Gainzy Posted January 4, 2016 Share Posted January 4, 2016 image hosting freeStock td04 and 1.4 barThat's all anyone should need in a 900kg car fwd lol unless you live on the autobahn Quote Link to post Share on other sites
richardc9052 Posted January 4, 2016 Share Posted January 4, 2016 So with the td04 300 hybrid you should make a bit more towards that 350 mark Quote Link to post Share on other sites
gorganl2000 Posted January 5, 2016 Share Posted January 5, 2016 VF35 if on a budget. GT28 if not i second this Quote Link to post Share on other sites
gorganl2000 Posted January 5, 2016 Share Posted January 5, 2016 stock td04 is just to small for a 5e same as ct9 is to smal for the 4efte tdo4 will drop of top end limiter tdo5 will pull past the rev limiter i get what you mean 5e colin,,,,but from what i observed, the td04/5e combination is very nice for an everyday car...it has a lot of low/mid range...and tails off around 6000/6500rpm which is not so bad if you have stock rev limiter and when i say tails off...the boost drop from the higher setting to about 14/15psi i suppose due to the exhaust housing and turbine wheel but still decent turbo for a street 5e on a budget Quote Link to post Share on other sites
ankers Posted January 10, 2016 Share Posted January 10, 2016 I've been told from a few tuners that a vf35 on a 5e won't get passed 330bhp and on the leaderboard the fastest vf35 is 335bhp. Quote Link to post Share on other sites
AdamB Posted January 10, 2016 Share Posted January 10, 2016 I've been told from a few tuners that a vf35 on a 5e won't get passed 330bhp and on the leaderboard the fastest vf35 is 335bhp. Don't get too strung up on numbers If that's what you're after you're in the wrong game. Quote Link to post Share on other sites
Bean Posted January 10, 2016 Share Posted January 10, 2016 (edited) This was my old 5e runing a rebuilt vf35 on a dta s80. the mapping was never finished and there was still more left in it. on the dyno day my boost controller settings were playing up i cant remember why.I have another for 324bhp on another dyno but i it did read a bit high that one. It was on boost all time, no lag just flat out in 5th all the time with the short ep85 gears. Edited January 10, 2016 by Bean Quote Link to post Share on other sites
gorganl2000 Posted January 10, 2016 Share Posted January 10, 2016 the vf35 is maybe good for about 300/325bhp at 1.5 bar ...which as said before is plenty on a 900kg carits close to the gt28 disco potato in performance...which will also be around the same 300/325bhp areaalso, on a 5e a td05/vf35/gt28 should not be a laggy turbo...if it is, then something is not so right or maybe very low compression build.....these sized turbos should begin spooling around 3000rpm and be at 1.5bar at 4500/5000rpm with a decent tune, engine build and gas...and pull to stock redline same thing with the td05..vf22, etc..........all around the same bhpthere will always be the odd set up which may make a little more if you are hell bent on 350/400bhp i'd suggest maybe the gt30, td05/6 hybrid, etc... as i'm not sure if the gt2871 would get you to 400bhpwith those bigger turbos, you may see an increase in lag Quote Link to post Share on other sites
gorganl2000 Posted January 10, 2016 Share Posted January 10, 2016 This was my old 5e runing a rebuilt vf35 on a dta s80. the mapping was never finished and there was still more left in it. on the dyno day my boost controller settings were playing up i cant remember why. I have another for 324bhp on another dyno but i it did read a bit high that one. It was on boost all time, no lag just flat out in 5th all the time with the short ep85 gears. hey bean, it that 227hp the Wheel HP.....converted to 303Brake HP? was this on a 4wd dyno or did you run the system disconnected? i think i recall you posting the other graph a long time ago...but i could be wrong lol Quote Link to post Share on other sites
gorganl2000 Posted January 10, 2016 Share Posted January 10, 2016 Don't get too strung up on numbers If that's what you're after you're in the wrong game. i must say, that's great advice again such a common mistake though Quote Link to post Share on other sites
Bean Posted January 10, 2016 Share Posted January 10, 2016 Those graphs are from tuning developments on their 4wd dyno dynamics system. Before that your right I ran it 2wd on the other dyno. hey bean, it that 227hp the Wheel HP.....converted to 303Brake HP?was this on a 4wd dyno or did you run the system disconnected? i think i recall you posting the other graph a long time ago...but i could be wrong lol Quote Link to post Share on other sites
ankers Posted January 10, 2016 Share Posted January 10, 2016 Can a vf35 go passed 1.5bar and be safe? Quote Link to post Share on other sites
AdamB Posted January 10, 2016 Share Posted January 10, 2016 (edited) Can a vf35 go passed 1.5bar and be safe? Will be out of its efficiency area, could probably go 1.6 but no more than that I'd say. That's why the Garrett's are better in that respect, they love big boost pressures. Edited January 10, 2016 by AdamB Quote Link to post Share on other sites
gorganl2000 Posted January 10, 2016 Share Posted January 10, 2016 i've done a lot of research on vf and td turbos over the years now....seems 1.5bar is the "recommended" max on the vf35However,,,and caution is advised here...a few sub owners have ran 1.6 - 1.7 bar ...i suppose it will only spike there and bleed back off...maybe give that little extra torque/hp in the mid range i'm not too sure if there will be a difference in the impact of 1.6/1.7 bar on a turbo (vf35 or any other) on a 2000cc vs a 4e/5e i always figured absolute boost pressure is boost pressure regardless ....however, maybe on a bigger engine (2000cc sub in this case) the turbo is being worked harder at the same relative boost pressures on a 4e/5e???...i dont know....maybe someone here with that type of knowledge could chime in Quote Link to post Share on other sites
