turbo Grant
  • Content Count
    2479
  1. What you doing on hear then get working! LoL
  2. After the above to cut up to rob the flange. Cheap as possible please
  3. Good job you didn't have the springs on when you drove up the kerb on the way back from getting the paseo. You might have repofiled sill. Was a well funny road trip as usual haha
  4. You want the thermostat in the line out from the filter.
  5. My twins were quite close to my rims. Is a chance they will fit.
  6. Ball joints looked ok no play. N/s boot was a bit split but the o/s was ok. have to try one of my wish bones on and see if that puts the wheel in the same place as the other side. If not then it can only leave you with a bent hub
  7. Does it have an inlet manifold On still?
  8. Best bet if you want propper management is go for a standalone that has alfa-n so the load is tunned of the tps sensor rather than map or you could use a combination of the two. Most good standalones will do that.
  9. Yer that will work but I would say to use fte valve springs and make sure your bottom end is up for it best to have it all ballenced.
  10. The 5e does run out of power towards the red line. Think thats more to do with the super long inlet to give you more torque. Fitting an fte inlet should see better gains at top end of the rev range. if you do remove the limiter make sure your bottom end isup to it lol
  11. There is defo something not right with the o/f wish bone, hub/ball joint. If you look down the side of the car the wheels don't sit in the same place and if you look at the top mount the camber is as far neg as it can go.
  12. Would need the boss welding to you de cat. Dose it not come with a wiring diagram?
  13. With the tc short shifter kits they can with solid raised bushes that fitted all models I believe.
  14. Zisco ran an Astra box but the ratios didn't quite work from what I remember.
  15. Yet you need to compress the springs to get them out the safe way. Put a set of springs on shortys levin last night took about an hour.
  16. Just keeping it as a tidy car to drive round in. And I have a few spare parts kicking around that will fit not just guna rip the engine out.
  17. ACT on it and forget about it. Will hold your power no problem.
  18. It does drive quite well. Need to get the tracking done. Aren't going to be many of these around soon once every one has robbed the 5E and scrapped them. Good to be back repping the forgoten Toyota.
  19. Shorty loves shimming heads .p
