H_D
    1867
Everything posted by H_D
  1. Item For Sale: 4efte rocker cover Item Condition & Description: mint condition sprayed 2 weeks ago in a matt metallic gunmetal grey using proper high temp paint. Price: £50 + 4% fees. Pictures: Payment & Shipping Details: postage included in price (recorded delivery via royal mail)
  2. Keep it on axle stands and leave the handbreak off. When its time to drive again drain all fluids and replace with new and prime the engine and turbo before the 1st start.
  3. any 75w90 will be fine
  4. best thing to do is a compression test and sniff test before taking it apart. both tests should conform head gasket failure.
  5. is it loosing any oil or water? Have you done a compression or sniff test,
  6. well done mate.
  7. knock sensor is probably the most important sensor on your car for tuning and monitoring engine health. I would only ever use a genuine toyota one.
  8. speak to abbey motorsport they have built many rb engines easily capable of 1000bhp+ and they built john bradshaws world record breaking rb engine in project gtst
  9. few more days before its boosting and screaming again. whaaaaaa pssssssssh
  10. few more days before its boosting a screaming again. whaaaaaa pssssssssh
  11. DMX - intro - from the album its dark and hell is hot track 1, This will have your opponent shitting bricks, good luck Jim
  12. there are 2 types of gaskets for the intake mani 1 will block the hole 1 will not you need the correct gasket, Im pretty sure IDWORKZ have them
  13. if it only happens when you are turning then its definitely your cv joint
  14. could be a worn cv joint.
  15. if you are based in Leicester contact future-Motorsports, My Glanza is there at the moment and so is Jamie1st. Ask for bijal and tell him I sent you. http://www.futuremotorsports.com/
  16. Purchased a knock sensor, It arrived well packaged and was delivered within 48hrs. Thanks.
  17. Nice work
  18. there is no manual switch for the rad fan it must have been fitted by the previous owner, If you have an after market temp gauge then I would switch it on for 30-40 seconds to bring down the temp once it has reached the temp rating on your thermostat. To identify the temp rating on the stat you will need to take it out and the temp rating will be stamped on it if i remember correctly it should be 82-87 degrees.
  19. Its not about what people are running on here it comes down to what your tuners is comfortable with mapping.
  20. As above speak to your tuner and go for what he/she recommends
  21. any time buddy if you need any help or advice just give me a shout.