turbo-fever Posted January 11, 2016 Share Posted January 11, 2016 This is a good topic been wondering TD or VF for my 5e for about 340hp Quote Link to post Share on other sites
ankers Posted January 12, 2016 Share Posted January 12, 2016 What would cams do in a 5e vf35 will they give alot more power top end revs? Quote Link to post Share on other sites
5e colin Posted January 12, 2016 Share Posted January 12, 2016 What would cams do in a 5e vf35 will they give alot more power top end revs? only !!! go for them if your planning on raising your revs ( not a lot do raise ! ) stock cams are pretty good Quote Link to post Share on other sites
Phil Posted January 12, 2016 Share Posted January 12, 2016 (edited) 268degree 8mm lift hereDefinitely laggier than stock but making good power.Regarding the turbo choices Same dyno same day my gt2860rs is very similar to a td04 for lag(Both running the same cams)Only difference is that the td04 is making 300@1.5bar and the gt2860rs is making 370@1.5barPhil Edited January 12, 2016 by Phil Quote Link to post Share on other sites
ankers Posted January 12, 2016 Share Posted January 12, 2016 268degree 8mm lift hereDefinitely laggier than stock but making good power.Regarding the turbo choices Same dyno same day my gt2860rs is very similar to a td04 for lag(Both running the same cams)Only difference is that the td04 is making 300@1.5bar and the gt2860rs is making 370@1.5barPhilThat's nice power I've got everything to go on my car I just need book it in for a forge I'm just asking about cams cause that will be my next step Quote Link to post Share on other sites
ankers Posted January 12, 2016 Share Posted January 12, 2016 Sorry forgot to ask is that the max boost on a gt28 60 rs on these engines? Quote Link to post Share on other sites
Phil Posted January 12, 2016 Share Posted January 12, 2016 Sorry forgot to ask is that the max boost on a gt28 60 rs on these engines? based on reading about on sr20 forums i would say 1.5bar but due to the relatively short duration it will see those levels of boost on a 4e/5e compared to an sr20det i would say pushing towards 2bar im currently running 1.6ish bar but will need scaled back down the gears to insure grip is still there. Phil Quote Link to post Share on other sites
ankers Posted January 12, 2016 Share Posted January 12, 2016 based on reading about on sr20 forums i would say 1.5bar but due to the relatively short duration it will see those levels of boost on a 4e/5e compared to an sr20det i would say pushing towards 2bar im currently running 1.6ish bar but will need scaled back down the gears to insure grip is still there. PhilWhere is your gt28 kit from? Quote Link to post Share on other sites
Phil Posted January 12, 2016 Share Posted January 12, 2016 (edited) It's abit of a mis mash of bits ankersWEPR manifold re trimmed and welded to suit v bandZisco downpipe re cut and welded to suit v bandTial v band housingBottom mounted Stock bottle neck (found on all direct fit aftermarket exhaust) removed Phil Edited January 12, 2016 by Phil Quote Link to post Share on other sites
pockrockgtti Posted January 12, 2016 Share Posted January 12, 2016 I used this combo of 5e with a td04 also had FHE cams, mine made 262whp at 1.4bar. Quote Link to post Share on other sites
gorganl2000 Posted January 12, 2016 Share Posted January 12, 2016 (edited) just a cautionary note here for members, especially those who are not so familiar with dynos and see members projects and dyno results be very careful in comparing dyno numbers...it's really not that simple, they are a lot of variables to consider including the dyno settings, tuners/tuning equipment ability, pump gas quality in different areas, climate, etc...even if assuming relatively similar builds we have a very wide cross section of people on this forum from very different regions....please don't take dyno numbers as the gospel....they will vary significantly across regions and even within the same area in different tuning shops....so one member's 200whp maybe another member's 250whp with the same or very similar set up.....this is how a lot of confusion starts i'd give a few examples...i quickly searched the leader board and see td05/vf35/gt28 can make about 300-360bhp and some td04/td04 hybrids making 250-310bhp on average using pump gas.......... while sometimes other members struggle to make 300bhp and 250bhp respectively with the same turbos using similar set ups where i'm from a td05/gt28rs/vf35/30/28/34 (sized turbo) will net you around 225-250whp on pump gas/meth mix or race gas (maybe around 180-200whp on straight pump gas)........td04/td04 hybrid will net you around 185-210whp on pump/meth or race gas (maybe 160-180whp on straight pump).........because the dyno reportedly reads low, very hot climate, our pump gas quality is reportedly not the best (low octane), etc..... Please...i'm not saying this to discredit anyone's build/results....i'm just trying to help members keep things in perspective and be open mindedthis is why i thought Adamb made a very good point earlier regarding not to get caught up with the numbers Edited January 12, 2016 by gorganl2000 Quote Link to post Share on other sites
