Glanza1996 Posted July 13, 2014 Posted July 13, 2014 So I got a little problem were every couple of weeks I have to tighten up the bolts. I have had a mechanic look at this but he failed and I have tried all sorts of bolts putting washers on etc has anyone got any ideas how I can stop them from coming undone? Thanks Quote
bucketep91 Posted July 13, 2014 Posted July 13, 2014 Had the same problem years back.Tighten it back up and put another nut on and tighten it against the first one. Quote
akyakapotter Posted July 13, 2014 Posted July 13, 2014 They are ment to be one time use nuts. get new ones and they wont come off bit of loctite would help aswell. Quote
Glanza1996 Posted July 13, 2014 Author Posted July 13, 2014 Okey cool ill give some loctite ago Quote
thorpy36 Posted July 13, 2014 Posted July 13, 2014 (edited) Serrated nuts will help as it bites into the metal of the flange as it try's to undo itself preventing them coming loose Edited July 13, 2014 by thorpy36 Quote
Sheehy StarletGT Posted July 13, 2014 Posted July 13, 2014 Camskill supply new Toyota nuts for the cat and there cheap too!! Quote
rinseep82 Posted July 13, 2014 Posted July 13, 2014 Use some spring washers they shouldn't come loose anymore Quote
Liam_D Posted July 13, 2014 Posted July 13, 2014 Had the same problem years back.Tighten it back up and put another nut on and tighten it against the first one.This was what I did with my old ct9 setup worked a treat. Quote
Starlet__SR Posted July 13, 2014 Posted July 13, 2014 Flanged nuts with the serrations and loctite. Day Quote
Socks Posted July 13, 2014 Posted July 13, 2014 Been there done that got t-shirt. Loctite fixed the issue.. Allow it to dry tho! Quote
Ryan_EP82 GT Posted July 14, 2014 Posted July 14, 2014 Use a spring washer, nylon nut and loctite and itll never ever move again Quote
asbo-v Posted July 14, 2014 Posted July 14, 2014 The ones I was supplied from Toyota are the ones you need £13 while your there change studs too ;)Worked for me Quote
scottieboi94 Posted July 15, 2014 Posted July 15, 2014 Use studs with nuts and then use loctite it should be fine then Quote
