russ78 Posted November 30, 2012 Posted November 30, 2012 managed to get hold of a perfect condition set of recaros out of a RS turbo is it a case of hacking and welding the rail to make it fit or can I unbolt my stock rails and swap over ? Quote
Matt1878 Posted November 30, 2012 Posted November 30, 2012 managed to get hold of a perfect condition set of recaros out of a RS turbo is it a case of hacking and welding the rail to make it fit or can I unbolt my stock rails and swap over ?Either modifying your current rails to get them to fit or buying some EP91 Recaro rails as far as I know dude. Quote
micky boy Posted November 30, 2012 Posted November 30, 2012 I done this many years ago!I Just cut the feet off the glanza rails and drilled and bolted the feet on the Rs rails! Quote
russ78 Posted November 30, 2012 Author Posted November 30, 2012 (edited) I done this many years ago!I Just cut the feet off the glanza rails and drilled and bolted the feet on the Rs rails! thats kinda what I was hoping for, were these out of a rs turbo ? as my recaros have red stitching not grey and they have the horizontal stiching through the middle ? Edited November 30, 2012 by russ78 Quote
micky boy Posted November 30, 2012 Posted November 30, 2012 (edited) Yeah mate fiesta RS turbo! not sure if they are any diffirent in an Escort Rs though!I also fitted the rear seats in aswell lolI then got bord of the rear seats and took them out as they didnt look right lol Edited November 30, 2012 by micky boy Quote
russ78 Posted November 30, 2012 Author Posted November 30, 2012 really wish it wasn't so cold so I could have go at getting em fitted Quote
yaristurbo Posted November 30, 2012 Posted November 30, 2012 Just been making brake pipes outside, get them fitted lol Quote
mattyD Posted November 30, 2012 Posted November 30, 2012 I think the only way would be to fabricate I tried getting some rails from RHD for my evo recaro's and apparently the bolt pattern differed between seat and rail Quote
yaristurbo Posted December 2, 2012 Posted December 2, 2012 ^^ in the dark ????Yep me and the flood lamp Quote
Starbo Moorley Posted December 2, 2012 Posted December 2, 2012 I were fitting an alternator to Jacks glsnza last nigjt at 11pm, man up lol. Ive always thought about putting rst recaros in mine but never git round too it. Quote
Amjad Posted December 2, 2012 Posted December 2, 2012 Will be attempting to get some Evo 4 Recaros in mine shortly! Quote
Socks Posted December 2, 2012 Posted December 2, 2012 fabbing mountsi is a pain, gurantee ull end up sitting wonky lolz...get a recaro rail cheap from JDM Quote
rob_bower Posted December 2, 2012 Posted December 2, 2012 ^^^^ this my drivers seat is abit wonky the passengers is spot on though. Quote
TrisK Posted December 2, 2012 Posted December 2, 2012 fabbing mountsi is a pain, gurantee ull end up sitting wonky lolz...get a recaro rail cheap from JDM You guys fail. Get a universal recaro mount (mine was from demon tweaks then just bolt th feet on Quote
Liam_D Posted December 2, 2012 Posted December 2, 2012 I have a Bride rail and a Recaro seat and mine sits wonky too beleive its something to do with the back left mounting point!fabbing mountsi is a pain, gurantee ull end up sitting wonky lolz...get a recaro rail cheap from JDM Quote
TrisK Posted December 2, 2012 Posted December 2, 2012 I had a bride rail, with recaro adapters and recaro seatsNever noticed mine sitting wonky Quote
ryan lang Posted December 2, 2012 Posted December 2, 2012 mine sits straight now with a fabbed up rail, unlike it did on the bride rail i had in my old one Quote
TrisK Posted December 2, 2012 Posted December 2, 2012 Did it have adapter plates on the bride rail? Quote
Amjad Posted December 2, 2012 Posted December 2, 2012 Ryan how did you fabricate the rail? (What did you use)My Recaros are gonne be a pain to modify with the existing Evo rails so Grant suggested buying some universal or better, Recaro rails. I'd rather buy Recaro rails but don't want them sitting wonky! Sounds a bit hit and miss with what people have experienced? Quote
ryan lang Posted December 2, 2012 Posted December 2, 2012 yeah was a full bride rail. base and sliders etc. it wasnt noticable sat in it, but looking at it from the back your could see it slightlyurmm ive just use the feet and sliders from the oem rail. cut the parts that bolt to the seat off, then bolted the rail back in the car, measured out the bolt holes in the bottom of the seat and welded 2 flat bars across the rails, drilled holes, welded them to the sliders and bolted the seat on Quote
Amjad Posted December 2, 2012 Posted December 2, 2012 What a pain! It's putting me off buying Recaro rails now! I need to fit mine asap Quote
ryan lang Posted December 2, 2012 Posted December 2, 2012 haha it was time consuming because i didnt want to mess it up, but its not complicated Quote
