Glanzacoley Posted October 13, 2014 Posted October 13, 2014 All standard internals guys new rings etc? Quote
Glanzacoley Posted October 13, 2014 Author Posted October 13, 2014 Guess that's not right is it? Quote
GlanzaJ Posted October 13, 2014 Posted October 13, 2014 (edited) I've had this arguement with my old man for a long time , he says take it easy with seems logical however i heard people who smash there car straight on the dyno Edited October 13, 2014 by GlanzaJ Quote
patman Posted October 13, 2014 Posted October 13, 2014 Surely doing it hard would spins bearing etc no? Quote
5e colin Posted October 13, 2014 Posted October 13, 2014 i am old fashioned an i dont rev above 3000rpm while driving the first 500 miles then steadily increase the rpms till 1000miles then hammer it dont forget when u first start her up and she reached operating temps to rev her hard for a second x8 or so to settle the rings if you dont it could happen that the bores/rings glaze ( never bed in propper ) and seep to much oil !!! Quote
amatthews45 Posted October 13, 2014 Posted October 13, 2014 Wouldnt smash it if your running on breaking in oil. Would do at least 300 miles then service it then put the hammer down Quote
akyakapotter Posted October 13, 2014 Posted October 13, 2014 Once the pistons have gone up and down a few times Kick its teeth in you don't see people who get new cars bedding cars in they just drive take it back to the dealer after 500 miles for the first oil change Quote
5e colin Posted October 13, 2014 Posted October 13, 2014 Once the pistons have gone up and down a few times Kick its teeth in you don't see people who get new cars bedding cars in they just drive take it back to the dealer after 500 miles for the first oil change there not new there all tested in the factory !!!! Quote
akyakapotter Posted October 13, 2014 Posted October 13, 2014 there not new there all tested in the factory !!!!Ok they are hooked up to a dyno then smashed round a test track and put through there paces Quote
DevonGT Posted October 13, 2014 Posted October 13, 2014 i am old fashioned an i dont rev above 3000rpm while driving the first 500 miles then steadily increase the rpms till 1000miles then hammer itdont forget when u first start her up and she reached operating temps to rev her hard for a second x8 or so to settle the rings if you dont it could happen that the bores/rings glaze ( never bed in propper ) and seep to much oil !!! Pretty much the way I've always done it. Quote
daniel_g Posted October 13, 2014 Posted October 13, 2014 The moto guy way.Kick the fuckin cunt right out it Quote
Lew91 Posted October 13, 2014 Posted October 13, 2014 What sort of noises should you hear on the first start up? Any rattling or knocking? Or just start up smooth and steady? Quote
Ryan-11 Posted October 13, 2014 Posted October 13, 2014 I boosted mine straight away, ran it pretty hard, had it on the dyno after about 300 miles, all was and is still good Quote
AdamB Posted October 15, 2014 Posted October 15, 2014 (edited) You don't need to "kick the shit out of it" to run a motor in! All you need to do is load the engine using high gears and pulling the car up hills/gradients etc. But yes don't be a pussy with it, load it up but you don't need to rag it to the red line, 4500-5500rpm will be fine.I wrote a guide on here a little while ago, do a search for it. Edited October 15, 2014 by AdamB Quote
Aamir Posted October 15, 2014 Posted October 15, 2014 All you need to do is load the engine using high gears and pulling the car up hills/gradients etc.^^ this, put the engine under strain to allow the piston rings to set in. If you don't do this your car will smoke on idle? Correct me if I'm wrongAamir Quote
Stu Posted October 16, 2014 Posted October 16, 2014 After a couple of heat cycles and you've dropped the start up mono weight oil out its best to not pussy around and have plenty of accel/decel so the rings bed in just don't rev it out too aggressively ie to redline and try not to run at the same rpm or idle for too long. If you nana it you'll glaze the bores and the rings wont bed in. I usually run 50-100k then drop the oil again then start progressively raising the boost/rev limit from there. A guy I know over here builds very high level RB30/32's and hes starting to lean on his new engines after only 30mins or so and he's yet to have any failures/issues and his engines are used all over the world setting all sorts of records. Quote
Turbo Goose Posted October 16, 2014 Posted October 16, 2014 http://www.mototuneusa.com/break_in_secrets.htmTake a read here very useful Quote
ali_legend Posted October 16, 2014 Posted October 16, 2014 Guys in the states fully build their motors and just thrash them once on road. Everyone in the uk seems to be experts and know exactly what to do lol Quote
AdamB Posted October 16, 2014 Posted October 16, 2014 (edited) ^^ this, put the engine under strain to allow the piston rings to set in. If you don't do this your car will smoke on idle?Correct me if I'm wrongAamir If the rings don't bed in or the bores are glazed then there will be excessive crankcase pressure and the motor will be hugely down on power. But yes there will be a lot of smoke out the breather.Guys in the states fully build their motors and just thrash them once on road. Everyone in the uk seems to be experts and know exactly not what to do lolEdited lol Edited October 16, 2014 by AdamB Quote
