H_D
    1866
Everything posted by H_D
  1. H_D
    Strange noise
    Worn or loose alternator belt
  2. H_D
    4EFTE ENGINE
    after a 4efte engine, need one soon or will end up breaking my V
  3. H_D
    Lost key
    Or a bit of harsh braking 😎
  4. I drilled mines out and had AN fittings welded on from the inside then blob welded the baffle back in
  5. Also change the water pump
  6. H_D
    oil type
    10w40 in summer and 5w40 in winter
  7. Im sure the newer heads have an extra waterway on the intake side.
  8. https://www.rhdjapan.com/zep-racing-2-row-radiator-aluminum-ep82-ep91.html
  9. il get some pics up later, I got it from, RHD japan, I will be breaking my forged glanza a tth end of the month after 10 years of ownership :( and all parts will be up for sale
  10. I opted for a full size twin core ZEP radiator. Not cheap but it does the job
  11. New driveshafts from toyota are over £1000 and the inner c.v joints cant be purchased separately
  12. i have a set of driveshafts available
  13. Bump Part number is 89420 10110
  14. The new thermostat should have come with a rubber o-ring
  15. I am after a 1996 glanza v map sensor. Please pm me. Thanks
  16. sounds like an ignition issue, had similar symptoms on mines but went away after changing the ignition leads,
  17. Have you checked if all the timing marks still line up?
  18. looks mint - nice doggo too
  19. Im using an orc 309d. Cant fault it
  20. There is only 1 cable for both check its connected properly on the back of the instrument cluster.
  21. Fully refurbed, sand blasted, painted, new seals etc. Works perfect. Mint condition, will also throw in all 4 brake pad retention clips. £115 posted £100 collected from leicester.
  22. H_D
    Front glanza badge
    Toyota still stock them.
  23. Brilliant clutch and excellent pedal feel, I have the same clutch on my V
  24. I use the VAG or loctite stuff
