Jordk Posted December 4, 2014 Posted December 4, 2014 I finally got my car mapped fully today. Im running a fully forged 4efte with a gt28 race tech set up. Also has a zisco fuel rail 550cc injectors, zisco plenum intake manifold, fmic etc etc. It made 253bhp at 1.6 bar. I guess putting a bit more boost through it would get me more but what sort of boost is plausible? 2.0bar pushing it? I'll get a photo of the graph up tonight. Quote
Ollieh17 Posted December 4, 2014 Posted December 4, 2014 253 seems low for that set up? Thats like td04 at 1-1.2 bar power. That at the wheels? Quote
Jordk Posted December 4, 2014 Author Posted December 4, 2014 Nope this is at the engine. Quite concerned. The mapper did say he was keeping it safe but still... Quote
Aamir Posted December 4, 2014 Posted December 4, 2014 Nope this is at the engine. Quite concerned. The mapper did say he was keeping it safe but still... Was going to say 253bhp at the wheels is pretty shit for a Forged engine with your mods thought It would have made 300bhp atleast.. Aamir Quote
Aamir Posted December 4, 2014 Posted December 4, 2014 Especially at 1.6 bar? TD04 Hybrids make over 300bhp at 1.2 bar dont they? Aamir Quote
daniel_g Posted December 4, 2014 Posted December 4, 2014 Who mapped it and on what ECU ?Something must be restricting it surely thats very low. Quote
Jordk Posted December 4, 2014 Author Posted December 4, 2014 (edited) This is what I thought. The mapper is good. He mapped mark1991's gt to over 350bhp on a td05 set up! Confused as to why it made so little :/It's mapped on emu by Wallace Performance in Aberdeen. And boost is controlled by an Apexi AVCR Edited December 4, 2014 by Jordk Quote
daniel_g Posted December 4, 2014 Posted December 4, 2014 Ahh was it Matty ? Hes ment to be spot on, know a few lads that have taken their motors up there.As for the power, the figure looks restricted somewhat. A GT28 @ 1.6 bar should be over 300 easily.Whats the history of the engine ? Id do a leak down test on it to see if its loosing compression.Take it maintenance parts like fuel filter, plugs etc are all in good condition ? Quote
GlanzaJ Posted December 4, 2014 Posted December 4, 2014 Mmm obviously something not quite right there mate, i made 239bhp on a td04 at 0.9 bar Quote
_shaun_ Posted December 4, 2014 Posted December 4, 2014 Am running just under 300bhp at 1.2bar on a hybrid gt28 so something is certainly untoward there Quote
Ryan-11 Posted December 4, 2014 Posted December 4, 2014 what gt28 are you using? what exhaust? my old exhaust was really restrictive Quote
mikey4410 Posted December 4, 2014 Posted December 4, 2014 im sure an exhaust being to small wouldnt help the matter at all.but I would do a comp test for sure Quote
Jordk Posted December 4, 2014 Author Posted December 4, 2014 Yeah it was Matty that mapped it. Didn't see him when I went to collect the car so I emailed him just awaiting response. The exhaust system was part of the racetech set up. 2.5" straight back from turbo to back box. Nothing too restrictive there. Here's the print outs. Quite linear graphs other than the AFR's Quote
_shaun_ Posted December 4, 2014 Posted December 4, 2014 A 2.5 straight thought I still woulda thought you would have for over 250. Most people pull easy 250-260 on japspeed exhausts. Best speak to the tuner and see what he thinks Quote
Jordk Posted December 4, 2014 Author Posted December 4, 2014 All service parts and most of the parts on the car are brand new. The engine was from Hawwy on here. He run a td04 set up from what I believe and not for many miles. I'll do a compression test at the weekend and see what I get. Was done a while ago when I first had it running. The mapper had to adjust the timing as it was out by a tooth. This could maybe have caused the problem? Quote
Jordk Posted December 5, 2014 Author Posted December 5, 2014 Well after hearing back from the mapper his only concern was that my gearbox and diff sounded like shit and he didn't want to put the boost up in case it shat itself... Any good places for a box/diff overhaul? Quote
Socks Posted December 5, 2014 Posted December 5, 2014 Why not just ask you that while he was mapping it? :s Quote
iamlegend Posted December 5, 2014 Posted December 5, 2014 yea like others say that is not good... mine made 283 at 1.4 bar hmmmm tdo4 tubby... strraaanngeee Quote
Jamie_VF22 Posted December 5, 2014 Posted December 5, 2014 At that boost it should be well over 300+ dude Quote
TurboTobz Posted December 5, 2014 Posted December 5, 2014 All service parts and most of the parts on the car are brand new. The engine was from Hawwy on here. He run a td04 set up from what I believe and not for many miles. I'll do a compression test at the weekend and see what I get. Was done a while ago when I first had it running. The mapper had to adjust the timing as it was out by a tooth. This could maybe have caused the problem?hawwy? Oh god. Quote
Jordk Posted December 5, 2014 Author Posted December 5, 2014 Why not just ask you that while he was mapping it? :sI thought he would've to be honest. Spoke to him today he said he kept it low because of the box but even still at that boost surely it would've made more unless he might've restricted it in some way to keep the power down (although I thought that would've been controlled by how much boost he run). He also said about looking into getting a standalone (power fc) instead of the emu as he says it'll make a huge difference to the car. But again, loads of you run emu making way more power than that. It drives well and pulls hard on boost but still doesn't give much of an explanation. I'll check the engine compression in the morning when I'm at my lock up. Quote
WallaceGlanza Posted December 5, 2014 Posted December 5, 2014 My box blew up and locked on the dyno with Matty at the wheel.... he probably didn't fancy that type of ride again! How does it feel on the road? That's a new dyno Wallace have so may not give the same over optimistic figures! Quote
Jordk Posted December 5, 2014 Author Posted December 5, 2014 My box blew up and locked on the dyno with Matty at the wheel.... he probably didn't fancy that type of ride again! How does it feel on the road? That's a new dyno Wallace have so may not give the same over optimistic figures!Haha he told me about that! Fair enough I'd rather not have to fork out for more than u bargained for!Feels ok on the road a tad noisy and whirrs a bit. New box sounds like the best plan. Map wise he said he didn't push the fueling/timing due to the box being ropey so it's a safe map. Quote
