2560 -
Cheers Hookie & Jamie
Picked up some new wheels last month. I haven't really had my time to do much to here apart from a wash - got her waxed today though.
gt turbo harmony hill car show
Chris Green replied to simongra's topic in I Spy, Have You Been Spotted?
I would say so, don't know too many GT's running NOS over here. -
The list is getting shorter. Good to see. I'll fire you a link for the washers.
**Postponed** Room 2 Race meet May 2014
Chris Green replied to Chris Green's topic in The Irish Quarter
Postponed due to lack of interest. -
HELP - GReddy/Grex oil filter relocator kit rubber o-rings
Chris Green replied to Nanglebadger's topic in Engines
Got it, will have a look for you today.I never check what's app lol. -
This gets me too. In work everyone is looking a discount or freebies.
Haven't got your message yet mate? -
Cheers dude. Are you hanging on to yours then?
It sure is and costing just a tad over £500, I think it's a bargain. Should be plenty over the coming months.
I may be working Sat, but could call up after, around 1?
Have you got any photos of the part that needs the o-ring? I spotted in work a load of Mazda O-rings for various models, lets face it if size is going to be odd, it going to be Mazda. -
Did these ever arrive? If yes, what did they set you back?
Final bump, going to book on Monday. -
Another selling up thread.. (UPDATED...Been offered moneys...)
Chris Green replied to Zeldoz's topic in Lifestyle General
Get yourself a comfy daily. I bought an IS220d to get me to work and back, but to be honest, I miss my EP being on the road. Yes the Lexus ticks all the boxes as a daily, but you cant wing it in to corners. -
Why gauges in bonnet, because muscle car! Looking good now bud, do tell these plans!
Any one know what make these are??
Chris Green replied to Rob H@RCH Engineering's topic in Alignment & Alloys
Joz's had gram lights and they are still on it. -
Anyone updates dude?
Bumping this up... -
I'm sure they were lol, plan is to get all of these bolts treated either anodized, painted or zinc coated. Really looking forward to getting 100+ bags for Toyota lol. Hopefully will be pulling the engine out this weekend. While I'm waiting for the parts to arrive, alot of cleaning will be done and prep for the engine bay paint.
It is indeed buddy, renewing everything near enough. I want the bay to be factory fresh! Still got a list of aftermarket parts the length of my arm too. Should be taking shape shortly, with that batch of parts en route.
Well, I suppose this is over due an update. I started stripping her when I had a few minutes spare, over the last 3 weeks. To date I have made steady progress with the majority of the engine bay stripped out. Realistically, all I need to do now is remove the drive shafts and mounts and she'll be ready for lifting out. Once the lump is out, I will remove the servo, brake & fuel lines, so the bay will be ready for prepping for paint. Here are a few photos so far. As you can see there ain't much left in there. On to today's updates, I have just spend the best part of 2 hours hiding in my man cave grabbing part numbers & firing them off to Toyota, here's the list & prices. Sump Bung 9034112012 £1.23 Sump Bung Washer 9043012019 £0.43 Sump Bolts (x10) 9011906719 £2.32 Sump Bolts (x2) 9011606151 £1.34 Piston Rings 1301111122 £42.35 Con Rod Bolt 1326510022 £6.80 Con Rod Nut 9017908014 £2.48 Thrust Washers 1101110010 £12.02 Con Rod Bearings 1320410020 £19.18 Crank Bearings 1170410012 £29.54 Crank Pulley Bolt 9010512051 £0.81 Flywheel Bolt 9010510138 £3.92 Timing Belt 1356819116 £22.16 Idler 1 1350511040 £19.44 Idler 1 Spring 9050616050 £0.92 Idler 1 Spring Bracket 1355811050 £2.46 Idler 1 Bolt 9010508123 £1.27 Idler 2 1350311030 £19.44 Idler 2 Bolt 9010508206 £0.66 Oil filter Bolt 9040419007 £2.34 Radiator Brackets (x2) 1650511240 £18.46 Radiator Bolts (x2) 9011906802 £0.50 Radiator Hose Clamp (x4) 9046731003 £3.64 Alternator Adjustment Bolt 9011908053 £0.74 Alternator Bracket Bolt (top) 9163560820 £0.31 Thermostat 9091603046 £8.06 Thermostat Housing nuts (x2) 9017908054 £0.58 Thermostat Housing nuts (x2) 9017906106 £1.34 Thermostat Housing gasket 1632563011 £1.50 Water pump pipe bolt to block 9165160612 £0.36 Water pump clamp (x2) 9046734003 £1.46 Alternator Belt 9936420820 £12.40 PAS Belt 9936420920 £16.18 Timing Cover Colt (x7) 9151160620 £1.96 Gear Box Sandwhich Plate 1135511030 £23.90 Crank Oil Seal Bolts (x4) 9164180616 £1.00 Front engine mount bolt 9010510268 £1.79 Front engine mount bolt 9010510355 £0.43 Front engine mount bolt 9010510380 £0.58 Front engine mount bolt (x3) 9010510266 £1.41 Alternator bottom Mount Bolts (x3) 9011908173 £3.81 Water pump nuts (x2) 9017908054 £0.58 Water pump Bolt 9011908472 £1.64 Exhuast Manifold nuts (x6) 9017910096 £4.92 Intake Manifold bolts (x2) 9161160825 £0.56 Intake Manifold Nuts (x3) 9017908054 £0.87 Head studs (x9) 9213260825 £4.77 Spark Plugs (x12) 9091901176 £14.76 Fuel Rail Bolts (x2) 9011908145 £1.34 Fuel Rail Spacer (x2) 2389111020 £1.94 Dizzy Cap 1910111060 £29.70 Rotor Arm 1910211370 £4.52 Dizzy Bolts 91621B0828 £0.64 Dizzy Cap Bolts (x3) 9009904977 £0.93 Alternator bottom Bolt 9010510102 £0.67 Alternator bottom Nut 9017910016 £0.35 Starter Bolts (x2) 9009904562 £2.46 Clutch Bolts (x6) 9011908026 £1.44 Slave Cylinder Cover 3112612051 £3.87 Slave Cylinder bolts (x2) 9161160822 £0.72 PAS Union Bolt 9040116008 £2.06 PAS Copper Washer 4432712010 £1.25 Misc Bolts 9011906394 £9.00 0.5mm USDM Paseo HG 1111511090 £18.20 Oil Pump 1510011071 £26.72 Complete Engine Gasket Set 411111104 £86.95 Gear box bolt 9161961260 £2.48
NATO Green Sportif - budget kanjo inspired build!
Chris Green replied to micrat's topic in EP91 Progress Blogs
The NATO green is cool, I do like it when someone does something out of the ordinary, Kudos!
