Today is a sad day for me and my starlet :( on my way home from town on a corner I have drove thousands of times over the last 6 years, I lost control of the car and it hit a grass verge and a concrete wall. I am ok just some stiffness but the car isn't. I managed to drive it a few miles to a friends farm but from what I can see so far it has pushed the bottom front crossmember a and the passenger side inner wing in along with some cosmetic damage. I have seen cars like this fixed and my friend has a porta power for pulling these out but it will need a new bumper panel, bumper, fogs, turbo to intercooler pipe, drivers side headlight, grille, bonnet, wing.......etc. So the options I have and car spec are below and I don't know which one would be best and need help deciding. Also if I put my engine in a new shell will it need mapped again or not?
Option 1 - Fix the car put new panels on it and save up for a respray.
Option 2 - Buy a rolling shell or even just a shell and transfer all my parts onto it.
Option 3 - Break the car and buy something else
Spec List
WEPR TD04 Externally Gated Manifold
WEPR TD04 Decat Pipe
WEPR Screamer Pipe
TD04 Turbo
38mm External Wastegate
Japspeed Exhaust
Tuning Developments RRFPR
Greddy Emanage Blue ECU (Mapped by TD on 21/12/2012 222bhp@1bar)
HKS Mushroom Filter (Relocated)
Tuning Developments 255lph Fuel Pump
Greddy Profec B Spec 2 Boost COntroller
Autobhan88 Front Mount
Tuning Developments Braided Oil Line
Depo Wideband Gauge
Momo Steering Wheel
Team Dynamics Monza R Wheels
Cobra 3-Point Harnesses
TRD Mechanical LSD
Meister R Zeta R Coilovers
Adjustable Panhard Rod
TRD & Powerflex Engine Mounts
Powerflex Exhaust Rubbers
Swoosh Boost Gauge
Drilled & Grooved Discs
EBC Yellowstuff Pads
Silicone Turbo Oil Return Pipe
Silicone Vacuum Lines
Aww man thats no too good, defo buy a new shell and swap it all over. Crashed damaged repaired cars are a bit pikey imo, and never really drive straight again. You shouldn't need it mapped again but best to ask TD as theyve just mapped it ae ?
If the shell its self isnt bent
beat the panals straightish with hammer and rattle can.similar colour and use as track weapon
what i was.gonna do to the civic but didnt fancey tracking a car thats actualy bent
Inner wing is dented in but not bent and so is front crossmember but not twisted or anything and car still drives straight. Will post some pictures now and add more detailed ones when I get a chance. Both lower intercooler brackets are snapped so it looks twisted but it is not, also the bonnet is slightly open that's why it isn't lined up.
471793_10151362288580726_157239612_o.jpg412331_10151362291990726_1676236501_o.jpg328922_10151362290340726_1860677178_o.jpg
Id say reshell if thers more damage under the wing, alot of people will be able to tell that its been accident damaged and u dont want that coming back to bite you if you tried to sell etc.
Might be worthwhile buying a shell mate, there are always a few around. One on gumtree, breakers yard place, 150 quid. And just swap all the parts over.
What Starbuck said aswell really.
But In my opinion that's not that bad, and definetly not worth re-shelling over.
You would be surprised how well damage repairable cars can be repaired! Might mate does it and uses them for plenty long enough!
John
Edited by Johnboy GT
It could just be the pic! But the passanger's side chassis leg looks bent!
Been up to the farm to check, it's just the picture both chassis legs are completely straight and have no damage at all. It's only the panels and the inner wing + front crash bars that have damage so should be repairable as the car still drives perfect and straight.
