is this a jam manifold
I don't think it is, the big deal is the reliability with the spool time and they can run the bigger turbo's, the runners are wider and all equal length's compared to stock jam knew what the were doing, if it was a case of just porting stock they would of just did that but the design is different in its own way...
  On 9/24/2013 at 10:47 PM, bucketep91 said:
Whats the big deal with jam manifolds anyway? Its essentially just a ported oem manifold
Its not a ported oem manifild. They have different casting marks on them compared to the oem manifold so they are essentially casted from a differnt mould.
They retain the stock look and have non of the restrictions.
  On 9/26/2013 at 11:36 AM, Addymk2 said:
they just need to be matched to the head ports. If they're bigger than the head ports it can actually slow down exhaust flow. Just a thought
That's the worst thing to do on a turbo motor, but that's a whole different topic.
I thought the cross section on the collector sat flush with the flange face on the jam mani's. Can't quite tell if it is flush from that pic though.
That's what I meant, I can't see a company like JAM knocking out a manifold with huge ports which will essentially kill off performance.
Doesn't look OEM, the dip for the middle runners doesn't look as deep as my old OEM manifold.
Right here we go the jam mani is on the right look at the thickess difference in the tubes more exspansion for the gas flow and the thicker ports...much thicker so no matter how much you port the stock it's never going to flow better, the guy probably thinks its a jam mani so he has taken it off ebay lol if anybody else says the jam mani is just a ported stock one more time am gunna kick off lol :pnewphotos006_zps62112bfd.jpg
