Chris Green Posted March 28, 2014 Author Posted March 28, 2014 :thumbsup: :thumbsup: updates with photos please dude! Phil. That's rich, given your track record lol. Will update with photos when there is an update, should be tomorrow. Good to see you still have the love Chris and look forward to updates John Never lost the love, just a lot of swearing lol. MS3 ordered great chris im happy you decided to keep her alive i was worryd she was going to be broke when the trumpet came off Well the project will still be alive, not sure about the car itself haha. I'll never break her now. Quote
Chris Green Posted March 29, 2014 Author Posted March 29, 2014 Some progress made today. Airbox & piping outIntake manifold offFuel lines outFuel rail offMost of the dash plastics outApexi AFC neo out.Rocker cover off Really surprised how clean the head was, photos to follow. Quote
Chris Green Posted March 29, 2014 Author Posted March 29, 2014 I know, I know. It's just the hassle of firing up the computer lol. Will post tomorrow, promise Quote
Nanglebadger Posted March 30, 2014 Posted March 30, 2014 lol @ John!!!!! Fair comment though bud! Good to hear you're tinkering away dude! Phil. Quote
Chris Green Posted April 21, 2014 Author Posted April 21, 2014 (edited) Well, I suppose this is over due an update. I started stripping her when I had a few minutes spare, over the last 3 weeks. To date I have made steady progress with the majority of the engine bay stripped out. Realistically, all I need to do now is remove the drive shafts and mounts and she'll be ready for lifting out. Once the lump is out, I will remove the servo, brake & fuel lines, so the bay will be ready for prepping for paint. Here are a few photos so far. As you can see there ain't much left in there. On to today's updates, I have just spend the best part of 2 hours hiding in my man cave grabbing part numbers & firing them off to Toyota, here's the list & prices. Sump Bung 9034112012 £1.23Sump Bung Washer 9043012019 £0.43Sump Bolts (x10) 9011906719 £2.32Sump Bolts (x2) 9011606151 £1.34Piston Rings 1301111122 £42.35Con Rod Bolt 1326510022 £6.80Con Rod Nut 9017908014 £2.48Thrust Washers 1101110010 £12.02Con Rod Bearings 1320410020 £19.18Crank Bearings 1170410012 £29.54Crank Pulley Bolt 9010512051 £0.81Flywheel Bolt 9010510138 £3.92Timing Belt 1356819116 £22.16Idler 1 1350511040 £19.44Idler 1 Spring 9050616050 £0.92Idler 1 Spring Bracket 1355811050 £2.46Idler 1 Bolt 9010508123 £1.27Idler 2 1350311030 £19.44Idler 2 Bolt 9010508206 £0.66Oil filter Bolt 9040419007 £2.34Radiator Brackets (x2) 1650511240 £18.46Radiator Bolts (x2) 9011906802 £0.50Radiator Hose Clamp (x4) 9046731003 £3.64Alternator Adjustment Bolt 9011908053 £0.74Alternator Bracket Bolt (top) 9163560820 £0.31Thermostat 9091603046 £8.06Thermostat Housing nuts (x2) 9017908054 £0.58Thermostat Housing nuts (x2) 9017906106 £1.34Thermostat Housing gasket 1632563011 £1.50Water pump pipe bolt to block 9165160612 £0.36Water pump clamp (x2) 9046734003 £1.46Alternator Belt 9936420820 £12.40PAS Belt 9936420920 £16.18Timing Cover Colt (x7) 9151160620 £1.96Gear Box Sandwhich Plate 1135511030 £23.90Crank Oil Seal Bolts (x4) 9164180616 £1.00Front engine mount bolt 9010510268 £1.79Front engine mount bolt 9010510355 £0.43Front engine mount bolt 9010510380 £0.58Front engine mount bolt (x3) 9010510266 £1.41Alternator bottom Mount Bolts (x3) 9011908173 £3.81Water pump nuts (x2) 9017908054 £0.58Water pump Bolt 9011908472 £1.64Exhuast Manifold nuts (x6) 9017910096 £4.92Intake Manifold bolts (x2) 9161160825 £0.56Intake Manifold Nuts (x3) 9017908054 £0.87Head studs (x9) 9213260825 £4.77Spark Plugs (x12) 9091901176 £14.76Fuel Rail Bolts (x2) 9011908145 £1.34Fuel Rail Spacer (x2) 2389111020 £1.94Dizzy Cap 1910111060 £29.70Rotor Arm 1910211370 £4.52Dizzy Bolts 91621B0828 £0.64Dizzy Cap Bolts (x3) 9009904977 £0.93Alternator bottom Bolt 9010510102 £0.67Alternator bottom Nut 9017910016 £0.35Starter Bolts (x2) 9009904562 £2.46Clutch Bolts (x6) 9011908026 £1.44Slave Cylinder Cover 3112612051 £3.87Slave Cylinder bolts (x2) 9161160822 £0.72PAS Union Bolt 9040116008 £2.06PAS Copper Washer 4432712010 £1.25Misc Bolts 9011906394 £9.000.5mm USDM Paseo HG 1111511090 £18.20Oil Pump 1510011071 £26.72Complete Engine Gasket Set 411111104 £86.95Gear box bolt 9161961260 £2.48 Edited April 21, 2014 by Chris Green Quote
vizzioarts Posted April 21, 2014 Posted April 21, 2014 Some parts list chris!Updates on this are exciting. Can't wait to see the rebuild take shape. Quote
Chris Green Posted April 21, 2014 Author Posted April 21, 2014 It is indeed buddy, renewing everything near enough. I want the bay to be factory fresh! Still got a list of aftermarket parts the length of my arm too. Should be taking shape shortly, with that batch of parts en route. Quote
ro55ifumi Posted April 21, 2014 Posted April 21, 2014 Now that is some list, bet the parts guy was happy!! John Quote
Chris Green Posted April 21, 2014 Author Posted April 21, 2014 I'm sure they were lol, plan is to get all of these bolts treated either anodized, painted or zinc coated. Really looking forward to getting 100+ bags for Toyota lol. Hopefully will be pulling the engine out this weekend. While I'm waiting for the parts to arrive, alot of cleaning will be done and prep for the engine bay paint. Quote
Nanglebadger Posted April 22, 2014 Posted April 22, 2014 nice to see an update buddy!!!! thats a hell of a list!!! Phil. Quote
Chris Green Posted April 24, 2014 Author Posted April 24, 2014 It sure is and costing just a tad over £500, I think it's a bargain. Should be plenty over the coming months. Quote
Starlet-Joshy Posted April 24, 2014 Posted April 24, 2014 Nice update mate! Liking this very much!! Quote
Chris Green Posted April 24, 2014 Author Posted April 24, 2014 Cheers dude. Are you hanging on to yours then? Quote
Starlet-Joshy Posted April 24, 2014 Posted April 24, 2014 Cheers dude. Are you hanging on to yours then?Yeah mate for now! See how much I can do to it Quote
Chris Green Posted May 21, 2014 Author Posted May 21, 2014 A box of Toyota parts arrived at a Ford Garage on Tuesday... Odd, I know. Quote
5e colin Posted May 22, 2014 Posted May 22, 2014 what did you spill on the block for the paint to be eaten away and rust like that ???? Quote
Chris Green Posted May 23, 2014 Author Posted May 23, 2014 The part that's not rusty is covered in oil mate. I would say 12k miles in 10 months, & exposure to the elements + dodgy block paint has done it. Quote
Chris Green Posted May 26, 2014 Author Posted May 26, 2014 It is a sad site, but she'll rise again! Quote
Chris Green Posted May 31, 2014 Author Posted May 31, 2014 No further progress has been made, but another 2 boxes of OEM Toyota parts have landed, to complete the set. Tomorrow shall see the rest of the bay stripped (hang over depending) and possibly the dash stripped. Pretty much decided that the bay will be painted Honda Pirates Black. Quote
Greenmachine81 Posted May 31, 2014 Posted May 31, 2014 Sounds good mate.. it wil look well with your hose colours :-) Quote
