as title says really just bought a glanza running 237bhp just wondered if it's safe at that bhp it's all been setup by TD
Emanage ecu , fuel pump , fpr , remap , boost gauge , boost controller , TD04 , fmic etc etc
it's leeroys old car any info would be appreciated!
Thats pretty much the limit of a stock lump, personally i wouldnt run it at that as IMO its almost a time bomb but ill be dependant on condition of engine.
But im sure others will disagree an say theyve had more powerful and been running for years on a stock motor.
I dont have a turbo motor just read about them alot.
I cant see a ebc hurting, and they do help with spool up if setup well, plus they have spike warnings etc which is nice to have.
I would assume thats fly and wheels unless your hi-lo boost button still works?
Have you checked to see if leeroy had an old build thread?
Really appreciate the info guys. Leeroy is a top lad honest as he could be. Got receipts from TD its been set up coorectly its just in my mind because its so fast lol. And i dont thrash cars anyway i just want it to last ;)
I thought Sparky ran 1.4 bar and it blew up on the rollers, but yes what everyone else has said. At that bhp though standard i wouldnt expect that engine to last longer than 12months! i would stick to around 210hp on standard you can sleep at night knowing it will last! :) at that kinda hp you are likely to snap a rod or crack a ringland :p
Actually I think your right Taggy
He got mapped to 1.2, the on the 2nd run at 1.4she blew
if its not running an boost controller then turn the boost down on actuator,with these cold days the boost will spike more causing it to run boost due to the cold air - just a precautionary measure.
depends on the boost.
but a lot of people run a td04 @ 1bar on standard interals for ages.
Sparky ran 1.4 for quite a while.
Didn't last very long though lol
The issue on these engines is there age.... Mechnical Fatigue is setting in...
Generally... 1bar on a ct9 or 1.2bar on a TD04 is considered the limits...
However it still depends hugely on the mapping... A shit map your car could go pop at stock boost...
Go with a reputable tuner... I know Driver on here ran 1.4bar+ on a td04 on a stock engine for over a year and deathed it with no issues...
If your going ebc I'd speak to TD as the boost curve will be different to the one it's mapped for, just a thought :)
And socks is right it all depends on engine condition and mechanical fatigue
