daniel_g Posted April 1, 2014 Author Posted April 1, 2014 Sleeper look ftw Do like sleepers but this will be going square light GT style very cool project dude.i like alot !!!!Thanks buddy, means a lot Quote
shorty Posted April 1, 2014 Posted April 1, 2014 Tbh even gt kitted they are sleeper as not many 4wd starllet gt's about haha, great progress made on this dan. Quote
daniel_g Posted April 1, 2014 Author Posted April 1, 2014 Tbh even gt kitted they are sleeper as not many 4wd starllet gt's about haha, great progress made on this dan.Yeah i know what you mean, there are so few GTs around here that nobody even knew what my GT was anyway lol. I have a 4EFE Corolla as a daily now so if i want a real sleeper i'll boost that Progress was good in the first month or two abd then it died off lol. Quote
shorty Posted April 3, 2014 Posted April 3, 2014 Haha i know that feeling, i when balls deep for a month or so and bought so much shiney shit the "to do" list was mental and then had soooo many parts and spent so much that i sudenly couldnt see the end any more so lost all interest tbh. Quote
daniel_g Posted June 23, 2014 Author Posted June 23, 2014 Having a few issues with this Got this boost problem, well lack of boost i think, car feels very boggy and hardly moves till way up the rev range. I'm certain its not an intercooler leak, core holds pressure and all pipes and joiners are solid. When core is bypassed its still the same. I've two different turbos here a VF12 and a VF10, same problem with each one, i know for sure the VF10 is ok because it ran bang on in my pals V. The VF12 visually looks perfect with no oil leakage or shaft play. The EWG is just an ebay one but its brand new. Issue is the same with o2 plugged in and also unplugged. I was using the standard 85 FPR, unsure what pressure it was so i bought a brand new adjustable FPR and the problem is still there, although i know the FPR is faulty because it wont adjust lol !! I've got standard turbo injectors which seem to work ok, the ECU is from my GT so thats working. The ignition timing does need set but it shouldn't cause this. The throttle cable is adjusted perfectly. Quote
daniel_g Posted June 23, 2014 Author Posted June 23, 2014 Now i'm running out of ideas, thinking TPS or MAP sensor ?? Considering turning it back to N/a.... Quote
turbo Grant Posted June 23, 2014 Posted June 23, 2014 You running GT map sensor. And you should always set your timing before driving. You could be retarded! Quote
_shaun_ Posted June 23, 2014 Posted June 23, 2014 Still think blocking off the wastegate for a test run to ensure that's fine is a good plan to be honest. Quote
daniel_g Posted June 24, 2014 Author Posted June 24, 2014 You running GT map sensor. And you should always set your timing before driving. You could be retarded!Yeah got a GT MAP sensor off a running MK3. And yeah i know just didnt have one to hand. Will get that sorted and retry.Still think blocking off the wastegate for a test run to ensure that's fine is a good plan to be honest.Yeah Shaun i got one of those blanks and it was the same so ruling out the wastegate. Quote
daniel_g Posted June 24, 2014 Author Posted June 24, 2014 Have you had the miming belt off at all?I put a new one on when it was still N/a, i put the engine back in and it was 100%Its only since ive put the turbo parts on its not been right.Do you think a TPS would cause this ? I might unplug it and see if its improved. Quote
yaristurbo Posted June 24, 2014 Posted June 24, 2014 There's a certain way to set tps isn't there? Quote
daniel_g Posted June 24, 2014 Author Posted June 24, 2014 There's a certain way to set tps isn't there?Yeah with feeler gauges and a multimeter. Im using a Gen1 FE inlet & TB which are identical to the turbo ones but maybe the actual sensor is different who knows. Quote
_shaun_ Posted June 24, 2014 Posted June 24, 2014 Long shot but have you got acces to a smoke tester to check for any daft wee leaks? Quote
daniel_g Posted June 24, 2014 Author Posted June 24, 2014 Long shot but have you got acces to a smoke tester to check for any daft wee leaks?Nah we dont have one at work, but am gonna try it pikey style with a can of spray lol. Quote
TurboTobz Posted June 24, 2014 Posted June 24, 2014 20 deck of superking blacks should do it (A technical remedy for fault diagnosis) Quote
bucketep91 Posted June 24, 2014 Posted June 24, 2014 With the price of fags these days youd be aswell buying a smoke machine!If you want to try another tps u can borrow one of mine mate;) Quote
daniel_g Posted June 24, 2014 Author Posted June 24, 2014 20 deck of superking blacks should do it (A technical remedy for fault diagnosis)I normally just throw things about and shout lol.With the price of fags these days youd be aswell buying a smoke machine!If you want to try another tps u can borrow one of mine mate;)Thanks for the offer man, am certain ive another TB with a TPS on it buried in the car somewhere. Will dig it out and try.So i'll set timing, set fueling once i get this fuckin FPR sorted and swap the TPS over. Quote
daniel_g Posted June 25, 2014 Author Posted June 25, 2014 My ignition timing was 1 degree retarded, set it to 10 BTDC, still the same. Set the TPS, still the same, fucked about with the knock sensor, still the same fuckin fault. I know this fuckin shitey FPR i bought is fucked so thats obviously not helping matters. Does anyone know what pressure the N/a FPR runs at ? Same as a turbo starlet 2.4 bar ? Think am gonna change the MAP sensor... Just to recap, fault is very boggy on low revs, fine higher up rev range. Anybody have any suggestions ? (apart from setting the bastard alight because thats very tempting atm) Quote
garrygt Posted June 26, 2014 Posted June 26, 2014 it wouldnt be anything to do with your lambda sensor would it? is it one out a gt your using? as im sure the lambda sensor is only needed in lower revs Quote
daniel_g Posted June 26, 2014 Author Posted June 26, 2014 I have thought about that yeah, sure its the one from my old GT, the car is still boggy with or without the o2 plugged in. Hopefully im getting anothe FPR sent out or i might stick a standard turbo one on. Knock sensor is getting swapped because i thought it might be faulty and the timing was getting pulled back. Gonna get another MAP sensor. Also will have a look at the ignition system, dizzy setup came off a fully functioning car although i've not had a look at the cap or rotor arm, leads and plugs are brand new. Ignitor is from my old GT. Last resort is a new engine loom. If it still faulty after that then i'll kill myself Quote
daniel_g Posted July 1, 2014 Author Posted July 1, 2014 This is turning into some state sitting there haha Quote
