H_D
    1867
Everything posted by H_D
  1. does it have a dirty engine bay?, tein coilovers?, tein stickers? bright green rocker cover? and rear c pillar bar made out of a very thin tube of aluminum almost as thin as a coke can. If the answer is yes to all of the above then the car came from leicester and it had 3 crashes in less than 6 months and the old owner did not know the difference between night and day. I fixed a few problems on it before he sold it,
  2. 15-20 mins in this weather. The temp gauge is for the water not the oil.
  3. Electric cars with brushless motors are much faster than nitro cars and require alot less maintenance. If you run li-po batteries you get approx 30 mins runtime per charge.
  4. Its illegal but police dont usually say anything about it unless if they have nothing better to do.
  5. If your getting mixed reviews i wouldn't bother. Just go to someone else with a better reputation.
  6. Buy a bmw
  7. avoid the appollo hotel and days inn hotel in birmingham at all costs,
  8. each to their own - been on the starlet seen long enough to have seen many engine failures because of flushing - I strongly recommend you do not flush it and im sure many will agree. the oil pickup in the sump is a gauze type pickup and can block up very very easily.
  9. Do not flush your engine, Your oil pickup will get blocked and your engine will die from oil starvation.
  10. the EP bug bites again. Welcome back.
  11. bump
  12. x2 my old zep ecu was pretty rich on boost but spot on when on idle
  13. H_D
    Evil Glanza
    by listening to the way the gearbox whines its defiantly using a dog box
  14. As above. I need a new window regulator. I attempted to fix it the other day but the white plastic cog is broken Let me know what u got. Thanx.
  15. i would get the injectors inspected and also change the fuel filter. Sounds like your running lean and it wont run for much longer if its leaning out. also check your fuel pump.
  16. sheffield is a bit far for the notts and leicester lot
  17. a local saisburys closed down in leicester and the car park is still there. local business use it all the time and there is lots of space for everyone.
  18. i call my gt The Dog as its used daily in shitty weather conditions. My glanza was called the the black slayer but its off the road during winter for a serious overhaul. When it comes back it will come back with loads more power so depending on how it drives I might have to re-name it to the supercar slayer lol. I always wanted to tune my EP to beat supercars and I dont mind blowing up a few engines trying.
  19. meadow hell no thanks count me out. way too far for me.
  20. H_D
    rocker cover
    Il have the lime green one Liam. Thanx for all the replys guys this thread can now be closed.
  21. no more nails double sided sticky tape. Mines has held for the best part of 3 years been through many washes, bad weather and high speeds. No signs of it coming off.
  22. H_D
    rocker cover
    As above, I need a rocker cover for my gt turbo let me know what you got. Thanx.
  23. Looks nice and clean, Fancy swapping for a silver one?
  24. I say turn it up to 1bar and you should be closer to 200bhp.
