well.. when i took mine off (5efe mind you, nothing diff though) it was covered in oil underneath and i changed the little gasgets (one was cracked so swapped with original rocker cover gasget)
but by the way, does it really matter if you spray the cam cover without masking up?
  • Replies 446
no you dont your not taking the whole head off...only the cover for the cams..so its fine...ill put a pic up of what its like underneath tomorrow for you if you want?!
Rob
Yeah yeah! :(
Do it :)
Good bit of learning for me :(
@ Si, yeah but it didnt work that well...so after i just went a scrapped it off really carefull, then heated the edges so the paint 'flexed' a little and stuck good...so hopefully it wont peel..
Cheers idrees...just fitted it back on, this is how it looks:-
As im sure you can see, the paint hasnt gone on totally even, but in really like, its given it a quite cool effect...may leave it, or may give it a couple of coats...there are a few rain sports on the photo, not screw ups in the paint by the way :):(
And ive just released i forgot to take the photo JAG :( really sorry man...but basically when you take it off...there is some cam shafts with a bit of oil...nothing fantastic...
Rob
Dont worry man
Its all good il go it alone when i get there :(
Looks damb sexy :)
Think idrees' point was what my dad was on about?
if he said head gasket its a completely different thing...
You dont need to change it..as its a rubber seal, just make sure you dont rip/tear it tho..otherwise you will...
It may be coming of in a couple of days, to have another lick of paint..if so if will defo. take a pic :(
Rob
while you peeps are on the subject of gasgets and covers and stuff...
would it be safe to do a straight swap between two rocker covers, both off of a 5efe so its not gonna be different, just im going to put the red and black one on the galli and use the other one to spray for JWK.. just i like both my ideas and have another car i can fit it to :)
would it be safe to do a straight swap between two rocker covers, both off of a 5efe so its not gonna be different, just im going to put the red and black one on the galli and use the other one to spray for JWK.. just i like both my ideas and have another car i can fit it to :blink:
Cant see why not :huh:
Cheers for posting the pic rick..!
Little update...the headlights, and 'S injectors + fuel rail have arrived from phil! Cheers mate!
Is there any difference in the fuel rails. or are they the same?!
Thanks!
@ Idrees, phil told me they were from you...still in the box, with your name on the side etc. ;)
^ i know mate...i realised i could of splashed out just, but had already bought them off nangle..and the car needs a gearbox, which is more important than crystals :huh:
Like i said,...couple of months, if you can still get hold of some :blink:
Rob
Another little updatings...As si is changing his spec big time...he had his SAFC II hanging around...so ive jacked that and been doing some of the wiring on that today, and couldnt wait for everyone and there gearboxs so just ordered one from somewhere...was meant to turn up to day but hasnt :lol::)
Pics of the installated safc to follow tomorrow ;)
Rob
Been wiring in the SAFC II yesterday and today...bit gay as i thought the n/a would have a Knock Sensor...and it doesnt ;) If im not mistaken :)
Also Rich gave me this corolla ECU, to see if it will work...havent tried it yet as the battery is flat...once the new gearbox is fitted, i will try..:lol:
Some Pics -
Rob
^ Cheers mate...hope so, due to the higher rev limit..and specially if me a scutchings get these twin TB's working in the future..
Does anyone know, the exact rev limit on the corrola ecu ?!
Thanks!
