  • Content Count
  1. shameless car whoring.... Second bonnet FTW! ;)
  2. Yourll need to cut chassis rails and mounts to get any 4-5-7a engine in. Along with driveshafts and custom wiring harness The only drop in engines are e series 4e 5e and probably 2e and 3e
  3. Sad day man:( any updates on the new one yet?
  4. How's it sit in the arches like that? Mine rubbed on the front arch linings with 15x6.5 195/50 et 38 with 10-15mm left to drop on bc's
  5. Wasnt one a cat temp sensor not a lambda? Either way thats it
  6. As above Opie Oils, redline, millers, etc I dont believe the OEM LSD requires LSD oil just normal stuff
  7. The H mean high compression or high pressure, its nothing To do with the cams Paul ;) It would have made sence to do both at the same time though as high lift cams work better with higher compression
  8. Haha no worries, They do have have high lift cams too but the comp ratio is 9.8/1 compared to the normal 5efe which is 9.4/1 hence the H in it
  9. Pretty sure its high comp mate. http://www.toymods.org.au/forums/faq/309-toyota-engine-codes-explained.html
  10. Give hawwy and idrees a pm each. One of them might have one
  11. Great work guys, saw the videos on facebook, man that thing shifts Good luck on getting that 9second pass!
  12. Yeah had to get One with Ss, couldn't have a Bz-R and not have it really, will end up costing a bomb eventually but im willing to pay. That blue ones john, spoke to him at jae the last couple of years, his is a pre facelift with the front end swapped. Is a lovely colour when its all polished up, He was moaning that my starlets vvt pulley was loads quieter than his lol
  13. Yeh thats correct unless someone was going to town and doing a high comp boosted build! Tbh the H is only an indication that its a hyped up eco engine anyway (going to get abuse for calling It that) I mean the 4age 20v has a comp ratio for 11.1-1 and that didnt get the H treatment.
  14. Yeah I know man, atm I cant sell any of them, I love my daily corolla just for abusability it just take abuse all day everyday down shitty little tracks and all sorts and laps it up, then the rest if the time is a perfect little run around. Starlet I've had for so long and its like my baby and I know that even though I dont drive it as much as id like I Would miss is so much just because the time and effort I've put into it, id hate to see someone ruin it all! Anyway! Got my first couple of little bits that Wanted, boot badge, rear veiw mirror, ash try holder and a new clock
  15. Years of being about and following threads etc, facebook pages are good too thats where I realised P8 and P9 were used alot more abroad. Silly things really, I cant really call my car an ep91 now as its technically now an ap91 lol
  16. Its people generalizing the series, ep91 and ep95 E is the engine series P9 is the chassis shape/style 0-1-2-5 is a variant within that chassis To say ep90 it covers the P9 chassis, in Europe they use P9 in reference a lot more than we do in the uk. If you were searching in eBay for example. We would use ep91 ep90. They would just use P9.
  17. Gt glanza and na will all fit, you would just have to which all the drums etc over. Gt axles are 10 or 20mm narrower than ep91 axles. This should open your options a bit
  18. Best way to tidy it is rip all the tape off and pull each plug and its wiring out individually then laying it Back where you need it just neater. With a bit more time and effort the injectors can be spun around and the wiring run under the inlet or fuel rail. Also move the sensors off the bulkhead lower down to hide them. With a Bit more time and effort you could make new brakelines and run them lower down so they are out of site, will also clean the bulkhead uo loads.
  19. I would have thought so, IIRC they fit rota slipstreams 15" Should add I've got the 277x25mm kit not sure if youve the same or the bigger or smaller kit?
  20. Theyre nothing to do with the engine at all, they control the abs system
  21. They fit speedlines and my random jdm wheels. Both 15" by 6/both around et38 offset
  22. Not actually wire tucked just neatened up and tied up a bit.
  23. Look in the wiki section on the top bar mate theres a thread describing it with pictures
