Godspeed Posted June 7, 2018 Posted June 7, 2018 HI there, Has anyone out there got a standard tune for a EP91. One that has been tuned on a dyno would be great. I loaded on the base map from there website before anyone asks, but it has no power and wont go over 2300RPM making it difficult to drive to a dyno. Has anyone else loaded on the base map from their website? did you have similar problem? Thanks in advance Quote
TimD Posted June 7, 2018 Posted June 7, 2018 Plug the standard ECU back in, drive to dyno, plug the ME221, map? Thought these things were plug and play? Quote
Godspeed Posted June 7, 2018 Author Posted June 7, 2018 Yeah I have plugged in the old ECU, but I don't really have the money right now to dyno tune the car after paying over $1000NZD for the ECU. They are far from plug and play. I don't think much R&D went into this ECU or research alone. When I bought the ECU I ticked the box to receive an ECU for a EP91 because I have an EP91. It comes with a 3 plug ECU, if you have a manual ECU it is only 2 plug. Lucky mine is an Auto and is 3 plug. Before I bought the ECU I asked if it works with an auto, and they said it would. I think that's where half my problems are coming from Quote
daniel_g Posted June 7, 2018 Posted June 7, 2018 Get a refund. Heard nothing but bad news about these ECUs. Thought you would be able to get a Link mapped up straight forward where you are. Quote
00joeindastarb0 Posted June 7, 2018 Posted June 7, 2018 I would think it being an Auto is the problem Quote
gorganl2000 Posted June 7, 2018 Posted June 7, 2018 (edited) may be something to do with the auto variable TPS and neutral start compared to a manual EP91 i converted my car from auto to manual a long time ago, and since then i've ran stock auto ecu, stock MT ecu and JAM MT ecu...the car registered a code 51 iirc with the MT ecus, but worked have you contacted ME for advice?...they should be able to assist Edited June 7, 2018 by gorganl2000 Quote
Godspeed Posted June 7, 2018 Author Posted June 7, 2018 9 hours ago, daniel_g said: Get a refund. Heard nothing but bad news about these ECUs. Thought you would be able to get a Link mapped up straight forward where you are. I have been trying to get a refund - No luck. They say I need to get it tuned. I did look into keeping it Kiwi made going for a Link, would have cost the same amount for the ECU, but I would have also had to pay for wiring it up and tuning. having something that is "Plug n Play" plugging into the existing wiring harness seemed like an easy and cheaper way of doing it. I'm not chasing massive amounts of power, just a little more boost without hitting the fuel cut. 9 hours ago, 00joeindastarb0 said: I would think it being an Auto is the problem I think it is too, but ME is denying that is the problem.  9 hours ago, gorganl2000 said: may be something to do with the auto variable TPS and neutral start compared to a manual EP91 i converted my car from auto to manual a long time ago, and since then i've ran stock auto ecu, stock MT ecu and JAM MT ecu...the car registered a code 51 iirc with the MT ecus, but worked have you contacted ME for advice?...they should be able to assist It has to do something with it interfacing with the automatic transmission, seems to run fine until you put the selector into drive. then it seems to go into "limp home mode" loses all power and doesn't rev over 2300. I would like to convert mine to manual, would you say it was worth the hassle? I have contacted ME and they are saying its a tuning problem. I just want my money back at this point. Quote
gorganl2000 Posted June 8, 2018 Posted June 8, 2018 15 hours ago, Godspeed said: I would like to convert mine to manual, would you say it was worth the hassle? well, to be honest, i only bought the car when i knew i had all the parts to convert it to manual----i bought all this stuff first...lol i bought the car, drove it home as an automatic, put all the manual conversion parts into the trunk and took it directly to the mechanic to be converted...so that was the extent of my auto experience---less than 1 day  iirc for me, it was worth the hassle, as i strongly prefer MT Quote
RobSR Posted June 8, 2018 Posted June 8, 2018 If itâs still got the automatic gearbox id imagine that is the issue like has been suggested. I wasnât aware of the ME having an auto gearbox control but Iâm sure they can confirm. Quote
Godspeed Posted June 10, 2018 Author Posted June 10, 2018 On â9â/â06â/â2018â â11â:â57â:â02â, RobSR said: If itâs still got the automatic gearbox id imagine that is the issue like has been suggested. I wasnât aware of the ME having an auto gearbox control but Iâm sure they can confirm. Yeah still have the automatic gearbox. I don't think ME was aware they needed a automatic gear box control. And I'm sure they would tell me if their ECU had the function, since I am in contact about the issue I'm having. Still just waiting for my refund.... Quote
Stu Posted June 18, 2018 Posted June 18, 2018 Hopefully you can get your refund. Definitely look at a Link though, just wire it into the factory harness piggy backing the factory ecu so it runs everything but the factory ecu keeps the auto shifting etc. Quote
Godspeed Posted July 2, 2018 Author Posted July 2, 2018 On â18â/â06â/â2018â â9â:â07â:â49â, Stu said: Hopefully you can get your refund. Definitely look at a Link though, just wire it into the factory harness piggy backing the factory ecu so it runs everything but the factory ecu keeps the auto shifting etc. Thanks Stu, ill have to look into it. Where abouts are you from in NZ? Matt has agreed to a refund after I took it to 2 tuners here, and they both said the same thing, automatic gear box is blocking it. So I have sent it back and they are testing the ECU. so I haven't seen any money yet. Quote
