5e colin Posted June 19, 2014 Share Posted June 19, 2014 grand i hope this works out for you , might have a few customers then :) Quote Link to post Share on other sites
turbo Grant Posted June 23, 2014 Author Share Posted June 23, 2014 Going to do a test for on the rear discs after work tonight. After I re-drill the disc so it's 4x100 fitment. It sure is a beast compared to stick lol Quote Link to post Share on other sites
shorty Posted June 23, 2014 Share Posted June 23, 2014 Haha yea boi! Quote Link to post Share on other sites
turbo Grant Posted June 24, 2014 Author Share Posted June 24, 2014 And the test fitting of the disc. Going to order some nice new shiney ones so I know the calliper bracket will sit spot on. Look at that rusty arch! Need to sort that out soon Quote Link to post Share on other sites
Clinternational Posted June 25, 2014 Share Posted June 25, 2014 NASTY ARCH, big priority ? I think those discs are so big and good working you'll need to spend some time adjusting the bias to gain good controlThey will lock instantly! Wicked vented discs When i look at your work, i think damn i need to upgrade mine too. Have to find a good reason first lol Quote Link to post Share on other sites
turbo Grant Posted June 25, 2014 Author Share Posted June 25, 2014 NASTY ARCH, big priority ? I think those discs are so big and good working you'll need to spend some time adjusting the bias to gain good controlThey will lock instantly! Wicked vented discs When i look at your work, i think damn i need to upgrade mine too. Have to find a good reason first lolArch will be getting a blast back treated and painted soon. The chassis has never been welded so I want to keep it that way. Had it nearly a year so I should start touching up the body work. The discs I'm going to use are 256x22mm so they are chunchier than stock turbo front discs lol but only 16mm larger that the stock 240mm turbo discs. The caliper pistons are 38mm compared to the 30.9 stock turbo rear caliper. Should have it all bolted on and running for next week Quote Link to post Share on other sites
turbo Grant Posted June 26, 2014 Author Share Posted June 26, 2014 New rear discs turned up today Quote Link to post Share on other sites
turbo Grant Posted June 27, 2014 Author Share Posted June 27, 2014 Went to shorty last night and grabbed some bits out of his aristo Should look ok once painted in white lol I'm sure they were black in the advert pictures lol I also grabbed a matching rear quarter plastic for the inside. So I now have a pretty much full interior Quote Link to post Share on other sites
Clinternational Posted June 27, 2014 Share Posted June 27, 2014 Wicked discs mate. Outstanding your rear brake setup will mayby work bette than the front haha Quote Link to post Share on other sites
turbo Grant Posted June 27, 2014 Author Share Posted June 27, 2014 Wicked discs mate. Outstanding your rear brake setup will mayby work bette than the front hahaThey probably will work better than stock front brakes lol but the 4pots on there now are savage! can't wait to get rid of the oem rear discs and callipers! I won't have to worry about the callipers binding (as much) but with the new callipers it's only like £120 for a reconditioned pair. And I will have a lot better rear pad selection WIN! WIN! WIN! I was going to use the wilwood rear callipers with mechanical hand brake. But this is supposed to be the budget daily lol Quote Link to post Share on other sites
Clinternational Posted June 27, 2014 Share Posted June 27, 2014 Nice 1.. Is there an oem brake upgrade for the rear actually? toyota stock ones off an other model by example ?? The setup i use in the front is oem toyota with a very big 60mm piston caliper. Would be funny if i can use the front calipers for the rear. Have you also changed the brakemaster cylinder ? and brake lines ? Quote Link to post Share on other sites
turbo Grant Posted June 27, 2014 Author Share Posted June 27, 2014 I've head of someone using a corolla rear brake upgrade but not seen evidence my self. I was going to use oem turbo front discs on the rear. But decide against it because the off set is more on the disc and the discs I'm using are a hell of a lot cheaper as well! I'm on oem hard lines to braided flexi's and I'm using GT turbo master and servo. Quote Link to post Share on other sites
turbo Grant Posted July 14, 2014 Author Share Posted July 14, 2014 Test fitted the rear brake upgrade yesterday. Need to take a grinder to the calipers and possible a small wheel spacers. But it's looking good apart from that Quote Link to post Share on other sites
akaye4000 Posted July 14, 2014 Share Posted July 14, 2014 Is that a Honda caliper? Quote Link to post Share on other sites
turbo Grant Posted July 14, 2014 Author Share Posted July 14, 2014 They are from the vag group off the bam series cars Quote Link to post Share on other sites
nEP71n Posted July 23, 2014 Share Posted July 23, 2014 This fast..carnt think how rapid that will go with a 4efe inside lol Quote Link to post Share on other sites
Clinternational Posted July 25, 2014 Share Posted July 25, 2014 Sick brake upgrade mate Let me know how many times you kissed the windshield 15, 16 inch rims ? Quote Link to post Share on other sites
Stu Posted July 25, 2014 Share Posted July 25, 2014 Looks good dude! Quote Link to post Share on other sites
turbo Grant Posted July 25, 2014 Author Share Posted July 25, 2014 Might get a chance to finish fitting the brakes at the weekend. Got a few jobs on the go so time is tight! The brakes just fit behind the 15's Quote Link to post Share on other sites
turbo Grant Posted September 9, 2014 Author Share Posted September 9, 2014 So managed to get the top spoiler and side skirts on for jae. Ran out of time to fit the lower spoiler/ beer shelf. Won best convertion from ukso members vote at jae. And a big group photo round my car lol Quote Link to post Share on other sites
turbo Grant Posted September 17, 2014 Author Share Posted September 17, 2014 This will be off the roads for a week or 2 in the next month or so. Need to get the forged 5e built and in. I've been running the 4efte engine nearly a year now. 1bar of boost, road mapped by me on emu and still going strong lol Quote Link to post Share on other sites
antheon2010 Posted October 5, 2014 Share Posted October 5, 2014 Can you shed some light on the rear brake upgrade Can you shed some light on the rear brake upgrade Quote Link to post Share on other sites
turbo Grant Posted April 12, 2015 Author Share Posted April 12, 2015 (edited) So after many miles of abuse I killed the car bank holiday Sunday. Got the car recover to my workshop on Monday morning. I started to strip the head of as the car was still running but had an awful misfire. I was fully expecting to see a melted / cracked piston. But none of that. I had burnt a valve out. I was thinking result at this time. What a nice quick fix I had to do. Burnt out valveSo instead of just changing the one valve I opted for a rebuilt head as the old head was warn out and need the valve guides changing as well. So I stuck a spare head on with cruise cams and solid buckets with top hat shims. Was also told my engine was built by HRF in Japan. The guy said he had the sump off and it looked stock. But when I took the head off I found this? Far from stock I'd say lol no wonder it's got low comp. had the car back up and running Monday night. Then I broke it again and took head back off. Dropped a valve. Had it back up and running Tuesday again. Now pulling like a train again. Bit more tweaking of the afr and ignition table and will be spot on again. Edited April 12, 2015 by turbo Grant Quote Link to post Share on other sites
5e colin Posted April 12, 2015 Share Posted April 12, 2015 more info on the brake upgrade grant :) is that the rear disc ( oem ) cut down for the spindle ( centre section ) ??? Quote Link to post Share on other sites
