Jeff is at garage today, running a bit sweeter now I have adjusted the idle and replaced the coolant temp sensor
Will keep you guys updated
  • Replies 595
  • Created
  • Last Reply
Top Posters In This Topic
nope fraid not mate
still no joy have changed the engine coolant sender, the spark plugs, leads, injectors, idle control valve and it still runs like shit and stalls at the slightest thing
tbh its worse than before, checked turbo as well as wasnt getting above 0.2 bar and checked all ic piping too
hating this car so much, plus its booked in for mapping friday the 9th terrific
adjusted it slightly, a mate and i are gonna do a compression test tomorrow (hope its not got bore wash) and check and adjust the timing
Christian and I have sussed it, we took the cambelt out to check the timing and found this!
....no not really, this
Changed cambelt, re-timed and its working lovely, being without boost for so long its scary fast again now lol, cant wait til it goes for mapping on friday yay
erm si i do believe some one else was there who brought the banter bus along!!!??
surely i was a massive help?
sorry dude, wouldnt have happened without you, i def brought my oyster card
thanks all for the nice comments, garage said there is wear on one side of belt, but didnt take cover off to look!
Compression on all 4 cylinders 180/185 happy with that
Catch can and Blitz BOV on pipe ready for AFR tuning friday
As expected, didnt go to plan, either the ecu is farked or the wiring is wrong, we checked it there too but couldnt see anything
may need an fcon Pro V now instead boo
Forgot to mention AFR is TVR city look at this bad boy lol, was designed to be 1000bhp and fastest street legal car, but owner ended up in jail lol
and this lovely Escort
today had mixed fortunes, got some parts from the post office, namely 2 piece Endless discs, Ultra leads and TRD bushes...well bush lol
the discs are lush look, fitted already and grooved from the factory
and the leads...which were for a 4efe, not 4efte so they'll have to go back and only one lower arm bush lol, all to be resolved shortly
so not a great 2 days all in all, but catch can (resprayed (not in pic) and welded) and dump valve fitted to the GReddy cold pipe
so not all bad
  • 3 weeks later...
car is getting there again, got a mate at Toyota who can sort my gearbox out thankfully
also picked up the Tanabe/Nightspirit front anti-roll bar from Mark on monday, it shall be known as this forever and ever amen, as the car is a legend
  • 2 weeks later...
Car is in Gatwick Toll House being worked on atm
Having the following done hopefully
LSD re-shimmed, 2nd synchro replaced, rear beam TRD bushes added, new door hinges
plus I have my ULTRA leads and TRD lower arm bushes en route too, may get them added at the same time - we shall see
  • 2 weeks later...
Needed an oil change today so took the opportunity to move the oil filter relocator from the daft place it was before, which meant I had to take my bumper off every time I changed the filter:
to here:
Much better, so now I can even change the filter with the bumper on, also fitted some Ultra spark plug and king leads but didn't take a pic sorry!
Turbo Dynamics are legendary, got the SARD K24 back today is in perfect condition now ready to go on the car can't wait to feel this bad boy motor now, may go on this avo if not saturday - lush!
typical as usual something goes wrong, Idrees sent me the return pipe for the base of the turbo, i left it in the box to TD and they've lost it ffs - why does it always have to go wrong!
I have had the exhaust housing side drilled for the EGT sensor though, so one less job to do
Slight update!
Car is back in the garage having some welded done to the lower arms, also getting the TRD bushes pressed in
Riko arrived today with the cleanest Nur-Spec back box I have ever seen too so that will soon be on the car, can't wait
Have had an ally oil return made up too so can get that on the motor too in the not too distant
Thanks guys, I always loved the Nur Spec, didnt get it fitted today sadly garage was hella busy
thanks Iddy, got it sorted now thanks - got one made
Is it the Plate?? If so its awesome :D
Yes it is the plate mate cheers
Got to say that number plate is rather awesome! :)
Cheers jag, it had to be done its the perfect combination of Jeff & 4e-fte
Numberplate is awesome Si! But two inventions you need to invest in.
Bucket (Fill with water)
Wash mitt.
You cheeky sod, I have both, the one thing I dont have is time! Had the Blitz Nur-Spec put on monday and that makes him sound so much better, next step is turbo kit, need flange welded on my downpipe and then put that all on and then mapping
Money is hella tight atm too because I have a big holiday to Thailand and spending money for diving needed
errrrrrr...she's rollin her winter wheels....errrrrr......fur'why??
Phil.
One of the front TE-37s is scratched and I can't find any one local and decent who can get a perfect colour match and a good job done
what about the guy Rick used to do up my Volks? he is THE man!
Philllll.
True didn't think of that i'll ask
I want to see Jeff's Muff :)
I've seen enough of yours, you slut :)
Ok it shall be done, ill get pics tomorrow sigh x
I've given into temptation I've bought idrees' complete K24 kit, im gna get the welding checked and some braces made up to make it as good as the Secret Sports/Zisco; which will be up for sale afterwards
Received from Iddy:
Turbo is ready for its new home on here, plus also taken off Sard C-II wastegate throroughly cleaned it and wire-brushed base, this has now been painted too, the base in black, the bell in silver - all that remains now is too have the manifold checked over for welding issues and get some braces welded on, may also heat wrap this beast too, then off to the mappers
needing to find a turbo hot side to downpipe gasket atm too tho, any ideas?
manifold is currently being re-welded, braced and having a bolt removed from it, then it will be heat-wrapped and ready to go on just trying to find the right size gasket for it
  • 2 weeks later...
Poly bushes added to the lower-arms and poly bushes put back onto the standard front anti-roll bar, well so far only one lower arm bar bush had to go to work before fitting the second and haven't received the front arb bushes yet lol - but you get the idea that's the plans lol
Should be picking up the re-welded and braced SARD mani tomorrow too woo!
