jayc-glanza17 Posted May 21, 2014 Author Posted May 21, 2014 right as we all kow japfest happened, epic day.. car drove faultlessly, no fluid loss pressures and temps were spot on. good catching up with fellow starlet owners. I finished fitting roll cage just before japfest.. but now im home heres the pics of the car and cage... Picture of me heading to combe. Quote
jayc-glanza17 Posted May 21, 2014 Author Posted May 21, 2014 car is very stiff now amjad.. along with suspension set up, car is much more direct then before. is surprising how much stiffer a cage makes a starlet Quote
Amjad Posted May 21, 2014 Posted May 21, 2014 Awesome! I really want one but they're big bucks, probably be a few years before I can make the purchase.. Quote
jayc-glanza17 Posted May 27, 2014 Author Posted May 27, 2014 cheers liam.. I do think my turbo might be on its way now though. white oil burn smoke once on high boost, any other conditions no smoke at all.. and dipstick level drops slightly too.. but lee from owen developments spoke to me at japfest as I apparently passed him on route to japfest and said mine flew past him and sounded nice.. So he looking at a turbo to suit my build, so maybe a new turbo over winter... Quote
Liam_D Posted May 28, 2014 Posted May 28, 2014 cheers liam..I do think my turbo might be on its way now though.white oil burn smoke once on high boost, any other conditions no smoke at all..and dipstick level drops slightly too..but lee from owen developments spoke to me at japfest as I apparently passed him on route to japfest and said mineflew past him and sounded nice..So he looking at a turbo to suit my build, so maybe a new turbo over winter...Has lasted a fair while to be honest, think yours was one of the first builds I did on here to be honest. Turbo would usually smoke on overun though and not when the cars being boosted? That's awesome Owen Developments really know there stuff that's where I would be aiming to work of they were a little closer to me. Let me know if I can be of any assistance again though. Quote
Beastmode panda Posted May 28, 2014 Posted May 28, 2014 Interested to know if you have the canards etc on the front just for looks or? Quote
RobSR Posted May 28, 2014 Posted May 28, 2014 Lets be honest, anyone who puts canards on a starlet does it for looks. The only way you'll know if they've worked is if they've been specifically designed and tested in a wind tunnel lol. Quote
Beastmode panda Posted May 29, 2014 Posted May 29, 2014 Lets be honest, anyone who puts canards on a starlet does it for looks. The only way you'll know if they've worked is if they've been specifically designed and tested in a wind tunnel lol. True, true. Just wondering that's all, because nothing on the front end is actually going to be doing anything. The car is way too high off the floor for starters and the canards are nearly vertical on the bottom touching the top ones almost, it will jut cause drag instead of downforce. Not digging, just being constructive. Quote
TimD Posted May 29, 2014 Posted May 29, 2014 Any aero worth it's salt needs to be fastened to the chassis of the car, not just the bumper. Aero if working correctly will pull the car to the road, that requires a lot of force. Force which I'm certain the standard bumper mounts will not tolerate. The air also needs to exit cleanly toward the back of the car, meaning at very least the splitter needs to stretch back as far as the floor, otherwise any air forced underneath will immediately exit up and into the engine bay. Quote
Beastmode panda Posted May 29, 2014 Posted May 29, 2014 Any aero worth it's salt needs to be fastened to the chassis of the car, not just the bumper. Aero if working correctly will pull the car to the road, that requires a lot of force. Force which I'm certain the standard bumper mounts will not tolerate. The air also needs to exit cleanly toward the back of the car, meaning at very least the splitter needs to stretch back as far as the floor, otherwise any air forced underneath will immediately exit up and into the engine bay. Yeah man, couldn't agree more. And thinking of that, I bet the engine bay itself causes SO much drag from air going underneath then up to the bay!! Quote
jayc-glanza17 Posted May 29, 2014 Author Posted May 29, 2014 Of course it was for looks, but then with some thoughtI decided to at least make it try to do something.And to get a starlet to have a flat bottom you basically need to recreate the car, as ride height is too high. Quote
