H_D
    1867
Everything posted by H_D
  1. The pcv valve is a stupid restriction and i would advise everyone to remove theirs especially when running more power as it helps the engine breathe more efficiently when removed.
  2. jack it up remove wheels and drive shafts its pretty much self explained when you look at the car from the underside once the wheels are off.
  3. pro - More power gains with lower boost. Con - more likely to det at high power so a good map is very important.
  4. Sorry people they were sold to me
  5. I wouldnt even re-use any type of headbolt so I went for studs instead and also using ARP studs on my main caps and flywheel.
  6. stock bolts are made to stretch. They are technically called TTY (Torque To Yield) bolts. Many manufacturers put TTY bolts in a head when manufacturing the car because they are the cheapest bolts available, and when you are using millions of bolts in a year even 0.10p a bolt adds up.Once these bolts are installed the first time, they stretch because they are made to. Once they are in your car for years they become rather worn out.When you take them out of your head they are stretched and should be thrown away (same with flywheel bolts). Never re-use the original bolts in your head. If you do you'll be buying another head gasket in a matter of weeks.
  7. You can get specif caliper paint from halfords, works really well and easy to apply with a brush. 1 small tin is more than enough.
  8. Any competent aluminium welder should be able to do it.
  9. Il take the zep and toms. I will come c u on saturday
  10. Definatley sounds like valve stem seals. Just drop Keith or Kon a PM for the stem seals they will sort you out even if the group buy has ended.
  11. Its always a shame when a car enthusiast has to walk away from their car due to no fault of their own
  12. I got shit loads of gt and glanza parts. What do u need. by the way im also based in leicester
  13. I paid alot less for skimming, decking, boring, head work, block x-ray and balancing.
  14. sounds like fuel cut, Have u done a diagnostic check?
  15. Looking forward to this. where is it located?
  16. x 2
  17. like There will never be another Senna and nobody can even come close - The No1 late great!
  18. get your name on he group buy for the zisco valve stem seals. They are cheaper and stronger than they toyota ones.
  19. I think its the valve stem seals - compression results look good.
  20. Lol...The previous owner of my V only sold it as he outgrew the car he was 6.4 at the time iirc, He had the lowest rail on the drivers side with a recaro bucket seat and he still didnt quiet fit he used to get a lot of stick from his mates who said he looks like an overgrown baby in a pram lol
  21. 150-200 is safe on a stock engine. anything above 230ish on stock internals is asking for trouble IMO
  22. This is correct - Replacement wishbones come with new bushes pressed in.
  23. It should be ok withany decat but you may have to modify the piping on your exhaust
