turbo Grant
    2479
  1. I don't see why loads of people like blocking off the dv?? Wow you get chatter lol
  2. Agh that one on the timing belt pulley. I will have a dig about. You dont have to run it tho
  3. The sping that goes inside the gear? I've got a spare you can have
  4. Good work. It will be fine when you turn the key. Just remember to prime it all. Before you start it. It does cost quite a bit when you add it all up. Best not to look at what you spend haha
  5. Its good checking if you have undersized bearing. And within tolerance
  6. Prize for the person furthest away haha
  7. Haha no smoke no poke as they say. Wonder what engine it has. The new diesel engine pump out some cracking torque
  8. I've talked to my boss about plastigauge. Never used it my self. He says it works ok. As for the tolerances they are floating about some were.
  9. Welcome along. I had my starlet for about 3 years till I joined up
  10. Might have to drive down to the forest for this
  11. Put the piston at tdc and have it in gear with the wheels on the floor. Put compressed air down the spark plug hole and it will hold the valves in place with out the dropping into the bore
  12. Be cool to see a vented rear disc set up
  13. I've used the compressed air method a few times. Saves loads of time
  14. Don't see why you can't use the same pump. And you will need abs model washer jets as the are the other way round
  15. Just run it on 20w50 mineral
  16. I might have a stock one kicking about
  17. Isn't that the 2e engine?
  18. I might have one sitting around. Would be from a LSD box tho not sure if they a different
  19. Your will be on the road again befor mine!
  20. I told you putting red bull in the rad won't make it fly
  21. Found the return pipe and will get the temp sensor welded in the manifold next week or so
  22. turbo Grant
    4wd
    Welder and a grinder bit of crafting and you will have 4wd. Just easyer to buy one and use that then you get the running gear without the messing about
  23. Doesn't have to be exactly 38mm I used 51mm for mine and it's been fine
  24. The heated rear screen is easy to wire up on a mk1 just need a switch and a relay. Rest of the wiring is already fitted.