Gainzy Posted May 29, 2014 Posted May 29, 2014 There is a rally starlet in the hyper rev, they created a flat base all across the floor pan, I think canards work but nothing major gained, they are meant to create downforce around corners or when sudden change of direction, Rob has a good point though, unless they have been positioned and tested correctly it would create more drag than aero, cars looking sweet definately finished it off with that cage! Quote
jayc-glanza17 Posted May 29, 2014 Author Posted May 29, 2014 theirs one problem with flat bottoms/ sculpted venturi bottoms.. that's is speedhumps.lol.. if this was a dedicated track only car, then I would explore the flat bottom a lot further.. main purpose was to disguise the state and poor paint job from previous owner on front bumper, and as I track it, drive hard on road and shows etc, I have never painted it just hid the state behind canards and splitter.. which to be honest has worked rather well.LOL.. Quote
Beastmode panda Posted May 29, 2014 Posted May 29, 2014 Nah that's fair enough man, was just curious . Quote
Gainzy Posted May 29, 2014 Posted May 29, 2014 theirs one problem with flat bottoms/ sculpted venturi bottoms..that's is speedhumps.lol..if this was a dedicated track only car, then I would explore the flat bottom a lot further..main purpose was to disguise the state and poor paint job from previous owner on front bumper, and as I track it,drive hard on road and shows etc, I have never painted it just hid the state behind canards and splitter..which to be honest has worked rather well.LOL..Speed bumps ruin everything!! Quote
jayc-glanza17 Posted May 29, 2014 Author Posted May 29, 2014 depending on money/time or if I keep the car, then a 98/99 spec bumper will go on with this one my track bumper as I don't care about it much.lol.. excuse not to paint it.. got worry about the white smoke first.. Quote
Amjad Posted May 31, 2014 Posted May 31, 2014 The car is way too high off the floor for starters and Why does it matter if the car isn't very low, as long as a splitter has the correct angle with regards to the car and the ground? Quote
Beastmode panda Posted June 1, 2014 Posted June 1, 2014 Why does it matter if the car isn't very low, as long as a splitter has the correct angle with regards to the car and the ground? Ground effect aerodynamics of race cars is concerned with generating downforce, principally via low pressure on the surfaces nearest to the ground. Suspension motion leading to unsteady flow. It has been well documented that, at a particular incidence, running in proximity to the ground gives increased levels of downforce compared with the freestream case. Why do you think f1 cars are on the floor? Time attack cars? Touring cars? It's all to do with suction towards the floor and accelerating over the suction and ground pressure. Put 2 cars next to each other the EXACT same, same aero set up, except one is high and one is low. Which is going to go round the corner faster? That's why it matters. Quote
Amjad Posted June 1, 2014 Posted June 1, 2014 I agree lower would be better, but surely that's not to say aero won't work without being slammed? Quote
shorty Posted June 1, 2014 Posted June 1, 2014 If its not low enough though you create more of a lift than push effect. That said i dont think starlets are really at the point of need such down force till you are in maybe the 600hp full track prep stage tbh. And plus, it looks awesome tbh who cares if its doing much or not lol, hes not a le mans car its a fast road/track car for fun and awesome days out. Quote
Amjad Posted June 1, 2014 Posted June 1, 2014 And plus, it looks awesome tbh who cares if its doing much or not lol, hes not a le mans car its a fast road/track car for fun and awesome days out. Hear hear! Quote
jayc-glanza17 Posted June 1, 2014 Author Posted June 1, 2014 Shorty thanks for the love bro..As russ78 said when i was behind him " looks so mean and different "It catches your eye and draws people in.Anyways got sort my burning oil prob, looks turbo related at the mome.t. Quote
maddox710 Posted June 1, 2014 Posted June 1, 2014 Shorty thanks for the love bro..As russ78 said when i was behind him " looks so mean and different "It catches your eye and draws people in.Anyways got sort my burning oil prob, looks turbo related at the mome.t.Jay you whipped the downpipe of and checked the turbine side to see if it's wet Quote
