funny onion Posted July 5, 2012 Author Posted July 5, 2012 I'll take a photo and post it up, I'm not very good at explaining :/ the turbo was only rotated by about 15 degrees. Still points upward compared to a td04 which points down. Quote
akyakapotter Posted July 5, 2012 Posted July 5, 2012 Yeah my exhaust has got louder but i like that screamer is insanely loud ;) no I'm not mapped yet. Jam FCC and sard rrfpr will be mapped asoon as I can afford it just trying to get the afr's right for time being which is proving a bitch. It's a little laggy but not that bad then when it boosts my god dose it go to be hoists it feels more responsive than my ct9 set up Quote
A L 3 X Posted July 5, 2012 Posted July 5, 2012 I'll take a photo and post it up, I'm not very good at explaining :/ the turbo was only rotated by about 15 degrees. Still points upward compared to a td04 which points down.That would be great if you could please Quote
funny onion Posted September 21, 2012 Author Posted September 21, 2012 bit of an update!she ran like a dream even considering the huge crack in the head, and she made the 5 hour round trip to jae like a trooper few pics from hull motor show and jae;decided that seeing as the head was scrap and the clutch was just about dead, we would rip the engine out tonight and crack on with swapping bits and stuff before i go back to uni. shes getting;- new cylinder head, freshly skimmed, cleaned and pressure tested- new valve stem oil seals- new head gasket, rocker cover gasket, general seals on the head, injector o-rings, spark plug seals etc etc...- exedy stage one organic clutch kit- replacing crank oil seals- painting block, gearbox etc- painting engine bay- removing unnecessary crap and tucking a few wires- the usual bits like fresh oil in engine and box, oil filter etc...and last but not least, full wepr external wastegate td04 kit (not actually got it yet but in a few days or so fingers crossed) pics so far!and she was out! everyone was happy so as it stands right now, the engine is out, bay is bare, and the swapping and painting and stuff commences tomorrow Quote
funny onion Posted September 21, 2012 Author Posted September 21, 2012 oh... i also made myself a gi bonnet! its no where near perfect by any standards but for a first attempt it could have gone worse, this photo was with one layer of paint and no lacquer Quote
Glanza Mac Posted September 21, 2012 Posted September 21, 2012 looking good , plans are to send my car into tuning developments when i can get it in, then take my wepr kit off for you as they cant get a true fault unless everything is whole Quote
funny onion Posted September 21, 2012 Author Posted September 21, 2012 Ok no worries any idea when your taking it? Not sure how many cars they have in but I know they're always busy haha. Quote
Glanza Mac Posted September 21, 2012 Posted September 21, 2012 well i need to ring tomorrow or monday to find out when i can take it down there Quote
Flaminsam Posted September 22, 2012 Posted September 22, 2012 Mac bring it to the lock up for a diagnosis if you wish? Seem to have alot of starlets in my spot at the Moment. But yea can't wait to get cracked on tomorrow. Engine and box split, engine on engine stand, head off and let the cleaning/painting begin! Quote
pick1 Posted September 22, 2012 Posted September 22, 2012 Sweet update giving the advance some tlc looking forward to the end result Quote
*Zoe* Posted September 22, 2012 Posted September 22, 2012 nice update going to be a different car next session! Quote
Glanza Mac Posted September 22, 2012 Posted September 22, 2012 I may take you up on that offer Sam ill let you know Quote
funny onion Posted September 26, 2012 Author Posted September 26, 2012 so engine went back in on monday after everything was dry from being painted. sprayed the bay gloss black, hammerited everything while the bumper and lights were out, and tidied the loom up abit, and ripped out some things that were still in the bay from the air conditioning. all went well as far as getting the engine back in, turned her over on the starter motor with no fuel or spark just to get plenty of oil around it and into the new head. this is when problems started occuring! she turned over for about 10-15 seconds, but the revs got slower and slower and then the engine appeared to lock up and wouldnt turn over at all. i was wounded thinking it was a timing issue (even though we checked before putting the engine back in that it turned over and all was fine) soon discovered that the lines to the throttle body were the wrong way round, so the engine had indeed filled with coolant, fantastic. whipped plugs out and turned her over again and boom, shot coolant about 3 feet in the air. cleared the bores out as best we could, dried off the plugs and put them back in having swapped the throttle body lines. tried to fire her again, and there was something there but definitely not what we hoped for, and she ran on by a fair bit when i turned the key off. checked fuel lines etc, then decided to check the throttle position sensor voltage. it was way out, hence the engine flooding itself. so set the tps up with a multimeter and wound out the idle screw (which was also all the way in). tried again, she fired on 3/4 for a few seconds then died again but that was the best we'd