turbo-fever Posted July 14, 2016 Share Posted July 14, 2016 Where did you get it done bussey ? Quote Link to post Share on other sites
jayc-glanza17 Posted July 14, 2016 Share Posted July 14, 2016 Glad your happy man..Did always feel the 28 was a tad large..keep it matey..See you around soon Quote Link to post Share on other sites
Bussey Posted July 14, 2016 Author Share Posted July 14, 2016 Where did you get it done bussey ?Redline mate Glad your happy man..Did always feel the 28 was a tad large..keep it matey..See you around soonCheers mate, catch you soon Quote Link to post Share on other sites
Broony Posted July 15, 2016 Share Posted July 15, 2016 Love this, sick of seeing huge turbos on starlets like!! I get that a bigger turbo gives you a higher scope for power but its all about drivability imo. Quote Link to post Share on other sites
Bussey Posted July 15, 2016 Author Share Posted July 15, 2016 Love this, sick of seeing huge turbos on starlets like!! I get that a bigger turbo gives you a higher scope for power but its all about drivability imo.Bang on mate !This setup feels like a CT9 with a massive kick up the ass, I love it Quote Link to post Share on other sites
kbond Posted July 15, 2016 Share Posted July 15, 2016 It's a great turbo I run a hybrid tf035 at 1.4bar 266hp and it spools less than 500rpm later than my mates ct9!Looks great though bud! Quote Link to post Share on other sites
ReeceGolliker Posted July 15, 2016 Share Posted July 15, 2016 (edited) Looks mad! Spools well too! I'm starting to think the TF is going to replace the TD04 as the natural upgrade haha Edited July 15, 2016 by ReeceGolliker Quote Link to post Share on other sites
TimD Posted July 15, 2016 Share Posted July 15, 2016 What wastegate do you run on this? Quote Link to post Share on other sites
turbo-fever Posted July 15, 2016 Share Posted July 15, 2016 Bussey need a spin in this, see what all the fuss is about Quote Link to post Share on other sites
Bussey Posted August 3, 2016 Author Share Posted August 3, 2016 (edited) Cheers everyone Car lasted 4 days before another problem had cropped up. She won't boost over 0.5 bar and the external wastegate won't open up.So far, waste gate has been rebuilt with genuine new diaphram and seats all checked. All new vaccum lines, turbo removed and checked over, the whole pressure system smoke checked. Boost solenoid checked over and works fine. So yeah, at the moment it has myself and some very clued up people extremely confused. In the mean time new exhaust and some pictures of when she was last out about 2 weeks ago. Centre silencer is now gone. The only silencer in the system is now the one pictured one the left, and that's at the rear. Edited August 3, 2016 by Bussey Quote Link to post Share on other sites
Ollieh17 Posted August 3, 2016 Share Posted August 3, 2016 Check airfilter isnt blocked. I had a problem where turbo wouldnt boost. Tried everything, turned out filter was blocked Quote Link to post Share on other sites
Bussey Posted August 3, 2016 Author Share Posted August 3, 2016 Check airfilter isnt blocked. I had a problem where turbo wouldnt boost. Tried everything, turned out filter was blockedIt currently hasn't got one on mate, thanks though Quote Link to post Share on other sites
00joeindastarb0 Posted August 3, 2016 Share Posted August 3, 2016 Mesh can restrict it or have you removed any form of filter to eliminate that Quote Link to post Share on other sites
Bussey Posted August 3, 2016 Author Share Posted August 3, 2016 Mesh can restrict it or have you removed any form of filter to eliminate thatNo filter is currently on the car mate Quote Link to post Share on other sites
Phil Posted August 3, 2016 Share Posted August 3, 2016 we had a external wastegate (that was genuine) that needed piped up in a way that seemed incorrect to allow it to make boost. was a fella on here with a red glanza V Phil Quote Link to post Share on other sites
Bussey Posted August 3, 2016 Author Share Posted August 3, 2016 we had a external wastegate (that was genuine) that needed piped up in a way that seemed incorrect to allow it to make boost. was a fella on here with a red glanza V PhilBut it worked fine before mate, then the boost just suddenly crept down, literally no reason behind it either! Quote Link to post Share on other sites
5e colin Posted August 4, 2016 Share Posted August 4, 2016 small crack appearing in diaframe from gate i think ?? Quote Link to post Share on other sites
TimD Posted August 4, 2016 Share Posted August 4, 2016 Surely if the wastegate wont open you'd be getting over boost? Quote Link to post Share on other sites
Bussey Posted August 4, 2016 Author Share Posted August 4, 2016 Surely if the wastegate wont open you'd be getting over boost?You would think so! obviously the boost is bleeding off somewheresmall crack appearing in diaframe from gate i think ??Wastegattes been fully rebuilt and checked by Owens mate Quote Link to post Share on other sites
TimD Posted August 4, 2016 Share Posted August 4, 2016 (edited) What spring do you have in it? The only thing that is controlling boost is the wastegate, I reckon it's your boost controller. Edited August 4, 2016 by TimD Quote Link to post Share on other sites
Bussey Posted August 4, 2016 Author Share Posted August 4, 2016 What spring do you have in it?The only thing that is controlling boost is the wastegate, I reckon it's your boost controller.It's 0.65 bar, was new 2 months ago. Currently it won't boost past 0.5, hence why the screamer isn't opening up Quote Link to post Share on other sites
H_D Posted August 4, 2016 Share Posted August 4, 2016 maybe try removing the boost controller and run off spring pressure, see if that helps at all? Quote Link to post Share on other sites
TimD Posted August 4, 2016 Share Posted August 4, 2016 (edited) You need to try a bleed valve or something to see if you can get some more boost out of it. The wastegate is doing it's job in that you aren't seeing overboost. You might no be getting .65bar, but that could be down to a tired spring. Edited August 4, 2016 by TimD Quote Link to post Share on other sites
Bussey Posted August 7, 2016 Author Share Posted August 7, 2016 So this happened Quote Link to post Share on other sites
00joeindastarb0 Posted August 8, 2016 Share Posted August 8, 2016 (edited) Have you checked your timing? Edited August 8, 2016 by 00joeindastarb0 Quote Link to post Share on other sites
