Basically re-shelling into a 96 spec shell but the floor pan on both sides (where the seats go) are bent/sagging down considerately! I have my 99 shell here with a perfect floor, shall I cut out the damaged part and get it properly welded in?
Any help on this would be appreciated as its holding my build back :(
Cheers
Nik.
Put some pics up..I don't under how they are sagging down, no way to heat shrink the area and bash the sags up? Would use cutting as a last resort
Loool maybe? Haha who knows :( must of taken some force as it's solid! But I don't understand how it can be even on exactly both sides? Just need this fixed mann
Edited by nikhilkamdar12
Nahh hasn't been crashed. There is no other evidence of anything out of place . everything lines up perfect on it. Plus it's even exactly on each side, plus the guy I got it from was gonna rebuild the entire thing and painted the entire engine bay and interior. So I don't think it's been in a crash but it needs to be fixed defoo
easy enough to fix, get someone on the inside to hold a block of wood against the floor while you smack the outside with a hammer, continue to do this till its all flat then underseal, job done! :D
Edited by Ryan-11
that doesn't look good looks like the chassis channels are bent I think you may go find another shell don't think that going to pass
an mot even if you jack it back up into place
