I've had the car over a year now and lots has changed since I got it. I'll add pics of where it started to where it is now over time so it makes for better reading.
  • Replies 141
  • Created
  • Last Reply
Top Posters In This Topic
So this is a 1 uk owner before me. I bought it off a friend who imported it and done a couple of bits to it but was his daily.
Spec:
Stock engine running CT9
HKS air filter and bov
Standard exhaust
BC coilovers
15'' sparco crimson wheels
Greedy oil cooler
Oil pressure & boost gauge
Greedy turbo timer
TRD clutch
LSD (cusco)
Edited by _JT_
Sweet base! Looks great :)
Cheers man, she is a minter
Where did you get the exhaust system from?
Sumopower, was on a golf trip up that way and picked it up on my way home
Fitted 1/2 size rad from idworkz, did have some red samco coolant pipes ready to go on but the outlets on the rad were huge so had to sell them on and got some bigger ones from Mike @ TD
Those rad fans are THE most fiddly things to install. Destroyed the first rad due to it coming loose so the next one got cable tied on by pulling them through the rad viens and back through. Haven't moved an inch since.
Gave the front strut a splash of Milano red and a few pipes got changed
Edited by _JT_
So this is a 1 uk owner before me. I bought it off a friend who imported it and done a couple of minor bits as it was his daily but it mainly came across from Japan with this spec:
Standard exhaust
BC coilovers
Greedy oil cooler
Greedy turbo timer
TRD clutch
LSD (cusco)
TRD Antiroll bar
Rear strut brace (unknown brand)
Braided brake lines all round
Next on the list was the a front mount & air filter relocation from Dean @RW
The oil cooler & lines kept getting in the way of everything but I wanted to keep it so undone it and rivoted it along a few inches.
Once all done took it for a spin before fitting the bumper and all good, loved to sound of the air whistling through the new intercooler pipes!! Also what looked like a previous bonnet repair was starting to appear so decides to get it painted and changed it to black
The new air filter silicone coming off the CT9 was a tight fit due to the oil cooler pipes
Also fitted a TD adjustable actuator set at 1bar.
Also done a gearbox oil change. Took me 2 goes at getting the right type. First lot that went in made the diff very clunky so took that out straight away and found Millers 75w90 fully synthetic done the trick.
New plugs & leads went on next
That front strut brace is a carbing item not sure if you know, but they fetch a good amount the 3 point ones.
Cheers fella I didn't know that
Lovely example. Same gauges as mine, did you have any difficulty wiring your's in?
John
Thanks mate, wiring was fine fella.
Next up was sorting the front bumper, I needed a fair bit of cutting & smoothing off but happy with what my mate done.
20150128_160354_RichtoneHDR_zpsf405noem.
20150207_153039_RichtoneHDR_zpsqawdd076.
New rear lights off a member & new 255LPH TD fuel pump was next up. Man those things look scary to install but not too bad
JDM Saturdays !!
Decided to drop a new clutch & lightweight flywheel in supplied by TD, with a TD04 not far away decided to get this done now.
When the old clutch was taken out it turns outo it was a TRD clutch, bit annoyed but I don't think it had much meat left on it so all good in the end.
Not sure if this was a stock flywheel or not ??
