  • Replies 249
  • Created
  • Last Reply
Top Posters In This Topic
Just had a quick look through this thread and its just awesome ;)
Great project mate well done!!
One of our cars is running a GT30 with a short ratio dog box and big cams, full map etc at 1.9bar boost and it has trouble getting it to spool up before its too late. its a massive turbo with massive spec, and we kept ARs down as much as possible. Now we're building a head with bigger valves and fittings springs for 10mm lift to change the cams, and see if it works like that.
Good luck with it mate. If I were you, if you're still in time, change it and get a GT28, much better results and 450bhp attainable with good map. But again good luck whatever you decide to do, great spec and very nice car :)
  • 5 weeks later...
Done some more to the car. Took over my brothers garage so the car is now parked on the lift and parts are going on and off. Welded in new seats, moved the battery to the trunk, changed front discs, prepared the 4e as a dummy engine to build a new manifold to the gt30+++
just an epic car cant wait to see the tubby set up. did u ever manage to get your hands on those carbon side skirts that were floating around the forum?
  • 2 months later...
  • 1 month later...
Little update....
New engine done, only missing turbo manifold.
Welded in an16 in sump to get rid off pressure
Brakes in front done with Ferrodo pads
Brakes on rear done, oem brakes. Drilled discs for ventilation
R888 all way round
Removed all fuseboxes and original wiring. Moved battery to the rear. Made a new fusebox
Sneak peak on the barbecue this year
My new daily driver. 2012 Avensis on air
What Coil's are you using for coil 2plug??
Looking tastey as ever Erik!
VAG ones..... :wacko:
/>http://www.ebay.co.uk/itm/AUDI-A3-S3-A4-A6-TT-QUATTRO-IGNITION-COIL-PACK-NEW-/120414421142?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c09424096
Edited by Erik
hey Erik where in Norway are you from?,i have been working in a ship yard not far from Alesund..
Close to Oslo
