H_D
    1866
Everything posted by H_D
  1. Im selling my GT in approx 1-2 weeks, almost standard - minor front end damage that has been fixed looking for £1750 http://www.ukstarletowners.com/topic/74076-newish-daily-ep82/
  2. H_D
    Pcv valve urgent
    why would someone urgently want a PCV valve, I urgently removed them of both of my EPs lol. by the way they are not needed for an MOT. Just block off the nipple on the inlet and stick a breather on the roka cover hole for your MOT, its best to attach a pipe to it and let it vent to atmosphere or a oil catch can.
  3. The reverse lights look good blacked out. I think the clear lenses ruins the look of the rear,
  4. H_D
    1000th post
    Sorry people it had to b done. Lol
  5. H_D
    1000th post
    This is my 1000th post and its a big deal to me call me sad but that just me lol.
  6. I hate reading posts like this its awful. I hope it comes back to you in one piece and i will keep a lookout
  7. No they should fit perfect unless its been damaged or if your car is bent lol
  8. Got some bits off Matt they arrived well packaged and as described. Good Communication and a top seller. Keep it up.
  9. yellow ones are too stiff imo and the black ones are meant to be stiffer
  10. i wouldnt run more than .8 bar and i would not bother spending money on a mapable ecu for the sake of a hybrid. fcon is a good ecu but will need mapping.
  11. Crank caps is what holds your crankshaft in place, head bolts are approx 5-6 inches long
  12. you will see a small difference but hybrids are more noticeable at the higher rev range where the stock ones usually run out of puff
  13. yes it will run fine but dont increase the boost untill you get proper management and a FCD is not needed if your only running 0.75 bar of boost.
  14. I have sold 4 turbos and used royal mail every time, No problems at all - just make sure its well packaged in a box with polystyrene cost approx £25 iirc and that was 24hr tracked delivery.
  15. management is key - fcd is a ticking time bomb get rid of the FCD and go for a plug n play ecu and then turn it up to 1bar. should be close to 200bhp on stock ct9 and probably 10-15 more bhp with a hybrid. Also change your fuel pump
  16. have u got a knock sensor?
  17. somebody please please help Its the last thing i need before i can fire her up again
  18. NEED A 96 KNOCK SENSOR ASAP SO THE V CAN TERRORIZE THE TARMAC AGAIN
  19. tell the insurance company how much you can get it fixed for go to another garage or get a trader on her to make up a quote for you. I had to get my mate a cheap quote from a local workshop so his car didn't get written off,
  20. or get a halfords HB038
  21. I need a 1996 spec knock sensor or the connector for the knock sensor off an EP82 loom as I have a spare ep82 knock sensor.