had out of her so far! turns out most of the problems were related to the inlet which i bought from a member on here some time ago, he was honest and said it had been fully stripped and thrown back together so was just a case of trial and error.and here's the fun bit...decided to check for a spark from all the leads with a plug against the block to rule out the leads/plugs. so off we went, fuel sender unplugged. turned her over, yes we had a spark! then all of a sudden there were very loud clicking noises and BOOOM! three foot flames from the inlet area of the engine bay! sam attempted for quite some time (felt like forever) to blow said three foot flames out with his pure man power lungs. needless to say he failed fantastically, so he got shoved out of the way and i dumped about 5 gallons of water on it and it only just went out. problem found- leaky injector on 4. i found it pretty hilarious but sam wasnt impressed and threatened to take me home and carry on without me, because i couldnt stop laughing haha. no damage and the fact that id stripped the loom and wrapped it in black electrical tape meant the loom survived. was a proper inferno!luckily i had a spare set of o-rings, quick swap, injectors back in, primed the rail again and she fired up first time. few slight adjustments of the idle screw etc and she was sweet as a nut. took here down the road, no problems or misfires.and she's been fine ever since but obviously im just limping her around for the first few hundred miles just to be sure. 250 down and no problemswepr td04 external kit turned up yesterday (my ct9 wepr kit was sold to ajep91 a while ago but been waiting on kits etc). picking a td04 up tonight and hopefully tomorrow night she will be td04 (still in steady mode for a while yet though)also just got sorted with a full set of trd shocks and springs last night, to replace the horrendous set of standard ones ive been on for months now and wow what a difference! only problem being shes now a hell of a lot lower and the 16's were chewing on the rear arches like mad so ive put the 14's back on and no rubbing but they look poo so panhard rod needed asap. but i would fully recommend trd's to anyone who wants a good road set up, not too stiff but amazing in corners etc. also have my gauges on the a pillar now, and a hello kitty gear knob haters gonna hate, potates gonna potate. the clutch was absolutely shafted, so in went the exedy stage one organic and a quick clean up of the fork and shaft and the pedal feels lovely and light, and no complaints with the new clutch yet, love it compared to the other oneplans for the near future are-- mot this afternoon- pick up td04 tonight- rotate and possibly fit tomorrow- panhard rod- new tyres for the 16's (or a nice set of 15's with tyres)- japshow finale on sunday woop Quote
akyakapotter Posted September 26, 2012 Posted September 26, 2012 Sounds like you've been having fun coming along nicely now Quote
pick1 Posted September 26, 2012 Posted September 26, 2012 Like I've already said to u great work mate really coming together now glad all was well in the end and she's running nice for u look forward to hearing your beast with a screamer Quote
Flaminsam Posted September 26, 2012 Posted September 26, 2012 I hated the flames. That was defo not disco But at least she is ruunning sweet now and td04 en route. Quote
pick1 Posted September 26, 2012 Posted September 26, 2012 I hated the flames. That was defo not disco But at least she is ruunning sweet now and td04 en route.I can pretty much imagin the look on your face mate with engine bay on fire lol but at least charl's found it funny ha ha Quote
Bluebear Posted September 26, 2012 Posted September 26, 2012 (edited) Bloody hell, it was panic mode activate yesterday it seems! Glad to see it's all sorted now! And the name 'Flaminsam' could have been apt if it had gotten worse Hello Kitty gearnob sounds hardcore, do ittt. Saw this at JAE, but totally forgot who it belonged too, sorry Don't think I even saw any of you lot. Edited September 26, 2012 by Bluebear Quote
Johnboy GT Posted September 26, 2012 Posted September 26, 2012 Good Progress! I too have a blanking scoop amd goin to make a homemade GI bonnet! John Quote
Idrees Posted September 26, 2012 Posted September 26, 2012 Glad it's now sorted and running well, sounds like a bit of an adventure! Quote
funny onion Posted September 26, 2012 Author Posted September 26, 2012 I was more annoyed about the water in the cylinders than the thermal incident. A lot of issues cropped up but every one of them could have turned into something worse so I was lucky. A lot of you who I have spoken to recently at jae/meets etc will know that I constantly moan about wanting either a pure black or white gt or a very clean glanza. I live the advance and know that if I sell it i probably never have the chance to own one again as they're getting very few and far between. But I look at sam's and it makes me want a solid colour rather than a two tone. Or a nice mint glanza. Hmmmm....I'm sat in the mot test station as I'm typing this haha Quote
pick1 Posted September 26, 2012 Posted September 26, 2012 (edited) Let us know how u get on at the mot station and u can't beat black or white gt's but then again I'm biased ha ha Edited September 26, 2012 by pick1 Quote
