The Toffinator Posted November 17, 2013 Posted November 17, 2013 Anybody have any reccomendations on what sealant to use? and tightening sequences etc?3 Times i have tried to seal this bastard now, Some form of loctite gasket stuff before, and a silicone carplan type stuff made for sumps etc tonight and its still pissing out!Been tightening it from each corner, all even etc to pull it flat Quote
lee0100 Posted November 17, 2013 Posted November 17, 2013 this might work? http://www.ebay.co.uk/itm/1-x-QUALITY-BLACK-RTV-SILICONE-SEALANT-310ml-INSTANT-GASKET-HIGH-TEMP-AUTO-/200713887443 Quote
kavan-k Posted November 18, 2013 Posted November 18, 2013 Pop into your local vw dealership and buy their sump sealant, you wont beat it, know of 3 mechanics that swear by the stuff Quote
Sefton-EP91 Posted November 18, 2013 Posted November 18, 2013 Pop into your local vw dealership and buy their sump sealant, you wont beat it, know of 3 mechanics that swear by the stuffWas going to say this. I am a VW mechanic and the stuff is lethal. Highly recommend but VERY messy. Quote
micky boy Posted November 18, 2013 Posted November 18, 2013 Daz is haveing this problem lol When i done mine a few years ago i use the toyota gear but it cost a bomb £70 a tube lol but worked first time Quote
JayJ Posted November 19, 2013 Posted November 19, 2013 Do you guys have any idea how much a garage will charge for a sump sealing? And if my oil level is just over the full mark is it more likely to leak out than if the level is on a half way? Quote
turbo Grant Posted November 19, 2013 Posted November 19, 2013 I use loctite premium black silicone from halfords. Ground it to be great stuff! Use it on loads of sumps that I do, even the VW ones! When sealing sumps if it's not spotlessly cleans and free from oil there is no point trying to seal it up. Preparation is every thing when it comes to sumps. Get some brake or carb cleaner and clean all the surfaces down with that so it's absolutely clean. Then run a nice bead of sealer round the edge. When you stick the sump to the engine you want to put it on once. Don't move it around to find the bolt holes if your location studs are gone. Tightening up should be done from the corners working your way in words. This is how I do my sumps. I would recommend you leave the sealer to go off over night. But I have driven cars after 20mins and they have been fine. Quote
rob_bower Posted November 19, 2013 Posted November 19, 2013 I've found the loctite one to be best to. Don't over tighten as it can flex the sump and cause a leak. Quote
Liam_D Posted November 19, 2013 Posted November 19, 2013 Pop into your local vw dealership and buy their sump sealant, you wont beat it, know of 3 mechanics that swear by the stuffThis! I used this on my old n/a it worked a treat! Quote
Broony Posted November 19, 2013 Posted November 19, 2013 toff have you left if for 24 hours to set? i did on mine don't put the oil back in for 24 hours gives it chance seal:) also wipe mating surfaces with thinners loctite black stuff from frauds worked a treat. Quote
The Toffinator Posted November 19, 2013 Author Posted November 19, 2013 I dont have time for this 24hour malarkey, overnight is all i have lol.Tried black silicone RTV last night and touch wood i think it has got it! Used your technique grant. And used carb cleaner to clean surfaces up. Will see if its sealed tommorow, if not i will try the suggestions aboveThanks! Quote
Mikeyallgood85 Posted November 19, 2013 Posted November 19, 2013 I wouldn't tighten it all the way as it will just piss out on the edges if you have given it enough time to set! as mentioned let it set for 24hr and then tighten it all up. Quote
The Toffinator Posted November 19, 2013 Author Posted November 19, 2013 Followed the instructions which said wait until tacky (Half an hour or so) Then nipped it up Quote
Patches Posted November 21, 2013 Posted November 21, 2013 i used the loctite copper sealant, worked a treat. Like the boys said, make sure its super clean and dry. I would personally leave it for 24 hours before putting oil in the engine just to save having to redo the process again if it wasnt left long enough. Quote
The Toffinator Posted November 21, 2013 Author Posted November 21, 2013 I wouldn't tighten it all the way as it will just piss out on the edges if you have given it enough time to set! as mentioned let it set for 24hr and then tighten it all up. i used the loctite copper sealant, worked a treat. Like the boys said, make sure its super clean and dry. I would personally leave it for 24 hours before putting oil in the engine just to save having to redo the process again if it wasnt left long enough. Yep you are all right lol, fucking thing is leaking still... So the idea is im guessing is once its all degreased with brake cleaner/carbcleaner or similiar, use a bead of sealant all the way around, wait till it sets then bolt it up? Ie to create like a proper gasket? Quote
Patches Posted November 21, 2013 Posted November 21, 2013 i used 2 beads, one on the outside and one on the inside of the bolt holes if that makes sense. Get it fitted and bolted in place as quick as you can after using the sealent. You want it to set on the engine. It might also be an idea to use a torque wrench to tighten up all the bolts to the correct torque, overtightening can bend the sump which would result in a crap seal. And obviously dont put any oil in the engine for a good 24 hours. Quote