Starlet__SR Posted July 3, 2018 Posted July 3, 2018 On 07/06/2018, 13:24:24, daniel_g said: Get a refund. Heard nothing but bad news about these ECUs. Thought you would be able to get a Link mapped up straight forward where you are. Like what? I've yet to install mine.. Quote
Stu Posted July 3, 2018 Posted July 3, 2018 20 hours ago, Godspeed said: Thanks Stu, ill have to look into it. Where abouts are you from in NZ? Matt has agreed to a refund after I took it to 2 tuners here, and they both said the same thing, automatic gear box is blocking it. So I have sent it back and they are testing the ECU. so I haven't seen any money yet. I'm in Auckland Quote
daniel_g Posted July 4, 2018 Posted July 4, 2018 12 hours ago, Starlet__SR said: Like what? I've yet to install mine.. Lad who mapped my car was telling me about a few who have come to him with them, functions not working correctly, unable to run COP properly. One had to be soldered again for some reason. He just didnt rate them. Quote
Starlet__SR Posted July 4, 2018 Posted July 4, 2018 13 hours ago, daniel_g said: Lad who mapped my car was telling me about a few who have come to him with them, functions not working correctly, unable to run COP properly. One had to be soldered again for some reason. He just didnt rate them. Strange but to be expected with a newish product. Only reason I bought mine was a step up from the aging PnP's, just giving that bit for flexibility. It's only gonna be so long before they start to fail lol. Quote
federalman Posted August 20, 2018 Posted August 20, 2018 On 7/4/2018 at 9:35 PM, Starlet__SR said: Strange but to be expected with a newish product. Only reason I bought mine was a step up from the aging PnP's, just giving that bit for flexibility. It's only gonna be so long before they start to fail lol. How are you getting on with it? I'm after an ME221 as it seems to be an excellent choice for the money. Quote
Starlet__SR Posted August 20, 2018 Posted August 20, 2018 3 hours ago, federalman said: How are you getting on with it? I'm after an ME221 as it seems to be an excellent choice for the money. Mines still in the box matey, haven't had chance to try it out yet lol Quote
Godspeed Posted August 29, 2018 Author Posted August 29, 2018 I did receive a refund in the end, so happy in that respect. Once I have converted mine to manual I might try going down the track of speeduino. It would only be a few hundred dollars to give it a go. Its a free open source ECU that's built on the Arduino platform. Here is a link for anyone interested: https://speeduino.com/wiki/index.php/Speeduino Quote
Calum122 Posted August 29, 2018 Posted August 29, 2018 (edited) 10 hours ago, Godspeed said: I did receive a refund in the end, so happy in that respect. Once I have converted mine to manual I might try going down the track of speeduino. It would only be a few hundred dollars to give it a go. Its a free open source ECU that's built on the Arduino platform. Here is a link for anyone interested: https://speeduino.com/wiki/index.php/Speeduino Mate, that's mental! An arduino is like 14MHz processor onboard. And like 32Kb of memory. Surely that's worse than the stock ECU. Â Having a read on their pages LMAO. Wow. Okay but it hardly seems like a reliable tuners ECU. I'm not a mapper, but 16X16 load points doesn't seem like a lot... Edited August 29, 2018 by Calum122 Quote
Godspeed Posted August 29, 2018 Author Posted August 29, 2018 4 hours ago, Calum122 said: Mate, that's mental! An arduino is like 14MHz processor onboard. And like 32Kb of memory. Surely that's worse than the stock ECU. Â Having a read on their pages LMAO. Wow. Okay but it hardly seems like a reliable tuners ECU. I'm not a mapper, but 16X16 load points doesn't seem like a lot... Yeah it does seem crazy, but ill give it a go. its not going to cost me much. If I do try it, ill be sure to post it on the forums here. It could be a cheaper option for people on a budget ;) Quote
gorganl2000 Posted September 3, 2018 Posted September 3, 2018 why not research megasquirt if going the cheaper route?...it's been around for a while now i'm no tuner, but some people have used them in the past...best to ask for their experiences on the starlet Quote
RobSR Posted September 3, 2018 Posted September 3, 2018 I believe @TrisK has one in his GT but correct me if I am wrong! Quote
TrisK Posted September 3, 2018 Posted September 3, 2018 1 hour ago, RobSR said: I believe @TrisK has one in his GT but correct me if I am wrong! Yeah. I have a megasquirt Quote
Frankieflowers Posted November 20, 2022 Posted November 20, 2022 (edited) On 6/8/2018 at 3:51 PM, gorganl2000 said: well, to be honest, i only bought the car when i knew i had all the parts to convert it to manual----i bought all this stuff first...lol i bought the car, drove it home as an automatic, put all the manual conversion parts into the trunk and took it directly to the mechanic to be converted...so that was the extent of my auto experience---less than 1 day  iirc for me, it was worth the hassle, as i strongly prefer MT Hello. I hope you are going to read this. I have swapped a 4efte ep91 eutomatic engine from a Glanza V into a Corolla E11 and I am in the process of changing the exhaust manifold with an external wastegate for the next step that is adding a piggyback. The plan was a DET3 but then I read about this standalone and I got curious. My engine is in the same situation as yours. Does the MT standalone ECU work with the auto to manual engine conversion? Let me know. Thanks! Edited November 20, 2022 by Frankieflowers Quote
