Bit of an update! I have made a start on the new wiring loom, going to make it so I can add to it still once its on the car tho as I want to sort the full bay loom out in time but have no time to do it yet!
All new plugs and pins with Raychem race spec wire!
3A175D23-CEA4-40C1-A849-F81172CC6060_zps
7AE0523C-D5DB-4FFD-B72A-F6E7F1042649_zps
Heat shrinked into groups for the first and second rails
50AEE0EB-F836-4550-8578-669244D2DC18_zps
Some thing like what it will finish off like!
6C799061-5B5E-4336-9C87-41BEDDE15360_zps
And the next job on the list is to make a new one of these as I cracked the mocal one :blink: so Im going to make a billet one!
371410BA-F254-4F6C-BEA0-0964B6CBC715_zps
5C12D6D6-3153-4F1F-9459-8F4A9FA8BB3E_zps
  • Replies 640
  • Created
  • Last Reply
Top Posters In This Topic
Cheers Johnny! I've not seen you on here for some time!
I get on from time to time for a browse!
Heading home in 2 weeks so ive gotten the bug again!
Good I hope to see the blue machine out on the road soon!!
Well I been busy playing with the milling machine again! Im getting quite into the milling stuff!
When we did the tuning last time we were struggling to get a good speed signal to the ecu for the trick functions in the ecu like the boost by gear, traction control, launch control and the rest so we gave it up at the time and decided I needed a proper seed input for the ecu. We decided to use a hall effect sensor for the job but could not decide where to mount it or the magnets for the pick ups, so ive had all the gear for the job sat about for over 2 years now! I did make a bracket to mount the sensor onto the gear box to use the drive shaft but had nothing to mount the sensors to so they were secure and not likely to fly off! So I decided to have a go at making a clamping ring to go onto the drive shaft to fit the magnets into and this is how it turned out, Im over the moon with it to be honest!!
It started off as a round blank.
D1993D01-68F3-48FE-9E2E-2F1CE02B1D6F_zps
4333A135-756D-484D-B7C0-BDC694533A8B_zps
3FDC7B90-213A-416B-A279-766C0B88986B_zps
750FA638-D1C2-402E-A28F-4755E3FCB136_zps
This is one of the magnets there only tiny but very strong.
64EBAEEE-B7CD-43F5-B241-D033B2EC5DD4_zps
0260CB32-DB84-4015-9868-1E653B3DB9CF_zps
Cut it in half so it clamps the the CV joint with 2 screws, you can just make out the joins.
582D235E-414F-4FE1-ACAD-EF6BA075356F_zps
7BB1678F-6D8B-4C12-8C34-08EB269DF8BA_zps
I ended up making a new bracket for the sensor too as the original one was too low.
8D4C4ED4-9C2C-4707-92CC-6F25F219AE9D_zps
DCAB1C53-3DCB-4908-9F0A-B3AB7DAB0FA1_zps
The only problem I hit was the CV cup I used to make the clamp fit is different to the cv on the car! I have 3 short drive shafts on the shelf and theres not 2 with the same CV lol so im just going to fit this shaft seen as im still running a N/A short shaft.
Next up is the replacement oil filter take off to replace the cracked mocal one. This turned out pretty good too but I still have to finish this yet! This one started off as a square blank
7C200969-284F-4CBF-AE0D-E07BFC1FC301_zps
EEB28D71-9214-4328-A802-BA290EF37D56_zps
DBF11D6B-47FC-4DE0-945E-587BBD186B3C_zps
72DA548A-014E-4DEB-B8E0-47E7E393A28C_zps
30017B72-4960-454A-9BCF-148A925D157E_zps
98AACB53-7B6C-4F36-9F89-F6A279A75226_zps
21F59450-1CE0-4D31-BCC6-DECF36186AAC_zps
670909D5-F376-4170-B6AE-02B2B1F9A04F_zps
Thats it for now more to come when Im on my days off again!
Will your engine be able to withstand a nuclear explosion after you have pretty much remade the whole engine by hand haha :)
Well the inlet is all bolted up and on to stay! But first I skimmed the flange just to be sure it was flat! And then checked it with some enginners blue and a glass table it was all good so it got fitted and all piped up, then. Made the throttle cable fit!
F4D7500A-D734-4AD6-851C-01277ACC370E_zps
4CB83257-7A8B-42E8-A80E-610527A16502_zps
1D0B7D8F-1694-4F0C-8CCD-E1DFCC1F7256_zps
544DC977-4920-47C3-98F2-6983F4282E22_zps
Well I got the fuel rails fitted today just need the finish the fuel piping off now and sort the boost pipe and wiring then mapping!
E0C64670-D413-4DDF-9C9B-E7B7A2BF483B_zps
9C75E8C2-EB3B-4C5D-8174-CA6AA75271CC_zps
8B0B05A9-BB6E-48E8-8056-7BCA7A3FF9FA_zps
Im going to remount the reg to the engine so theres less stress on the pipes and fixings with engine movement.
E5ABFF39-4AAC-4B36-A196-316D03CE26BC_zps
I did not weld the fittings on the rails my welding int upto that job yet lol
