So I got a little problem were every couple of weeks I have to tighten up the bolts. I have had a mechanic look at this but he failed and I have tried all sorts of bolts putting washers on etc has anyone got any ideas how I can stop them from coming undone? Thanks
Serrated nuts will help as it bites into the metal of the flange as it try's to undo itself preventing them coming loose
Edited by thorpy36
Had the same problem years back.
Tighten it back up and put another nut on and tighten it against the first one.
This was what I did with my old ct9 setup worked a treat.
