, i reckoned it was coming in the rear windows because it felt that they were never fully shut. Never got round to fixing it though. Tiny puddle in the 85 boot aswell ghrrr :/ Quote
Ollieh17 Posted November 13, 2013 Author Posted November 13, 2013 Is it likely to cause alot of problems? Like rust etc? Quote
daniel_g Posted November 13, 2013 Posted November 13, 2013 If you leave it sitting there then yeah it'll eventually rust. For now ive just taken the grommet out because my car is off the road but i'll need to look into it.Check all around the rear lights, bet it'll be comin in through there. Quote
morgey Posted November 13, 2013 Posted November 13, 2013 not quite the same but my bother had a crx that was leaking, he had to cut a few little notches out the bottom of the rubber seal around the boot to let the water out of it, other wise it filled up and leaked inside the car. might be something to consider Quote
Ollieh17 Posted November 13, 2013 Author Posted November 13, 2013 Will have a look at the weekend...explains the car getting so fogged up Quote
AdamB Posted November 14, 2013 Posted November 14, 2013 Theres some rubber grommets behind the rear lights, its those that leak generally. Quote
Ollieh17 Posted November 14, 2013 Author Posted November 14, 2013 I had a quick look and looks like its coming from under the rear plastics by the drivers side rear window? Suppose that could be fed from the rear light. Will check out these grommets and put some extra sealant around them. Quote
AdamB Posted November 14, 2013 Posted November 14, 2013 (edited) You can tell if its coming from the light cluster. If you look in the boot under where the light sits, you can see the rubber grommet, it kinda thins out to a point where it gets pushed through. Mine had water/droplets on the tip of this rubber. If its coming from the window area I would probably guess its a poor sealing rubber on the window, although I would expect the water to head down into the inner arch or the rear seat well if it was coming from there. Edited November 14, 2013 by AdamB Quote
jellybaby Posted November 14, 2013 Posted November 14, 2013 tip sit in boot get a friend if possible to spray the back of the car with a pressure washer or hose pipe and see where it coming in from Quote
jayc-glanza17 Posted November 14, 2013 Posted November 14, 2013 I had this issue two years ago in my glanza..its the rear passenger lights, the rubber seal leaked, put a new set of lights on I found down scrappy, and hasn't leaked since. Quote
chrisdeadcell Posted November 20, 2013 Posted November 20, 2013 Try taking the rear lights out and buying a tube of black silicone sealant from a motor factors or halfrauds, Clean up the original seal and the paint where the light seal pushes up to the car. Then on the original seal put a even amount of silicone around, and refit your lights. Quote
Ollieh17 Posted November 20, 2013 Author Posted November 20, 2013 Tried everywhere with a hose...no leaks. Turned out it was coming up through one of the grommets in the back, so re siliconed that and alls okay Quote
Gainzy Posted November 21, 2013 Posted November 21, 2013 Buy some masking tape and stick it in places where you think it's getting wet first bit that gets wet trace it back that's what I did Quote
Liam_D Posted November 21, 2013 Posted November 21, 2013 Mine slighty lets water in through the drivers rear light unit somewhere? Quote
Glanza-Ben Posted November 28, 2013 Posted November 28, 2013 I got this, just drill a hole in the boot then it runs out job done Quote
