I made 175 at 0.8 bar
190 - 200 would be normal at 1 bar
More has been achieved tho, just depends on engine health and other factors
Am I reading the leader board wrong 211hp from a ct9b on stock internals?
sure on uk rolling banks they seem to read a tat higher then in the republic ere 1 bar is around 180 over ere if the engine is super fresh maybe 190 but pushing it hard
anythng above a bar is useless stress on the engine turbo for nothing
Edited by 5e colin
It's the fuel over here too Colin, mainland can get 99 ron
In the north here can only get 97
And it's even worse down with you's
EWG is the way to go imo holding the boost.. I've seen dyno sheets of stock ct9 217 but it just depends on alot of things, fuel, temprature, mapper
When I bought used Tongs hybrid it was dynoed 223 in UK on rolling road, same turbo made 146hp from wheels on my local hub dyno. Dyno differences explain the most high power CT9s on leaderboard ;)
So your claiming dyno differences made you 80 less horse power? if you made 146 at the wheels pretty good chance something else is to blame not the dyno.
